Tested and working coding Octavia mk4
14 hours ago, OccyVRS said:
@PetrolDave I'm not sure any development on the SFD front is really a priority for OBD11?
I'm not sure why you made a link between the OBD11 apps and SFD, I didn't.
I've made 2 unconnected posts recently on here:
1) Ross-Tech are working with VAG to enable SFD on VCDS
2) OBD11 apps have a history of making changes that have unwanted side effects.
  • Replies 294
  • Views 128.9k
  • Self moderation is the key to happiness. The best reply is sometimes no reply at all.   we’re all free to do what we want to do with our stuff.   Why would someone buy a brand new
  • @SkOmk4, My answer in line: 1. All the Release Active DTCs will be present only on the SFD locked modules. The reason why the DTC is still present on that module is that you forgot cu SFD Lock the m
  • I think both sides of the argument have some validity.   Perhaps an addition to the first post by the OP stating that you should backup the configs before doing anything, you should understa
13 hours ago, Cairus said:
I don't have to prove anything to anyone here... furthermore, if you want others to work for you, share a complete ECU image of the car here
Tell us why you need a complete ECU image of the car? I am very very curious why you are requesting this. Furthermore sharing a complete ECU image is dangerous, one never knows in which hands it this car config details in the end ends up with... In other words > NO WAY!
Sure, you do not have to prove anything. Just be reminded that you made a huge fool of yourself here in this forum. You simply do not have the solution at hand for this Coming / Leaving Home question which you thought you would have, and are unwilling to admit / just pretending to know. Or in other words: Keeping up appearances, so to say.
Does anyone happen to know how to disable the warning message on the Infotainment screen and the removal of running video when driving? Passengers (my kids) would like to use the larger screen to watch some video content they bring on their USB-C key.
I’ve absolutely no idea why or what I was going on about with OBD11. Ignore - I’ll ask mods to delete.
It goes back to a previous post (on this thread?) about why VW do what they do. If they give people access to SFD1/2, then suddenly their dealers and expensive ODIS tools become surplus.
22 minutes ago, Cairus said:
I would strongly advise against using lighting apps. For example, Seat programs the light channels differently than Skoda. Enough users have destroyed their cars with this Apps
Yeah n have a look in the golf or Tiguan forums I did it in the Tiguan and its quite easy BUT in our country it is ILLEGAL TO HAVE A VIDEO RUNNING WHERE THE DRIVER CAN SEE IT CONCIOUSLY OR NOT. Mod is called VIM Video in motion
Thanks I'll take a look in those forums 👍
1 hour ago, SkodaOctaviaIV said:
Sagen Sie uns, warum Sie ein vollständiges ECU-Image des Fahrzeugs benötigen? Ich bin sehr, sehr neugierig, warum Sie das anfordern. Außerdem ist es gefährlich, ein vollständiges ECU-Image zu teilen, man weiß nie, in wessen Hände diese Fahrzeugkonfigurationsdetails letztendlich gelangen... Mit anderen Worten: AUF KEINEN FALL!
Klar, Sie müssen nichts beweisen. Denken Sie nur daran, dass Sie sich hier im Forum total blamiert haben. Sie haben einfach nicht die Lösung für diese Coming-/Leaving-Home-Frage parat, die Sie zu kennen glaubten, und wollen es nicht zugeben / tun nur so, als wüssten Sie es. Oder anders gesagt: Sie wahren sozusagen den Schein.
then leave it alone... for your information, never share or write your chassis number anywhere, because that's how you get the coding of the vehicle as it rolled out of the factory.
Found two solutions, one for the Tiguan and one for the latest golf model, both do unfortunately not work.
Try this, when you have a Tool for Flash Dataset
https://mega.nz/#P!AgEzq1SMFtJRso3LLKGMfif8ADglSZ7M55rATDrJlAAnKqjovN1v-NmQOaPpHYbWbUA8U_5tkXJ8FUf_0l9jeTrKQ36fWxORQiFydnEyb0C9AWjFc2e7_u5C9erQwWTW5PrrrZ3KGGw
Website is requesting a password? How to obtain such?
ask nicely and politely
Still completely in the Blue with this one (I cannot get it working to switch OFF the beamlights for Coming / Leaving Home)
Also tried 09 > Adaptations > Leuchte 6 ABL LC 5 - Tried to set from 'Parklicht Links' to 'not actve', but then I was presented the "(31) Function is not available" error. The same happened with the Leuchte 7 ABL RB 1 channel.
Looks like there are no channels in my Skoda Octavia to de-activate these dipped beams... Other option would be to set the low beams value to "0" for CH / LH, but where to find these in the adaptions menu?
Anyone please? I want to only have the front Fog Lights enabled for CH / LH, not together with the low beam lights.
Edited by SkodaOctaviaIV
Backup unit 9
44 minutes ago, Cairus said:
Backup unit 9
All units are in backup made in history already, that is step number 1 before any coding.
I can only think about changing option 'Dimmwert ABC 6' its value from '127' to '0' (for the left dipped beam light as example. That is, IF the car supports this change?
1 hour ago, Cairus said:
Backup-Einheit 9
57 minutes ago, Cairus said:
  2 hours ago, Cairus said:
Backup-Einheit 9
Like I wrote earlier, all cars modules are already present in backup.
Post Unit 9 here
Post Unit 9 here
Which section of 09 backup you wanted? Massive amount of text....
All light
39 minutes ago, Cairus said:
All light
All right here we go. One observation. At this moment the front Fog lights are not enabled for LH/CH (As it only currently adds the Fog lights, instead of replacing the dimmed headlights...)
Fernlicht_assistent:
Menuesteuerung Fernlichtassistent:
Present
Fernlichtassistent Reset:
active
Menuesteuerung Fernlichtassistent Werkseinstellung:
Present
Parking light:
Standlicht-Verfügbarkeit:
24 s
Bedingungen zur Standlichtbegrenzung:
Switch-off due to energy management
Bedingungen zur Parklichtbegrenzung:
Faktor fuer Verfuegbarkeitstimer:
Faktor fuer x5 Minuten
Standlichtreduzierung mit beidseitigem Parklicht:
active
Standlicht aus:
active
Parklicht ueber LSS aktiviert:
One-sided
Lichtwarnungsverhalten:
klemmenabhaengig
Daytime running lights:
Geschwindigkeitsabhaengiges TFL:
5 km/h
Speed warning active, rear fog lamps:
0 km/h
TFL_Abschaltung_ueber_Geschwindigkeit:
not active
Daytime running lights/parking light:
not active
Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
not active
Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht:
not active
Tagfahrlichtkontrollleuchte:
not active
Activation: daytime running lights:
Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge:
active
Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
not active
Tagfahrlicht nur in Schalterstellung AUTO:
active
Flashing function:
Fahrerassistenz_Blinkenfunktionen:
Warnblinke_zulaessig
Warnblinken_durch_Fahrerassistenz:
not active
Hupen_durch_Fahrerassistenz:
active
Travel Assist:
not active
Innenlicht_durch_Fahrerassistenz:
not active
Light function "Coming/Leaving Home":
Menuesteuerung Leaving-home Freischaltung per BAP:
active
Menuesteuerung Coming Home Werkseinstellung:
active
Coming Home Verbaustatus:
automatic
Menueeinstellung CHO LHO:
Menuesteuerung Zeit aktivieren
Leaving-Home Verbausstatus:
Enabled
Darstellung Coming-home Verlauf:
not active
Darstellung Leaving-home Verlauf:
not active
Lichtdrehschalter:
Light rotary switch with fog tail light:
Yes
Light rotary sw. with AFL:
Yes
Light rotary switch with park. light pos.:
Yes
Light rotary switch with fog light:
Yes
Light functions for special-purpose vehicle:
intermittent high beam:
High beam
intermittent low beam:
Low beam
Dynamic turn signal control:
Dynamische_Blink_Delay:
50 ms
Rear lid opening angle adaptation flashing:
active
Garage door opener adaptation flashing:
active
Confirmation flashing of the central locking system when locking:
active
Confirmation flashing of the central locking system when unlocking:
active
IPA_RPA_Blinkbestätugung:
active
Telematic blinking or blinking by positioning assistant:
active
DWA_Schaerfungsquittung:
active
Theft flashing:
active
Taxi alarm flashing:
active
Panic flashing:
not active
Emergency flashing:
not active
Multikollisions_blinken:
not active
Notwarn_blinken_NBA_Phase_2:
active
Emergency flashers in roll mode:
active
IPA_RPA_blinken_rechts:
active
IPA_RPA_blinken_links:
active
SWA_blinken_rechts:
active
SWA_blinken_links:
active
Richtungs_blinken_rechts:
active
Richtungs_blinken_links:
active
Crash flashing:
not active
Warnblinken_Zuendung_EIN:
active
Warnblinken_Zuendung_AUS:
active
BAP function status:
Helligkeitsschwelle Forward-Messung:
696 lx
Menueeinstellung Leaving-home Zeit per BAP:
10 seconds
Coming home Leuchten:
Low beam <<<<<<<<<<<<<<<<<<<<<<<<<<< When tried, was set to 'Fog Lights'.
