Amundsen MIB2 Firmware Update
3 hours ago, ulli0824 said:
Hello,
the latest official firmware update for your headunit is: Latest official firmware update: MST2_EU_SK_ZR_P0369T.
You can check this yourself on the website: https://mib-helper.com/index.php?train=MST2_EU_SK_ZR_P0359T.
Unfortunately, I can only help you with the information, as I don't have access to the firmware. The download website https://mibsolution.one/ has been closed.
Perhaps someone else here can help you download the firmware.
Best regards
Thanks, I would very much appreciate if someone could provide a download link for that specific version.
  • Replies 4.7k
  • Views 900.1k
1 hour ago, CptSeasick said:
Danke, ich wäre sehr dankbar, wenn mir jemand einen Download-Link für diese spezielle Version zur Verfügung stellen könnte.
Password PM
https://mega.nz/#P!AgEWbXJNihmMYuO4uyZm-6bB5pDjb9xNsqyZXk0bqofMzQYlpRFtj9XJF2vdfW2hAhIaGKyoQpiqQZW9gkgxn8mXKB5ryZ_ef9euCqmTocRmtfQlKVJSVNwwI4eULf-6d6a-HQRv1e4
Hello everyone,
I have a Škoda Amundsen MIB2 STD2 ZR NAV unit with the following details:
• Hardware version: H41
• Firmware version: MST2_EU_SK_ZR_P0478T
• Device part number: 5Q0 035 866 C
• Still working map version is: VO3959820BS - 2010 - MRM DL2 23/24 SHIELD 2016-44 (build 309) (There is no metainfo2.txt at SD Card and working)
Could anyone please share the latest compatible map package for this unit? Or do I have update the firmware first?
So I’m mainly looking for a verified and working map that runs correctly on this hardware/firmware combination.
Thanks a lot in advance for your help and for keeping this topic updated!
Edited by explo
@Cairus Could you also provide me with the MST2_EU_SK_ZR_P0480T please.
2 hours ago, Garbski said:
Hi Explo
Go to the Škoda update portal and enter your car's VIN number, all updates and maps
are available for download from there.
https://updateportal.skoda-auto.com/?appVIN=&appLanguage=en-GB
Thank you Garbski, I tried this before, but when I enter my VIN number in this address, I get a message saying there is no suitable map. I don't know why.
Sorry I can't be of any more help. I have a 16 plate Octavia and that's all I
do and don't have a problem with updates or map downloads.
Hello I'm seeking MIB firmware versions MST2_EU_SK_ZR_P0369T and MST2_EU_SK_ZR_P0480T
Can anyone share me the files please.
Thank You
55 minutes ago, vasjaimelik said:
Hallo, ich suche die MIB-Firmware-Versionen MST2_EU_SK_ZR_P0369T und MST2_EU_SK_ZR_P0480T.
Kann mir bitte jemand die Dateien teilen?
Danke .
You can Not Update from Firmware x3xx to Firmware x4xx
Unfortunately, no one can provide me with the required firmware, or did I do something wrong here in the forum?
Understood.
In this case I need only MIB firmware version MST2_EU_SK_ZR_P0369T
Right now I have MST2_EU_SK_ZR_P0361T
SW MUI Version: 0361
Hardware: H30
Can You update from Firmware x2xx to Firmware x3xx?
If so can someone share the firmware with me please
Edited by Stevejd58
On 28/10/2025 at 14:32, Cairus said:
Password PM
@Cairus is this download link still valid if so can you please share the password. As i understand the conversation it should contain the MIB I need - MST2_EU_SK_ZR_P0369T
Hello can i have a link for MST2_EU_SK_ZR_P0480T
On 14/10/2025 at 11:11, KodiaqBear2017 said:
Hi, I'm writing from Italy.
Thank you for this precious support channel!!
After an app update, I'm having a connection problem between the infotainment system and the "MySkoda" app (I had already renewed all the services 😭 ).
The dealership told me it's definitely an update issue, but they have to keep the car for a whole day, and it's a big problem for my job.
Can you help me, please?
Here are the system screenshots. Thanks!!!!!
Hi everyone! Can anyone help me with this version? 😰
@pab567
Firstly, check your PMs for download links.
Secondly, how many times it must be repeated that:
  1. None official firmware update activates new features, e.g. SmartLink
  2. It's NOT possible to upgrade from 02xx to any other soft than 02xx, from 03xx to any other than 03xx and from 04xx to any other than 04xx without patching unit first.
  3. To patch the unit you can use MIB STD2 Toolbox.
  4. Units with OEM navigation (two SD slots) can be patched from SD.
  5. Units without OEM navigation (single SD slot) can NOT be patched from SD, they must be reworked on bench as some files must be manually replaced in EMMC.
  6. To use MIB STD2 Toolbox you also have to enable developer mode in adaptations.
  7. to upgrade from 02xdx to 03xx or 04xx, or from 03xx to 04xx, you MUST modify metainfo2.txt
And pls, don't ask me how to use MIB STD2 Toolbox or how to modify metainfo2.txt - I give you a fishing rod, not a fish, you have to use your brains (and Google...)
Dear, @pab567 With the new "MySkoda" app update, the system finally connected and reactivated. The update issue still remains, if you could please help.
Thank you so much!!!! @pab567 I'll try it now!
On 16/09/2025 at 11:05, pab567 said:
Yes, you can, but in every case unit requires patching of swdownload first - if you have AMundsen then you can do it from SD card with MIB STD2 Toolbox, if you have Bolero then unfortunately glove box unit must be disassembled and soldered.
Hello @pab567
I have Amundsen. Will you please be able to help and to explain the steps on how to update to P0480T, using MIB STD2 Toolbox and where to download the update for P0480T (MST2_EU_SK_ZR_P0480T). Thank you very much.
I sent you download link in PM. Concerning the rest of your request - as I wrote: don't ask me how to use MIB STD2 Toolbox or how to modify metainfo2.txt.
Edited by pab567
On 16/02/2020 at 21:11, pab567 said:
Let me know software you have currently installed
On 01/11/2025 at 07:17, pab567 said:
Hello pab567
Hello @pab567, could you please send me the firmware for updating my Amundsen radio?IMG_3945.jpeg
Sent in PM
Thank you so much, @pab567 ! Everything was perfect!
