Amundsen MIB2 Firmware Update
17 minutes ago, gerstemann said:
There should be one, but no one has it yet.
I haven't seen anything higher that 0478 for the MIB2.5 Bolero/Amundsen.
What do you think the newer version is?
I have seen version numbers for 0490, but this is SOP1.x hardware or MIB hardware. The version number doesn't always follow.
43 minutes ago, gerstemann said:
480
Interesting, any pictures/autoscans from units running it? Everything I can see online suggests 0480 is only a MIB1 software.
I've just checked erwin and TPI 2049459/10 shows 0367 and 0478 as the latest versions.
On 21/06/2021 at 20:45, pab567 said:
Itr's rather HW than SW issue. Of course you may reflash the unit with latest SW just to be on the safe side but first you must send model number and current SW version - long press SETUP then SYSTEM INFORMATION.
All others check your PMs
oh dear...what do you suggest I do? go see?  it may not load properly for days, then all of sudden just work for a day or so.
i managed finally to get my model number and SW version.  Looks as though HW is H21, and SW is 6270.
 thx in advance for your help
8 hours ago, gerstemann said:
Does anyone speak Russian and can write a summery?
Easy - enable closed captions - press the * button - select Auto-Translate and choose your language.  They guy thinks he got the update from his local dealer.....
10 hours ago, Harry0989 said:
Hi All,
I also would like to request an update for my Amundsen.
Online Update did not work because the service is unavailable.
Thanks in advance, BR
You need the help of @pab567 - there is 0363 for your car (SOP3.x)
8 hours ago, blk said:
Hi
Is there any update for my headunit?
Thanks!
Yes - there is version 0478 available for your car - speak with @pab567
Hello from Australia.  I'm not sure if the firmware is universal.  This is my system.  Is there any update compatible with what if have?
Zac
@pab567 please could you send me the update file for this firmware. My infotainment is playing up a little so I'm hoping the update will cure it.
Any help would be much appreciated.
Does anyone know if updating the firmware of a hacked unit would disable the CP and Smartlink functionalities? My unit current version is: Hardware 25, Software 0252.
Depends on the files that are updated during such update.
  • Love it! 1
Thank you very much for your reply @pab567. Can I ask what is the latest update for my firmware (Hardware 25, Software 0252) and is there a way to do such an update?