Helligkeitsschwelle Infrarot-Messung:
800 lx
Menueeinstellung Cominghome:
10 seconds
Coming-home Einschaltereignis:
Driver door opened
Tagfahrlicht mit CHO bei Tag in Stellung AUTO:
not active
Tagfahrlicht mit LHO bei Tag in Stellung AUTO:
not active
Menueeinstellung Cominghome bei Tag:
10 seconds
Menueeinstellung Leaving-home bei Tag:
10 seconds
CHo_LHo_Nachlauf:
0 ms
Light sensor:
Einschaltgrenze_CHO_LHO:
0 lx
Daemmerungsgrenze, Hysterese_obergrenze:
0 lx
Daemmerungsgrenze_Hysterese_untergrenze:
0 lx
Helligkeitsgrenze_sehr_hell:
0 lx
Helligkeitsgrenze_Licht__einschalten:
0 lx
Helligkeitsgrenze_Licht_ausschalten:
0 lx
Minimale_Beleuchtungsstaerke:
0 lx
Maximale_Beleuchtungsstaerke:
0 lx
Minimale_Ausgangsspannung:
0 mV
Maximale_Ausgangsspannung:
0 mV
Tunnel_einschalt_verzoegerung:
0
ECE_Lichteinschaltschwelle:
0 lx
Helligkeitsgrenze_Licht_ausschalten_red:
0
HMI_Exterior_light_on_highway:
not active
HMI_exterior_light_sensitivity:
frueh
Special Function:
Blinkerueberwachug_Sonderfunktions_SG:
not installed
Special function 1:
not installed
Special Function 2:
not enabled
Licht Konfig-Abhängig:
Emergency brake display:
active
Signaturlicht HMI-default Anzeige im Kombiinstrument:
not active
Signaturlicht_verbaut:
not installed
Allwetterlicht:
not installed
Diskrete_SBBR_links:
not installed
Diskrete_SBBR_rechts:
not installed
After-run for park light:
No_sidelights_delay
Assistance light functions:
Assistenzfahrlicht bei Regen:
active
LS_Error_Ausgabe:
active
Lichtsensorempfindlichkeit:
normal
AFL Zeitverzoegerung:
500 ms
Maskierung_Regenlichtmenü:
not active
Will Beam assistant, responsivity adjustable via BAP:
Present
Aussenlicht-SG-Architektur:
Schlusslicht mit Bremslichtfunktion:
not active
Bremslicht_ist_auch_Blinklicht:
No
Lichthupe bei Zuendung aus moeglich:
not active
Zahl der aktiven Scheinwerfer auf 2 limitieren:
in Betrieb lassen
Abblendlicht_Leuchtentyp:
H7
Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht:
not active
Abschaltung Redundanzpfad Prüfung:
not active
Lichtfunktion_OL_Diagnose_LT55_1:
0
Lichtfunktion_OL_Diagnose_LT55_2:
0
Lichtfunktion_OL_Diagnose_LT55_3:
0
Lichtfunktion_OL_Diagnose_LT56_1:
0
Lichtfunktion_OL_Diagnose_LT56_2:
0
Lichtfunktion_OL_Diagnose_LT56_3:
0
Fahrlichthinweis:
Fahrlicht_Hinweis_mehrfach:
active
Fahrlichtwarnung_Hinweis_Konfig:
Hinweis_in_LDS-Stellung_Null_und_SL
Light_control:
Comfort flasher:
active
Abbruch Komfortblinken:
active
Light rotary sw. connection:
Data bus LIN 1
Comfort flasher set point:
3
Umgreifende_Heckklappe:
not installed
Parking lamp indicator lamp:
integriert in Suchbeleuchtung
bewusstes Standlicht:
Aktive Begrenzung
Umfeldleuchte als Manoevrierleuchte:
not active
PreCrash_RECAS:
active
Trailer turn signal indicator lamp:
individual
Leuchte 35 LED Warnblinktaster C60:
Lasttyp 35:
not_active
Lampendefektbitposition 35:
0
Fehlerort mittleres Byte DTC-DFCC 35:
0
Lichtfunktion A 35:
nicht aktiv
Lichtfunktion B 35:
nicht aktiv
Lichtfunktion C 35:
nicht aktiv
Dimmwert ABC 35:
0
Lichtansteuerung HD ABC 35:
always
Lichtfunktion D 35:
nicht aktiv
Lichtfunktion E 35:
nicht aktiv
Lichtfunktion F 35:
nicht aktiv
Dimmwert DEF 35:
0
Dimming Direction DEF 35:
maximize
Lichtfunktion G 35:
nicht aktiv
Lichtfunktion H 35:
nicht aktiv
Lichtfunktion I 35:
nicht aktiv
Dimmwert GHI 35:
0
Dimming Direction GHI 35:
maximize
Lichtfunktion J 35:
nicht aktiv
Lichtfunktion K 35:
nicht aktiv
Lichtfunktion L 35:
nicht aktiv
Dimmwert JKL 35:
0
Dimming Direction JKL 35:
maximize
Leuchte 16 BLK SL B42_C31:
Lasttyp 16:
LED_Tagfahrlicht_modul_Versorgung
Lampendefektbitposition 16:
38
Fehlerort mittleres Byte DTC-DFCC 16:
22
Lichtfunktion A 16:
Nebellicht links
Lichtfunktion B 16:
Abbiegelicht links
Lichtfunktion C 16:
nicht aktiv
Dimmwert ABC 16:
127 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< This to be set to value '0'?
