Amundsen MIB2 Firmware Update
1 hour ago, pab567 said:
@fthkara you have non-navigation unit, upgrading to 0480 in this case requires unit to be dismantledm opened and resoldered.
@Davidmet14 pls post part number of your unit.
This is my version.
Multivan t6
  • Replies 4.7k
  • Views 898k
@pab567 So what is the most relevant version that i can upgrade ? Can you suggest me please? I want to solve these carplay problem any help will be great
@fthkara 0369, I have just sent you download link on PM
@Davidmet14 You can upgrade to MST2_EU_VW_PQ_P0480T but first you have to install MIB STD2 Toolbox and patch swdownload in order to install this firmware
Yes, but unfortunately I don't know where to download STD2. With swdownload.
Does anyone have it available?
And could they provide it?
Thank you
David
Just google for 'MIB STD2 TOOLBOX" then read and follow instructions from github
Yes yes I know github.
But I don't know how to download the Toolbox version.
I downloaded version 1.3.3 which I read should work with my radio.
But I would like to be sure.
Please confirm that this version is correct.
See photo
I don't use it at all so someone else has to confirm but if this is the newest version then IMHO you should go with it.
Okay
So what do you think I should use?
As you wrote from the github page?
Or where can I find the patch you wrote about?
Patching is made with MIB STD2 Toolbox so have it installed, in the newest version.
Please, can you send me a link or a photo in a message? There are several versions. Please, please. I really want to fix the radio.
Thank you very much
I understand but as I wrote you previously, I don't use it at so can't help you more.
Ok, thank you very much anyway.
Is there anyone else here who can confirm the installation of Toolbox 1.3.3. Will it then allow me to flash the firmware to version 480?
Thank you very much for the answer.
Have a nice day everyone
David
@pab567 I understand you could possibly provide me download link to
MST2_EU_SK_ZR_P0480T ? I would be very grateful if you could do so.
Sent in PM
David
Hi, you are trying to do the same update I have looked into, the stopper for me was access to the GEM (Green Engineering Menu). Just checking, do you have access to it or OMB11 or VCDS?
4 hours ago, pab567 said:
Sent in PM
Can I have the link for MST2_EU_SK_ZR_P0253T?
thanks
PM
@pab567 can you please send me link for MST2_EU_SK_ZR_P0480T as I can't seem to get it from anywhere on the internet? TIA
PM
@pab567 Hi. Thanks for the file MST2_EU_SK_ZR_P0480T which I downloaded and put onto SD card this morning. Tried to update system but it came back saying unable to read metadata info.
I formatted SD card (quick format) with File system FAT32 and allocation size as default. Any thoughts?
It looks that you are trying to update from SW version 02xx or 03xx - this is not possible unless you patch your unit first.
Oh OK. I'll look into that then and see what I can sort out
Hi everyone,
so I have confirmation that for the update from 245 to 480 you need Toolbox and even version 1.3.3.
Unfortunately I overlooked one thing.
I have version MST2_EU_VW_PQ_P0245T
And the downloaded 480 software from pab567 is for version MST2_EU_SK_ZR_P0245T
The problem is in the letters PQ (multivan t6)
And ZR (octavia for example.)
The difference is in the unit located in the radio or separately in the passenger compartment.
Please can someone give me a link to download the new software for Multivan? That is for MST2_EU_VW_PQ_P0245T
Thank you very much
David
Thanks very much @pab567 ! Update went without a hitch an CarPlay is working again 🙏
does anyone have these as mibsolution down
MST2_EU_SE_ZR_P0512T.7z
MST2_EU_SE_ZR_P0514T.7z
MST2_EU_SE_ZR_P0515T.7z
