Amundsen MIB2 Firmware Update
1 hour ago, Andrei1997 said:
please someone can help me with an update file?
Also if anyone knows, on my unit carplay doesn’t work anymore with the last IOS…
Thank you a lot
There is update to 0369 version, not sure it will cure your problem.
You may also loose the FEC codes if they have been hacked into the system, won't know until you try update.
  • Replies 4.6k
  • Views 864.9k
FEC codes are bought whe i ordered the car, none was hacked
Then they should survive the firmware update process 🤝
Do you know where i can find the update file?
Thank you!
Thank you!
Yes, via PM to you... wait 2 minutes.
Thank you very much.
Hi can I get update 369 file for my MIB unit.I’m wanting to enable Apple car play main reason for doing this
I have sent it, but please note that the FEC codes are what give you functions as your firmware has it already inside.
HI!  can anyone help me to update my mib2?  I would like to activate Android Auto and they advised me to update the firmware..
I will send a link to 0253
3 minutes ago, varooom said:
Invierò un link allo 0253
Thanks!🙂
Hello,
I have a Skoda Yeti with a Amundsen it only have Mirrorlink and i hope to get Android Auto with a Firmware update.
Valid SWAP FEC codes are already installed.
Software Train is MST2EU_SK_PQ_P0245T
Part 5L0035680C Hardware H22
is it possible to update to 253T? or what is the latest possible Version?
can you provide me a download link?
4 minutes ago, OlsenOil said:
Hello,
Sent link, but don't expect miracles
Hi @pab567, you are clearly a hero. Please help me out with the firmware on my 2018 VRS. It’s currently as follows :
PN: 5Q0035874C
Hardware: H41
Software: 0471
NAVDB: 5L0051236AD
0910
ECE1 2018.
Please could you send me the latest update file.
Thank you!
Howard
PM
I finaly did it,
update to 0253T was succesfull.
And Today I changed with OBD11
Module : 5F. (Information Control Unit)
Adaptation
Vehicle Configuration
Google_GAL=active
Apple_DIO = active
Now
MirrorLink
AQndroidAuto
AppleCarPlay
are availiable from SmartlinkMenu
Thanks Varoom
I finaly did it,
Adaptation
Google_GAL=active
Apple_DIO = active
Now
MirrorLink
AQndroidAuto
AppleCarPlay
Thanks Varoom
Nice work, and write up for others
31 minutes ago, OlsenOil said:
finalmente l'ho fatto,
l'aggiornamento a 0253T ha avuto successo.
E oggi ho cambiato con OBD11
Modulo: 5F. (Unità di controllo delle informazioni) Configurazione del veicolo
di adattamento Google_GAL=attivo Apple_DIO=attivo
Ora
SpecchioLink
AQndroid Auto
AppleCarPlay
sono disponibili da SmartlinkMenu
Grazie Vaom
good job! do you think it is possible to activate android auto with vcds vag? smartlink requires me a code to buy in skoda service
Hello @pab567
Thanks for all.
Could you help me with the firmware on my 2017 L&K ?
PN: 5Q0035864C
Hardware: H41
Software: 0475
NAVDB: 5L0051236BR
1410
ECE AS 20/21
Thank you!
Cédric
No, it's not possible.
@cedricq check your PM
Hello,
can I get the update file for my MIB2 unit? Car is Octavia 2017 MK3 5E RS 4x4.
And also is there any kind of information what exactly its improved version after version? Should I update it only if I find some bugs/issues?
42 minutes ago, Nice_to_Mitio said:
Hello,
You can update to this
release = "MHI2_ER_SKG11_K3343"
MUVersion = "1433"
There are no release notes.
That's a bigger debate, there maybe fixes you won't see, but then after the whole system is more responsive, or if using bluetooth it's more stable.
Let me know if you wish to try update.
I will give it a go. @varooom do you happen to have the link to this version?
Of course, I will send a link now I am able via PM