Lichtansteuerung HD ABC 16:
always
Lichtfunktion D 16:
nicht aktiv
Lichtfunktion E 16:
nicht aktiv
Lichtfunktion F 16:
nicht aktiv
Dimmwert DEF 16:
0
Dimming Direction DEF 16:
maximize
Lichtfunktion G 16:
nicht aktiv
Lichtfunktion H 16:
nicht aktiv
Lichtfunktion I 16:
nicht aktiv
Dimmwert GHI 16:
0
Dimming Direction GHI 16:
maximize
Lichtfunktion J 16:
nicht aktiv
Lichtfunktion K 16:
nicht aktiv
Lichtfunktion L 16:
nicht aktiv
Dimmwert JKL 16:
0
Dimming Direction JKL 16:
maximize
Leuchte 17 BLK_SR B4_A61:
Lasttyp 17:
Lampendefektbitposition 17:
42
Fehlerort mittleres Byte DTC-DFCC 17:
23
Lichtfunktion A 17:
Nebellicht rechts
Lichtfunktion B 17:
Abbiegelicht rechts
Lichtfunktion C 17:
nicht aktiv
Dimmwert ABC 17:
Lichtansteuerung HD ABC 17:
always
Lichtfunktion D 17:
nicht aktiv
Lichtfunktion E 17:
nicht aktiv
Lichtfunktion F 17:
nicht aktiv
Dimmwert DEF 17:
0
Dimming Direction DEF 17:
maximize
Lichtfunktion G 17:
nicht aktiv
Lichtfunktion H 17:
nicht aktiv
Lichtfunktion I 17:
nicht aktiv
Dimmwert GHI 17:
0
Dimming Direction GHI 17:
maximize
Lichtfunktion J 17:
nicht aktiv
Lichtfunktion K 17:
nicht aktiv
Lichtfunktion L 17:
nicht aktiv
Dimmwert JKL 17:
0
Dimming Direction JKL 17:
maximize
Leuchte 18 BLK HL A60:
Lasttyp 18:
LED_Blinkleuchten_mit_Ueberspg_absch
Lampendefektbitposition 18:
8
Fehlerort mittleres Byte DTC-DFCC 18:
16
Lichtfunktion A 18:
Blinken links Hellphase
Lichtfunktion B 18:
Quittierungsfunktion1
Lichtfunktion C 18:
nicht aktiv
Dimmwert ABC 18:
127
Lichtansteuerung HD ABC 18:
always
Lichtfunktion D 18:
nicht aktiv
Lichtfunktion E 18:
nicht aktiv
Lichtfunktion F 18:
nicht aktiv
Dimmwert DEF 18:
0
Dimming Direction DEF 18:
maximize
Lichtfunktion G 18:
nicht aktiv
Lichtfunktion H 18:
nicht aktiv
Lichtfunktion I 18:
nicht aktiv
Dimmwert GHI 18:
0
Dimming Direction GHI 18:
maximize
Lichtfunktion J 18:
nicht aktiv
Lichtfunktion K 18:
nicht aktiv
Lichtfunktion L 18:
nicht aktiv
Dimmwert JKL 18:
0
Dimming Direction JKL 18:
maximize
Leuchte 19 BLK HR C27:
Lasttyp 19:
Lampendefektbitposition 19:
18
Fehlerort mittleres Byte DTC-DFCC 19:
18
Lichtfunktion A 19:
Blinken rechts Hellphase
Lichtfunktion B 19:
Lichtfunktion C 19:
nicht aktiv
Dimmwert ABC 19:
127
Lichtansteuerung HD ABC 19:
always
Lichtfunktion D 19:
nicht aktiv
Lichtfunktion E 19:
nicht aktiv
Lichtfunktion F 19:
nicht aktiv
Dimmwert DEF 19:
0
Dimming Direction DEF 19:
maximize
Lichtfunktion G 19:
nicht aktiv
Lichtfunktion H 19:
nicht aktiv
Lichtfunktion I 19:
nicht aktiv
Dimmwert GHI 19:
0
Dimming Direction GHI 19:
maximize
Lichtfunktion J 19:
nicht aktiv
Lichtfunktion K 19:
nicht aktiv
Lichtfunktion L 19:
nicht aktiv
Dimmwert JKL 19:
0
Dimming Direction JKL 19:
maximize
Leuchte 20 BR L A71:
Lasttyp 20:
LED_Bremsleuchten
Lampendefektbitposition 20:
9
Fehlerort mittleres Byte DTC-DFCC 20:
2b
Lichtfunktion A 20:
Bremslicht
Lichtfunktion B 20:
nicht aktiv
Lichtfunktion C 20:
nicht aktiv
Dimmwert ABC 20:
127
Lichtansteuerung HD ABC 20:
always
Lichtfunktion D 20:
nicht aktiv
Lichtfunktion E 20:
nicht aktiv
Lichtfunktion F 20:
nicht aktiv
Dimmwert DEF 20:
0
Dimming Direction DEF 20:
maximize
Lichtfunktion G 20:
nicht aktiv
Lichtfunktion H 20:
nicht aktiv
Lichtfunktion I 20:
nicht aktiv
Dimmwert GHI 20:
0
Dimming Direction GHI 20:
maximize
Lichtfunktion J 20:
nicht aktiv
Lichtfunktion K 20:
nicht aktiv
Lichtfunktion L 20:
nicht aktiv
Dimmwert JKL 20:
0
Dimming Direction JKL 20:
maximize
Leuchte 21 BR R C8:
Lasttyp 21:
LED_Bremsleuchten
Lampendefektbitposition 21:
19
Fehlerort mittleres Byte DTC-DFCC 21:
2d
Lichtfunktion A 21:
Bremslicht
Lichtfunktion B 21:
nicht aktiv
Lichtfunktion C 21:
nicht aktiv
Dimmwert ABC 21:
127
Lichtansteuerung HD ABC 21:
always
Lichtfunktion D 21:
nicht aktiv
Lichtfunktion E 21:
nicht aktiv
Lichtfunktion F 21:
nicht aktiv
Dimmwert DEF 21:
0
Dimming Direction DEF 21:
maximize
Lichtfunktion G 21:
nicht aktiv
Lichtfunktion H 21:
nicht aktiv
Lichtfunktion I 21:
nicht aktiv
Dimmwert GHI 21:
0
Dimming Direction GHI 21:
maximize
Lichtfunktion J 21:
nicht aktiv
Lichtfunktion K 21:
nicht aktiv
Lichtfunktion L 21:
nicht aktiv
Dimmwert JKL 21:
0
Dimming Direction JKL 21:
maximize
Leuchte 22 BR M A57:
Lasttyp 22:
LED_dritte_Bremsleuchte
Lampendefektbitposition 22:
29
Fehlerort mittleres Byte DTC-DFCC 22:
2c
Lichtfunktion A 22:
Bremslicht
Lichtfunktion B 22:
nicht aktiv
Lichtfunktion C 22:
nicht aktiv
Dimmwert ABC 22:
127
Lichtansteuerung HD ABC 22:
always
Lichtfunktion D 22:
nicht aktiv
Lichtfunktion E 22:
nicht aktiv
Lichtfunktion F 22:
nicht aktiv
Dimmwert DEF 22:
0
Dimming Direction DEF 22:
maximize
Lichtfunktion G 22:
nicht aktiv
Lichtfunktion H 22:
nicht aktiv
Lichtfunktion I 22:
nicht aktiv
Dimmwert GHI 22:
0
