Amundsen MIB2 Firmware Update
26 minutes ago, pab567 said:
Both possible with your unit, check MIB solution one website
I know, but when i tried with 0480t it said "unable to read the file meta information, dependencies of update not meet"
  • Replies 4.7k
  • Views 901.5k
@Nevals Yes, it can be done.
@Cdrmihh it's normal. You have to patch your unit first. Google for MIB STD2 Toolbox
do i need a VCDS or OBDeleven to install toolbox? cause i don`t have developer mode enabled..
Nope, you install it as a regular firmware update (as long as you have unit with oem sat nav - and you have it :) )
On the toolbox instructions, after installation it says developer mode (GEM) is needed to use the toolbox, which needs OBD11?
Yep, sorry, I forgot it, you need VCDS, OBD Eleven, VCP, ODIS or VC Tool to enable develope mode.
Yep, i tried 5 minutes ago installing toolbox and then the 0480t version and still doesn`t work
Edited by Cdrmihh
Can I update this? How?
Does anyone knows what is the lasted firmware for:
Onderdeelnummer apparaat: 5Q0035874C
Hardware: H41
Software: 0480
Navigatiedatabase:
V03959820MP
2110
ECE DL3 2024
Shield: Shield 2016-44 (build 309)
Media-codec: 4101.0.0.1
Bluetooth version: C300
SmartLink: 4101.480.0.0
Radio database version: 1.10.48
USB surfstick version: 4101.438.1.5
And where i can get the lasted firmware? thank you.
Hello, is it possible to put this update MHI2_ER_SKG11_P2104_MU0318 on my Skoda Octavia 5E .
I currently have the one MHI2_ER_SKG11_K3343 thank you for everything
Edited by skodo_octav
SVP, y a t il une mise a jour pour mon logiciel sur  octavia :
Voilà la  Version logiciel de ma voiture :
MEN2_EU_SKJPx_P7381L
Version unite princ.inst : 8740
20250122_161426.heic
So i can install toolbox and after thart i can install MST2_EU_SK_ZR_P0480T over MST2_EU_SK_ZR_P0369T?
It is not straight forward and there is a risk of bricking the device. I did it last year there is a procedure you need to follow and yes using GEM toolbox.
using  this MIBSTD2_Toolbox-v1.4.2 and then install P0480T...thats all they say..
If you have unit with OEM sat nav - yes, and it can be done from SD without necesiity to open and solder the unit.
I have original sat nav.. i installed toolbox but when i try to instal 0480 it says i cant. What do i need to do in toolbox to get it installed? Thank you.🙏
Just google, it has been described multiple times...
HI PLEASE I NEED UPDATE FOR MY CAR SKODA RAPID 2018 AS I LOST MY SD CARD
THANK YOU A LOTS
Puzzled by your comment - how will an update help with a lost SD card?
Hi
can anyone tell me if I’m on latest firmware or if anything newer is available please thanks
Hello!
I have the following firmware installed, Is there any new firmware i can install for my system? Thanks in Advance
Device n: 5Q0035840B
Hardware: H30
Software : 0361
@pab567 i tag you since you look the guru here 😂 thanks
5 hours ago, Aakayamy said:
Hi
Yes, you are on the latest firmware.
Once again for all those who don't know how to use "Search"
1. format SD (if possible 8, 16 or 32GB) under FAT32.
2. unpack to root (metainfo2.txt and all the folders must be placed directly on SD, not in any folder)
3. insert SD card into the slot
4. enter Service Menu (long press MENU button)
