Amundsen MIB2 Firmware Update
33 minutes ago, colinjmatt said:
Hi, I've just got my Octavia and it looks like I might need a firmware update too if you can help?
Also, would I be able to install the mic-std2 toolbox on this unit?
You can have update to 0480, as for MIB Toolbox, you must have "Developer Mode" enabled in the radio for that to work... do you have VCDS or equivalent?
  • Replies 4.7k
  • Views 916.6k
I've seen your PM thank you. I've already enabled developer mode too in preparation for the update and installing mib-std2 toolbox
Hey,
I would be happy if I could get a firmware update
Best regards
4 hours ago, timmsel said:
Hey,
Best regards
I will send you a link to 0480 version.
Hi Looking for MST2_EU_SK_PQ_P0363T. Thanks
Do you need the older firmware???
MST2_EU_VW_PQ_P0369T exists you see
I tried a copy of MST2_EU_SK_PQ_P0369T, it failed during installation, I tried a few times and it failed at the same point, maybe a file error. Wanted to revert to original.
More than likely, a bad copy, or bad SD Card.
Not sure what you mean by "revert" to as if it failed, you would still be on orignal... or did it actually partially update?
You would be better grabbing copy from me, and loading this on, if your SD Card is duff, then you will see checksum errors.
I'm not getting any checksum errors, just a read error on a file. The archive passes winrar integrity test. I have used a tool to compare the file on the sd card and disk, they are identical. How do I grab a copy from you?
Can I get the link to latest FW - SW Train MST2_EU_SK_ZR_P0471T, 5Q0 035 874 C. Thanks
Well then let us go with my nice clean files then, make sure to use 7-Zip (free software to unpack) or make sure to update your WinRAR as I think the older versions may not read correctly.
I will send you a PM with link/destructions.
EDIT: Having woke up a little more, can you confirm your Software Train with a picture?
You said you have...
I have only
MST2_EU_SK_PQ_P0253T version, and cannot see any higher.
Edited by varooom
Original software status, installing 369T has led to a red screen of death during installation.
I suspect you may have a bad SD Card, as this is the common culprit.
Sadly I do not have a matching firmware... @pab567do you have 03xx version for the PQ series?
Can you run in an Admin Command Prompt (change M for the SD Card letter) and look for bad sectors on the card?
ChkDsk M: /R
I have NEVER seen any frimware updates fo SKODA SOP3 PQ units, @KATV pls share the link for MST2_EU_SK_PQ_P0369T so I can x-check it.
I have tried a different SDHC card, and it fails in the same place updating to 0369T. If this is a problem wiould like to revert to the original 0363T.
I don't have any solution for you I'm afraid, I can see one post where someone claims to have 0363 & 0369 firmware, but probably wants to sell the files for money.
Are you now stuck in Red Emergency mode?
Yes, I'm stuck in emergency mode, with a loop of please insert update.
Last suggestion would be to use another tool to unpack, like 7-Zip?
Can I update this unit ?
Thanks in advance @pab567
Hi, any update available for this please?
Thanks!
Thanks!
I bet we can update you to 0480 version
Hello, I installed the current version on my columbus MHI2_ER_SKG11_K3343_1433 and I expected to be able to display the new menu. Is there any way to do it?
No because new menu is from newer media unit, you cant transform crt monitor to lcd one…
Hello, is there an update to my Superb 2018 system and how could I get it? And thanks to everybody for the awesome thread!
I think we can update you to 0480 version by Private Message