Dimming Direction GHI 22:
maximize
Lichtfunktion J 22:
nicht aktiv
Lichtfunktion K 22:
nicht aktiv
Lichtfunktion L 22:
nicht aktiv
Dimmwert JKL 22:
0
Dimming Direction JKL 22:
maximize
Leuchte 25 KZL H A59:
Lasttyp 25:
allg_LED_mit_Open_Load_Diagnose_ohne_PWM
Lampendefektbitposition 25:
28
Fehlerort mittleres Byte DTC-DFCC 25:
30
Lichtfunktion A 25:
Standlicht
Lichtfunktion B 25:
nicht aktiv
Lichtfunktion C 25:
nicht aktiv
Dimmwert ABC 25:
127
Lichtansteuerung HD ABC 25:
always
Lichtfunktion D 25:
nicht aktiv
Lichtfunktion E 25:
nicht aktiv
Lichtfunktion F25:
nicht aktiv
Dimmwert DEF 25:
0
Dimming Direction DEF 25:
maximize
Lichtfunktion G 25:
nicht aktiv
Lichtfunktion H 25:
nicht aktiv
Lichtfunktion I 25:
nicht aktiv
Dimmwert GHI 25:
0
Dimming Direction GHI 25:
maximize
Lichtfunktion J 25:
nicht aktiv
Lichtfunktion K 25:
nicht aktiv
Lichtfunktion L 25:
nicht aktiv
Dimmwert JKL 25:
0
Dimming Direction JKL 25:
maximize
Leuchte 27 NSL R C6:
Lasttyp 27:
not_active
Lampendefektbitposition 27:
0
Fehlerort mittleres Byte DTC-DFCC 27:
0
Lichtfunktion A 27:
nicht aktiv
Lichtfunktion B 27:
nicht aktiv
Lichtfunktion C 27:
nicht aktiv
Dimmwert ABC 27:
0
Lichtansteuerung HD ABC 27:
always
Lichtfunktion D 27:
nicht aktiv
Lichtfunktion E 27:
nicht aktiv
Lichtfunktion F 27:
nicht aktiv
Dimmwert DEF 27:
0
Dimming Direction DEF 27:
maximize
Lichtfunktion G 27:
nicht aktiv
Lichtfunktion H 27:
nicht aktiv
Lichtfunktion I 27:
nicht aktiv
Dimmwert GHI 27:
0
Dimming Direction GHI 27:
maximize
Lichtfunktion J 27:
nicht aktiv
Lichtfunktion K 27:
nicht aktiv
Lichtfunktion L 27:
nicht aktiv
Dimmwert JKL 27:
0
Dimming Direction JKL 27:
maximize
Leuchte 30 FR L C72:
Lasttyp 30:
not_active
Lampendefektbitposition 30:
0
Fehlerort mittleres Byte DTC-DFCC 30:
0
Lichtfunktion A 30:
nicht aktiv
Lichtfunktion B 30:
nicht aktiv
Lichtfunktion C 30:
nicht aktiv
Dimmwert ABC 30:
0
Lichtansteuerung HD ABC 30:
always
Lichtfunktion D 30:
nicht aktiv
Lichtfunktion E 30:
nicht aktiv
Lichtfunktion F 30:
nicht aktiv
Dimmwert DEF 30:
0
Dimming Direction DEF 30:
maximize
Lichtfunktion G 30:
nicht aktiv
Lichtfunktion H 30:
nicht aktiv
Lichtfunktion I 30:
nicht aktiv
Dimmwert GHI 30:
0
Dimming Direction GHI 30:
maximize
Lichtfunktion J 30:
nicht aktiv
Lichtfunktion K 30:
nicht aktiv
Lichtfunktion L 30:
nicht aktiv
Dimmwert JKL 30:
0
Dimming Direction JKL 30:
maximize
Leuchte 31 AMBL 1 C61:
Lasttyp 31:
LED_Kleinleistung_ohne_Open_Load_Diagnose
Lampendefektbitposition 31:
0
Fehlerort mittleres Byte DTC-DFCC 31:
66
Lichtfunktion A 31:
Ambientelicht 1
Lichtfunktion B 31:
nicht aktiv
Lichtfunktion C 31:
nicht aktiv
Dimmwert ABC 31:
100
Lichtansteuerung HD ABC 31:
always
Lichtfunktion D 31:
nicht aktiv
Lichtfunktion E 31:
nicht aktiv
Lichtfunktion F 31:
nicht aktiv
Dimmwert DEF 31:
0
Dimming Direction DEF 31:
maximize
Lichtfunktion G 31:
nicht aktiv
Lichtfunktion H 31:
nicht aktiv
Lichtfunktion I 31:
nicht aktiv
Dimmwert GHI 31:
0
Dimming Direction GHI 31:
maximize
Lichtfunktion J 31:
nicht aktiv
Lichtfunktion K 31:
nicht aktiv
Lichtfunktion L 31:
nicht aktiv
Dimmwert JKL 31:
0
Dimming Direction JKL 31:
maximize
Leuchte 33 AMBL 3 C36:
Lasttyp 33:
not_active
Lampendefektbitposition 33:
0
Fehlerort mittleres Byte DTC-DFCC 33:
0
Lichtfunktion A 33:
nicht aktiv
Lichtfunktion B 33:
nicht aktiv
Lichtfunktion C 33:
nicht aktiv
Dimmwert ABC 33:
0
Lichtansteuerung HD ABC 33:
always
Lichtfunktion D 33:
nicht aktiv
Lichtfunktion E 33:
nicht aktiv
Lichtfunktion F 33:
nicht aktiv
Dimmwert DEF 33:
0
Dimming Direction DEF 33:
maximize
Lichtfunktion G 33:
nicht aktiv
Lichtfunktion H 33:
nicht aktiv
Lichtfunktion I 33:
nicht aktiv
Dimmwert GHI 33:
0
Dimming Direction GHI 33:
maximize
Lichtfunktion J 33:
nicht aktiv
Lichtfunktion K 33:
nicht aktiv
Lichtfunktion L 33:
nicht aktiv
Dimmwert JKL 33:
0
Dimming Direction JKL 33:
maximize
Leuchte 34 AMBL 4 C37:
Lasttyp 34:
not_active
Lampendefektbitposition 34:
0
Fehlerort mittleres Byte DTC-DFCC 34:
0
Lichtfunktion A 34:
nicht aktiv
Lichtfunktion B 34:
nicht aktiv
Lichtfunktion C 34:
nicht aktiv
Dimmwert ABC 34:
0
Lichtansteuerung HD ABC 34:
always
Lichtfunktion D 34:
nicht aktiv
Lichtfunktion E 34:
nicht aktiv
Lichtfunktion F 34:
nicht aktiv
Dimmwert DEF 34:
0
Dimming Direction DEF 34:
maximize
Lichtfunktion G 34:
nicht aktiv
Lichtfunktion H 34:
nicht aktiv
Lichtfunktion I 34:
nicht aktiv
Dimmwert GHI 34:
0
Dimming Direction GHI 34:
maximize
Lichtfunktion J 34:
nicht aktiv
Lichtfunktion K 34:
nicht aktiv
Lichtfunktion L 34:
nicht aktiv
Dimmwert JKL 34:
0
Dimming Direction JKL 34:
maximize
Leuchte 39 Sidemarker_H C26:
Lasttyp 39:
not_active
Lampendefektbitposition 39:
0
Fehlerort mittleres Byte DTC-DFCC 39:
0
