Amundsen MIB2 Firmware Update
Please, is it possible to send me an update on my amundsen, I enter the factory settings and after turning off the ignition, everything is back, I hope for a fix. Thank you in advance and sorry google translation
  • Replies 4.7k
  • Views 917.1k
38 minutes ago, Kingbrit said:
Is this the correct screen?
Thanks in advance!
Yes I will send along 0369 version in PM
Use this location to update firmware
I shall send you a link to 0253 version
Hoping this helps your situation
On 14/11/2022 at 12:01, varooom said:
@stefansuperb3@vektors are you still awaiting firmware updates?
@Phil82if you're new then you won't be able to edit posts until you have written 5 or 10 posts.  I will send you a PM for 0480 version.
Yes still waiting for help. Last time year ago @pab567 sent me a firmware update what worked.
I took a bit of the weekend off from a lot of firmware help.
I can send you 0369 version to you.
Thanks a lot. I wait for it
Hello all!
Is there an update available for my Amundsen? See picture.
Thanks in advanced.
17 minutes ago, ThomBrink said:
Hello all!
Thanks in advanced.
Morning, press and hold down your Setup/Menu key for about 10 seconds to get into the engineering menu, this has Software Train, and also the correct firmware update button.
Odds are, you can update to 0369 version.
Thanks! Can i download the 0369 anywhere? Menu say "... nothing found on sd-card ...".
I can send you 0369, but ideally you should verify your Software Train information first.
Yours should be
MST2_EU_SK_ZR_P0359T
Available
MST2_EU_SK_ZR_P0369T
Hi, I am new to briskoda
There's new software update for my skoda karoq 1.6 se technology
Many thanks
Edited by john999boy
Tidy up
Many thanks
You have PM for 0480
Thanks @john999boyfor the tidy up
Hello all,
I'm having various freezes on my Amundsen - any idea if an update would help and if so does anyone have a link to a newer version?
I'm on SW 0241, train version MST2_EU_SK_ZR_P0241T.
Thanks!
Edited by London_Jock
Hi.  I recently changed the display on my superb.  Apparently it should show 6 radio icons.  Is there any soft or leave it as it is?  Soft radio 0253
On 17/11/2022 at 18:49, varooom said:
You have PM for 048
Thanks for your help
I tried but not working me
I used 7-zip and winrar to extract
I use to different sd cards 8gb and 32gb
I download on the pc twice
Even I download on my phone as well
Can you help me further please
Hi, in engineering menu when I press 'versions'
I uploaded the picture
Might this help
On 20/11/2022 at 11:54, London_Jock said:
Hello all,
Thanks!
I can send you 0253 version for you
Check your PM's
Might this help
Sorry was taking a weekend off for family time.
Remind me what media you are using for the update?  SD Card or USB?
In theory you could use FAT32/exFAT/NTFS format for the firmware update, though I usually recommend the first two.
Have you got a picture of the files on your update media?  If you have a folder called MST2_EU_SK_P0480T then that won't work, only the contents of this folder should be copied to media.
I use sd card FAT32 and exFAT
When press 'MST2_EU_SK_ZR_P0475T(0475-1)
Only 4 files showing
Cpu
icici
main
powerc
Cpu
icici
main
powerc
When pressing current version
MST2_EU_SK_ZR_P0475T(0476)
Many thanks
This is the screen you should be in for updating, the other menu you're referring to is the history of updates applied.
Might be an idea if possible to send a screenshot of your SD Card contents, in the 'root' you should have a single text file, and then about 30 or so folders.
Hi
can i request an update for this system?
Taking this opportunity, could someone please share a thread on hacking MID2 system. I would like to upload codes that activate hidden functions, such as Smartlink
i hope this will help
thanks