Lichtfunktion A 39:
nicht aktiv
Lichtfunktion B 39:
nicht aktiv
Lichtfunktion C 39:
nicht aktiv
Dimmwert ABC 39:
0
Lichtansteuerung HD ABC 39:
always
Lichtfunktion D 39:
nicht aktiv
Lichtfunktion E 39:
nicht aktiv
Lichtfunktion F 39:
nicht aktiv
Dimmwert DEF 39:
0
Dimming Direction DEF 39:
maximize
Lichtfunktion G 39:
nicht aktiv
Lichtfunktion H 39:
nicht aktiv
Lichtfunktion I 39:
nicht aktiv
Dimmwert GHI 39:
0
Dimming Direction GHI 39:
maximize
Lichtfunktion J 39:
nicht aktiv
Lichtfunktion K 39:
nicht aktiv
Lichtfunktion L 39:
nicht aktiv
Dimmwert JKL 39:
0
Dimming Direction JKL 39:
maximize
Leuchte 43 Wischblinksignal_re C33_B36:
Lasttyp 43:
not_active
Lampendefektbitposition 43:
0
Fehlerort mittleres Byte DTC-DFCC 43:
0
Lichtfunktion A 43:
nicht aktiv
Lichtfunktion B 43:
nicht aktiv
Lichtfunktion C 43:
nicht aktiv
Dimmwert ABC 43:
0
Lichtansteuerung HD ABC 43:
always
Lichtfunktion D 43:
nicht aktiv
Lichtfunktion E 43:
nicht aktiv
Lichtfunktion F 43:
nicht aktiv
Dimmwert DEF 43:
0
Dimming Direction DEF 43:
maximize
Lichtfunktion G 43:
nicht aktiv
Lichtfunktion H 43:
nicht aktiv
Lichtfunktion I 43:
nicht aktiv
Dimmwert GHI 43:
0
Dimming Direction GHI 43:
maximize
Lichtfunktion J 43:
nicht aktiv
Lichtfunktion K 43:
nicht aktiv
Lichtfunktion L 43:
nicht aktiv
Dimmwert JKL 43:
0
Dimming Direction JKL 43:
maximize
Leuchte 42 Wischblinksignal_li C30_B35:
Lasttyp 42:
not_active
Lampendefektbitposition 42:
0
Fehlerort mittleres Byte DTC-DFCC 42:
0
Lichtfunktion A 42:
nicht aktiv
Lichtfunktion B 42:
nicht aktiv
Lichtfunktion C 42:
nicht aktiv
Dimmwert ABC 42:
0
Lichtansteuerung HD ABC 42:
always
Lichtfunktion D 42:
nicht aktiv
Lichtfunktion E 42:
nicht aktiv
Lichtfunktion F 42:
nicht aktiv
Dimmwert DEF 42:
0
Dimming Direction DEF 42:
maximize
Lichtfunktion G 42:
nicht aktiv
Lichtfunktion H 42:
nicht aktiv
Lichtfunktion I 42:
nicht aktiv
Dimmwert GHI 42:
0
Dimming Direction GHI 42:
maximize
Lichtfunktion J 42:
nicht aktiv
Lichtfunktion K 42:
nicht aktiv
Lichtfunktion L 42:
nicht aktiv
Dimmwert JKL 42:
0
Dimming Direction JKL 42:
maximize
Leuchte 45 C61:
Lasttyp 45:
allgemeine_Gluehlampe_27W_auch_H15_TFL
Lampendefektbitposition 45:
0
Fehlerort mittleres Byte DTC-DFCC 45:
0
Lichtfunktion A 45:
Kofferraumlicht
Lichtfunktion B 45:
nicht aktiv
Lichtfunktion C 45:
nicht aktiv
Dimmwert ABC 45:
100
Lichtansteuerung HD ABC 45:
always
Lichtfunktion D 45:
nicht aktiv
Lichtfunktion E 45:
nicht aktiv
Lichtfunktion F 45:
nicht aktiv
Dimmwert DEF 45:
0
Dimming Direction DEF 45:
maximize
Lichtfunktion G 45:
nicht aktiv
Lichtfunktion H 45:
nicht aktiv
Lichtfunktion I 45:
nicht aktiv
Dimmwert GHI 45:
0
Dimming Direction GHI 45:
maximize
Lichtfunktion J 45:
nicht aktiv
Lichtfunktion K 45:
nicht aktiv
Lichtfunktion L 45:
nicht aktiv
Dimmwert JKL 45:
0
Dimming Direction JKL 45:
maximize
Leuchte 44 ALV C70:
Lasttyp 44:
LED Lichtmodul ohne Open Load Diagnose
Lampendefektbitposition 44:
0
Fehlerort mittleres Byte DTC-DFCC 44:
85
Lichtfunktion A 44:
Ambientelichtmodul Versorgung
Lichtfunktion B 44:
aktiv100prozent
Lichtfunktion C 44:
nicht aktiv
Dimmwert ABC 44:
127
Lichtansteuerung HD ABC 44:
always
Lichtfunktion D 44:
nicht aktiv
Lichtfunktion E 44:
nicht aktiv
Lichtfunktion F 44:
nicht aktiv
Dimmwert DEF 44:
0
Dimming Direction DEF 44:
maximize
Lichtfunktion G 44:
nicht aktiv
Lichtfunktion H 44:
nicht aktiv
Lichtfunktion I 44:
nicht aktiv
Dimmwert GHI 44:
0
Dimming Direction GHI 44:
maximize
Lichtfunktion J 44:
nicht aktiv
Lichtfunktion K 44:
nicht aktiv
Lichtfunktion L 44:
nicht aktiv
Dimmwert JKL 44:
0
Dimming Direction JKL 44:
maximize
Leuchte 32 AMBL 2 C35:
Lasttyp 32:
not_active
Lampendefektbitposition 32:
0
Fehlerort mittleres Byte DTC-DFCC 32:
0
Lichtfunktion A 32:
nicht aktiv
Lichtfunktion B 32:
nicht aktiv
Lichtfunktion C 32:
nicht aktiv
Dimmwert ABC 32:
0
Lichtansteuerung HD ABC 32:
always
Lichtfunktion D 32:
nicht aktiv
Lichtfunktion E 32:
nicht aktiv
Lichtfunktion F 32:
nicht aktiv
Dimmwert DEF 32:
0
Dimming Direction DEF 32:
maximize
Lichtfunktion G 32:
nicht aktiv
Lichtfunktion H 32:
nicht aktiv
Lichtfunktion I 32:
nicht aktiv
Dimmwert GHI 32:
0
Dimming Direction GHI 32:
maximize
Lichtfunktion J 32:
nicht aktiv
Lichtfunktion K 32:
nicht aktiv
Lichtfunktion L 32:
nicht aktiv
Dimmwert JKL 32:
0
Dimming Direction JKL 32:
maximize
Leuchte 0 BLK VL B24:
Lasttyp_0:
not_active
Lampendefektbit Position 0:
0
Fehlerort mittleres Byte DTC-DFCC 0:
0
Lichtfunktion A 0:
nicht aktiv
Lichtfunktion B 0:
nicht aktiv
Lichtfunktion C 0:
nicht aktiv
Dimmwert ABC 0:
0
Lichtansteuerung HD ABC 0:
always
Lichtfunktion D 0:
nicht aktiv
Lichtfunktion E 0:
nicht aktiv
Lichtfunktion F 0:
nicht aktiv
Dimmwert DEF 0:
0
Dimming Direction DEF 0:
maximize
Lichtfunktion G 0:
nicht aktiv
Lichtfunktion H 0:
nicht aktiv
Lichtfunktion I 0:
nicht aktiv
Dimmwert GHI 0:
0
Dimming Direction GHI 0:
maximize
Lichtfunktion J 0:
nicht aktiv
Lichtfunktion K 0:
nicht aktiv
Lichtfunktion L 0:
nicht aktiv
Dimmwert JKL 0:
0
Dimming Direction JKL 0:
maximize
Leuchte 1 BLK VR B9:
Lasttyp 1:
not_active
Lampendefektbitposition 1:
0
Fehlerort mittleres Byte DTC-DFCC 1:
0
Lichtfunktion A 1:
nicht aktiv
Lichtfunktion B 1:
nicht aktiv
Lichtfunktion C 1:
nicht aktiv
Dimmwert ABC 1:
0
Lichtansteuerung HD ABC 1:
always
Lichtfunktion D 1:
nicht aktiv
Lichtfunktion E 1:
nicht aktiv
Lichtfunktion F 1:
nicht aktiv
Dimmwert DEF 1:
0
Dimming Direction DEF 1:
maximize
Lichtfunktion G 1:
nicht aktiv
Lichtfunktion H 1:
nicht aktiv
Lichtfunktion I 1:
nicht aktiv
Dimmwert GHI 1:
0
Dimming Direction GHI 1:
maximize
Lichtfunktion J 1:
nicht aktiv
Lichtfunktion K 1:
nicht aktiv
Lichtfunktion L 1:
nicht aktiv
Dimmwert JKL 1:
0
Dimming Direction JKL 1:
maximize
Leuchte 2 SL VL B20:
Lasttyp 2:
not_active
Lampendefektbitposition 2:
0
Fehlerort mittleres Byte DTC-DFCC 2:
0
Lichtfunktion A 2:
nicht aktiv
Lichtfunktion B 2:
nicht aktiv
Lichtfunktion C 2:
nicht aktiv
Dimmwert ABC 2:
0
Lichtansteuerung HD ABC 2:
always
Lichtfunktion D 2:
nicht aktiv
Lichtfunktion E 2:
nicht aktiv
Lichtfunktion F 2:
nicht aktiv
Dimmwert DEF 2:
0
Dimming Direction DEF 2:
maximize
Lichtfunktion G 2:
nicht aktiv
Lichtfunktion H 2:
nicht aktiv
Lichtfunktion I 2:
nicht aktiv
Dimmwert GHI 2:
0
Dimming Direction GHI 2:
maximize
Lichtfunktion J 2:
nicht aktiv
Lichtfunktion K 2:
nicht aktiv
Lichtfunktion L 2:
nicht aktiv
Dimmwert JKL 2:
0
Dimming Direction JKL 2:
maximize
Leuchte 3 SL VR B32:
Lasttyp 3:
not_active
Lampendefektbitposition 3:
0
Fehlerort mittleres Byte DTC-DFCC 3:
0
Lichtfunktion A 3:
nicht aktiv
Lichtfunktion B 3:
nicht aktiv
Lichtfunktion C 3:
nicht aktiv
Dimmwert ABC 3:
0
Lichtansteuerung HD ABC 3:
always
Lichtfunktion D 3:
nicht aktiv
Lichtfunktion E 3:
nicht aktiv
Lichtfunktion F 3:
nicht aktiv
Dimmwert DEF 3:
0
Dimming Direction DEF 3:
maximize
Lichtfunktion G 3:
nicht aktiv
Lichtfunktion H 3:
nicht aktiv
Lichtfunktion I 3:
nicht aktiv
Dimmwert GHI 3:
0
Dimming Direction GHI 3:
maximize
Lichtfunktion J 3:
nicht aktiv
Lichtfunktion K 3:
nicht aktiv
Lichtfunktion L 3:
nicht aktiv
Dimmwert JKL 3:
0
Dimming Direction JKL 3:
maximize
Leuchte 4 TFL L B3:
Lasttyp 4:
not_active
Lampendefektbitposition 4:
0
Fehlerort mittleres Byte DTC-DFCC 4:
0
Lichtfunktion A 4:
nicht aktiv
Lichtfunktion B 4:
nicht aktiv
Lichtfunktion C 4:
nicht aktiv
Dimmwert ABC 4:
0
Lichtansteuerung HD ABC 4:
always
Lichtfunktion D 4:
nicht aktiv
Lichtfunktion E 4:
nicht aktiv
Lichtfunktion F 4:
nicht aktiv
Dimmwert DEF 4:
0
Dimming Direction DEF 4:
maximize
Lichtfunktion G 4:
nicht aktiv
Lichtfunktion H 4:
nicht aktiv
Lichtfunktion I 4:
nicht aktiv
Dimmwert GHI 4:
0
Dimming Direction GHI 4:
maximize
Lichtfunktion J 4:
nicht aktiv
Lichtfunktion K 4:
nicht aktiv
Lichtfunktion L 4:
nicht aktiv
Dimmwert JKL 4:
0
Dimming Direction JKL 4:
maximize
Leuchte 5 TFL R B4:
Lasttyp 5:
not_active
Lampendefektbitposition 5:
0
Fehlerort mittleres Byte DTC-DFCC 5:
0
Lichtfunktion A 5:
nicht aktiv
Lichtfunktion B 5:
nicht aktiv
Lichtfunktion C 5:
nicht aktiv
Dimmwert ABC 5:
0
Lichtansteuerung HD ABC 5:
always
Lichtfunktion D 5:
nicht aktiv
Lichtfunktion E 5:
nicht aktiv
Lichtfunktion F 5:
nicht aktiv
Dimmwert DEF 5:
0
Dimming Direction DEF 5:
maximize
Lichtfunktion G 5:
nicht aktiv
Lichtfunktion H 5:
nicht aktiv
Lichtfunktion I 5:
nicht aktiv
Dimmwert GHI 5:
0
Dimming Direction GHI 5:
maximize
Lichtfunktion J 5:
nicht aktiv
Lichtfunktion K 5:
nicht aktiv
Lichtfunktion L 5:
nicht aktiv
Dimmwert JKL 5:
0
Dimming Direction JKL 5:
maximize
Leuchte 6 ABL L C5:
Lasttyp 6:
LED_LeiMo_Signal
Lampendefektbitposition 6:
36
Fehlerort mittleres Byte DTC-DFCC 6:
1a
Lichtfunktion A 6:
LED-Leistungsmodul Versorgung
Lichtfunktion B 6:
Standlicht
Lichtfunktion C 6:
Parklicht links
Dimmwert ABC 6:
127
Lichtansteuerung HD ABC 6:
always
Lichtfunktion D 6:
nicht aktiv
Lichtfunktion E 6:
nicht aktiv
Lichtfunktion F 6:
nicht aktiv
Dimmwert DEF 6:
0
Dimming Direction DEF 6:
maximize
Lichtfunktion G 6:
nicht aktiv
Lichtfunktion H 6:
nicht aktiv
Lichtfunktion I 6:
nicht aktiv
Dimmwert GHI 6:
0
Dimming Direction GHI 6:
maximize
Lichtfunktion J 6:
nicht aktiv
Lichtfunktion K 6:
nicht aktiv
Lichtfunktion L 6:
nicht aktiv
Dimmwert JKL 6:
0
Dimming Direction JKL 6:
maximize
Leuchte 7 ABL R B1:
Lasttyp 7:
LED_LeiMo_Signal
Lampendefektbitposition 7:
40
Fehlerort mittleres Byte DTC-DFCC 7:
1b
Lichtfunktion A 7:
Lichtfunktion B 7:
Standlicht
Lichtfunktion C 7:
Parklicht rechts
Dimmwert ABC 7:
127
Lichtansteuerung HD ABC 7:
always
Lichtfunktion D 7:
nicht aktiv
Lichtfunktion E 7:
nicht aktiv
Lichtfunktion F 7:
nicht aktiv
Dimmwert DEF 7:
0
Dimming Direction DEF 7:
maximize
Lichtfunktion G 7:
nicht aktiv
Lichtfunktion H 7:
nicht aktiv
Lichtfunktion I 7:
nicht aktiv
Dimmwert GHI 7:
0
Dimming Direction GHI 7:
maximize
Lichtfunktion J 7:
nicht aktiv
Lichtfunktion K 7:
nicht aktiv
Lichtfunktion L 7:
nicht aktiv
Dimmwert JKL 7:
0
Dimming Direction JKL 7:
maximize
Leuchte 8 FL L B39:
Lasttyp 8:
not_active
Lampendefektbitposition 8:
0
Fehlerort mittleres Byte DTC-DFCC 8:
0
Lichtfunktion A 8:
nicht aktiv
Lichtfunktion B 8:
nicht aktiv
Lichtfunktion C 8:
nicht aktiv
Dimmwert ABC 8:
0
Lichtansteuerung HD ABC 8:
always
Lichtfunktion D 8:
nicht aktiv
Lichtfunktion E 8:
nicht aktiv
Lichtfunktion F 8:
nicht aktiv
Dimmwert DEF 8:
0
Dimming Direction DEF 8:
maximize
Lichtfunktion G 8:
nicht aktiv
Lichtfunktion H 8:
nicht aktiv
Lichtfunktion I 8:
nicht aktiv
Dimmwert GHI 8:
0
Dimming Direction GHI 8:
maximize
Lichtfunktion J 8:
nicht aktiv
Lichtfunktion K 8:
nicht aktiv
Lichtfunktion L 8:
nicht aktiv
Dimmwert JKL 8:
0
Dimming Direction JKL 8:
maximize
Leuchte 9 FL R B2:
Lasttyp 9:
not_active
Lampendefektbitposition 9:
0
Fehlerort mittleres Byte DTC-DFCC 9:
0
Lichtfunktion A 9:
nicht aktiv
Lichtfunktion B 9:
nicht aktiv
Lichtfunktion C 9:
nicht aktiv
Dimmwert ABC 9:
0
Lichtansteuerung HD ABC 9:
always
Lichtfunktion D 9:
nicht aktiv
Lichtfunktion E 9:
nicht aktiv
Lichtfunktion F 9:
nicht aktiv
Dimmwert DEF 9:
0
Dimming Direction DEF 9:
maximize
Lichtfunktion G 9:
nicht aktiv
Lichtfunktion H 9:
nicht aktiv
Lichtfunktion I 9:
nicht aktiv
Dimmwert GHI 9:
0
Dimming Direction GHI 9:
maximize
Lichtfunktion J 9:
nicht aktiv
Lichtfunktion K 9:
nicht aktiv
Lichtfunktion L 9:
nicht aktiv
Dimmwert JKL 9:
0
Dimming Direction JKL 9:
maximize
Leuchte 10 SHUTTER L B23:
Lasttyp 10:
not_active
Lampendefektbitposition 10:
0
Fehlerort mittleres Byte DTC-DFCC 10:
0
Lichtfunktion A 10:
nicht aktiv
Lichtfunktion B 10:
nicht aktiv
Lichtfunktion C 10:
nicht aktiv
Dimmwert ABC 10:
0
Lichtansteuerung HD ABC 10:
always
Lichtfunktion D 10:
nicht aktiv
Lichtfunktion E 10:
nicht aktiv
Lichtfunktion F 10:
nicht aktiv
Dimmwert DEF 10:
0
Dimming Direction DEF 10:
maximize
Lichtfunktion G 10:
nicht aktiv
Lichtfunktion H 10:
nicht aktiv
Lichtfunktion I 10:
nicht aktiv
Dimmwert GHI 10:
0
Dimming Direction GHI 10:
maximize
Lichtfunktion J 10:
nicht aktiv
Lichtfunktion K 10:
nicht aktiv
Lichtfunktion L 10:
nicht aktiv
Dimmwert JKL 10:
0
Dimming Direction JKL 10:
maximize
Leuchte 11 SHUTTER R B22:
Lasttyp 11:
not_active
Lampendefektbitposition 11:
0
Fehlerort mittleres Byte DTC-DFCC 11:
0
Lichtfunktion A 11:
nicht aktiv
Lichtfunktion B 11:
nicht aktiv
Lichtfunktion C 11:
nicht aktiv
Dimmwert ABC 11:
0
Lichtansteuerung HD ABC 11:
always
Lichtfunktion D 11:
nicht aktiv
Lichtfunktion E 11:
nicht aktiv
Lichtfunktion F 11:
nicht aktiv
Dimmwert DEF 11:
0
Dimming Direction DEF 11:
maximize
Lichtfunktion G 11:
nicht aktiv
Lichtfunktion H 11:
nicht aktiv
Lichtfunktion I 11:
nicht aktiv
Dimmwert GHI 11:
0
Dimming Direction GHI 11:
maximize
Lichtfunktion J 11:
nicht aktiv
Lichtfunktion K 11:
nicht aktiv
Lichtfunktion L 11:
nicht aktiv
Dimmwert JKL 11:
0
Dimming Direction JKL 11:
maximize
Leuchte 12 NL L B45:
Lasttyp 12:
LED_Tagfahrlicht_modul_Signal
Lampendefektbitposition 12:
38
Fehlerort mittleres Byte DTC-DFCC 12:
24
Lichtfunktion A 12:
Nebellicht links
Lichtfunktion B 12:
Abbiegelicht links
Lichtfunktion C 12:
nicht aktiv
Dimmwert ABC 12:
100
Lichtansteuerung HD ABC 12:
always
Lichtfunktion D 12:
nicht aktiv
Lichtfunktion E 12:
nicht aktiv
Lichtfunktion F 12:
nicht aktiv
Dimmwert DEF 12:
0
Dimming Direction DEF 12:
maximize
Lichtfunktion G 12:
nicht aktiv
Lichtfunktion H 12:
nicht aktiv
Lichtfunktion I 12:
nicht aktiv
Dimmwert GHI 12:
0
Dimming Direction GHI 12:
maximize
Lichtfunktion J 12:
nicht aktiv
Lichtfunktion K 12:
nicht aktiv
Lichtfunktion L 12:
nicht aktiv
Dimmwert JKL 12:
0
Dimming Direction JKL 12:
maximize
Leuchte 13 NL R B5:
Lasttyp 13:
Lampendefektbitposition 13:
42
Fehlerort mittleres Byte DTC-DFCC 13:
25
Lichtfunktion A 13:
Nebellicht rechts
Lichtfunktion B 13:
Abbiegelicht rechts
Lichtfunktion C 13:
nicht aktiv
Dimmwert ABC 13:
100
Lichtansteuerung HD ABC 13:
always
Lichtfunktion D 13:
nicht aktiv
Lichtfunktion E 13:
nicht aktiv
Lichtfunktion F 13:
nicht aktiv
Dimmwert DEF 13:
0
Dimming Direction DEF 13:
maximize
Lichtfunktion G 13:
nicht aktiv
Lichtfunktion H 13:
nicht aktiv
Lichtfunktion I 13:
nicht aktiv
Dimmwert GHI 13:
0
Dimming Direction GHI 13:
maximize
Lichtfunktion J 13:
nicht aktiv
Lichtfunktion K 13:
nicht aktiv
Lichtfunktion L 13:
nicht aktiv
Dimmwert JKL 13:
0
Dimming Direction JKL 13:
maximize
Leuchte 23 SL HL C10:
Lasttyp 32:
LIN_SBBR_Versorgung_OL_Appl_55
11
29
Lichtfunktion A 32:
LED-Heckleuchte Versorgung
Lichtfunktion B 32:
nicht aktiv
Lichtfunktion C 32:
nicht aktiv
Dimmwert ABC 32:
127
always
Lichtfunktion D 32:
nicht aktiv
Lichtfunktion E 32:
nicht aktiv
Lichtfunktion F 32:
nicht aktiv
Dimmwert DEF 32:
0
maximize
Lichtfunktion G 32:
nicht aktiv
Lichtfunktion H 32:
nicht aktiv
Lichtfunktion I 32:
nicht aktiv
Dimmwert GHI 32:
0
maximize
Lichtfunktion J 32:
nicht aktiv
Lichtfunktion K 32:
nicht aktiv
Lichtfunktion L 32:
nicht aktiv
Dimmwert JKL 32:
0
maximize
Leuchte 24 SL HR A65:
Lasttyp 24:
Lampendefektbitposition 24:
21
Fehlerort mittleres Byte DTC-DFCC 24:
2a
Lichtfunktion A 24:
Lichtfunktion B 24:
nicht aktiv
Lichtfunktion C 24:
nicht aktiv
Dimmwert ABC 24:
127
Lichtansteuerung HD ABC 24:
always
Lichtfunktion D 24:
nicht aktiv
Lichtfunktion E 24:
nicht aktiv
Lichtfunktion F 24:
nicht aktiv
Dimmwert DEF 24:
0
Dimming Direction DEF 24:
maximize
Lichtfunktion G 24:
nicht aktiv
Lichtfunktion H 24:
nicht aktiv
Lichtfunktion I 24:
nicht aktiv
Dimmwert GHI 24:
0
Dimming Direction GHI 24:
maximize
Lichtfunktion J 24:
nicht aktiv
Lichtfunktion K 24:
nicht aktiv
Lichtfunktion L 24:
nicht aktiv
Dimmwert JKL 24:
0
Dimming Direction JKL 24:
maximize
Leuchte 28 RFL L C11:
Lasttyp 28:
not_active
Lampendefektbitposition 28:
0
Fehlerort mittleres Byte DTC-DFCC 28:
0
Lichtfunktion A 28:
nicht aktiv
Lichtfunktion B 28:
nicht aktiv
Lichtfunktion C 28:
nicht aktiv
Dimmwert ABC 28:
0
Lichtansteuerung HD ABC 28:
always
Lichtfunktion D 28:
nicht aktiv
Lichtfunktion E 28:
nicht aktiv
Lichtfunktion F 28:
nicht aktiv
Dimmwert DEF 28:
0
Dimming Direction DEF 28:
maximize
Lichtfunktion G 28:
nicht aktiv
Lichtfunktion H 28:
nicht aktiv
Lichtfunktion I 28:
nicht aktiv
Dimmwert GHI 28:
0
Dimming Direction GHI 28:
maximize
Lichtfunktion J 28:
nicht aktiv
Lichtfunktion K 28:
nicht aktiv
Lichtfunktion L 28:
nicht aktiv
Dimmwert JKL 28:
0
Dimming Direction JKL 28:
maximize
Leuchte 29 RFL R A64:
Lasttyp 29:
Lampendefektbitposition 29:
0
Fehlerort mittleres Byte DTC-DFCC 29:
31
Lichtfunktion A 29:
Rueckfahrlicht
Lichtfunktion B 29:
nicht aktiv
Lichtfunktion C 29:
nicht aktiv
Dimmwert ABC 29:
127
Lichtansteuerung HD ABC 29:
always
Lichtfunktion D 29:
nicht aktiv
Lichtfunktion E 29:
nicht aktiv
Lichtfunktion F 29:
nicht aktiv
Dimmwert DEF 29:
0
Dimming Direction DEF 29:
maximize
Lichtfunktion G 29:
nicht aktiv
Lichtfunktion H 29:
nicht aktiv
Lichtfunktion I 29:
nicht aktiv
Dimmwert GHI 29:
0
Dimming Direction GHI 29:
maximize
Lichtfunktion J 29:
nicht aktiv
Lichtfunktion K 29:
nicht aktiv
Lichtfunktion L 29:
nicht aktiv
Dimmwert JKL 29:
0
Dimming Direction JKL 29:
maximize
Leuchte 36 LEDNL_PWM_L_B37:
Lasttyp 36:
not_active
Lampendefektbitposition 36:
0
Fehlerort mittleres Byte DTC-DFCC 36:
0
Lichtfunktion A 36:
nicht aktiv
Lichtfunktion B 36:
nicht aktiv
Lichtfunktion C 36:
nicht aktiv
Dimmwert ABC 36:
0
Lichtansteuerung HD ABC 36:
always
Lichtfunktion D 36:
nicht aktiv
Lichtfunktion E 36:
nicht aktiv
Lichtfunktion F 36:
nicht aktiv
Dimmwert DEF 36:
0
Dimming Direction DEF 36:
maximize
Lichtfunktion G 36:
nicht aktiv
Lichtfunktion H 36:
nicht aktiv
Lichtfunktion I 36:
nicht aktiv
Dimmwert GHI 36:
0
Dimming Direction GHI 36:
maximize
Lichtfunktion J 36:
nicht aktiv
Lichtfunktion K 36:
nicht aktiv
Lichtfunktion L 36:
nicht aktiv
Dimmwert JKL 36:
0
Dimming Direction JKL 36:
maximize
Leuchte 37 LEDNL_PWM_R_B38:
Lasttyp 37:
not_active
Lampendefektbitposition 37:
0
Fehlerort mittleres Byte DTC-DFCC 37:
0
Lichtfunktion A 37:
nicht aktiv
Lichtfunktion B 37:
nicht aktiv
Lichtfunktion C 37:
nicht aktiv
Dimmwert ABC 37:
0
Lichtansteuerung HD ABC 37:
always
Lichtfunktion D 37:
nicht aktiv
Lichtfunktion E 37:
nicht aktiv
Lichtfunktion F 37:
nicht aktiv
Dimmwert DEF 37:
0
Dimming Direction DEF 37:
maximize
Lichtfunktion G 37:
nicht aktiv
Lichtfunktion H 37:
nicht aktiv
Lichtfunktion I 37:
nicht aktiv
Dimmwert GHI 37:
0
Dimming Direction GHI 37:
maximize
Lichtfunktion J 37:
nicht aktiv
Lichtfunktion K 37:
nicht aktiv
Lichtfunktion L 37:
nicht aktiv
Dimmwert JKL 37:
0
Dimming Direction JKL 37:
maximize
Leuchte 38 Sidemarker_V_B21:
Lasttyp 38:
not_active
Lampendefektbitposition 38:
0
Fehlerort mittleres Byte DTC-DFCC 38:
0
Lichtfunktion A 38:
nicht aktiv
Lichtfunktion B 38:
nicht aktiv
Lichtfunktion C 38:
nicht aktiv
Dimmwert ABC 38:
0
Lichtansteuerung HD ABC 38:
always
Lichtfunktion D 38:
nicht aktiv
Lichtfunktion E 38:
nicht aktiv
Lichtfunktion F 38:
nicht aktiv
Dimmwert DEF 38:
0
Dimming Direction DEF 38:
maximize
Lichtfunktion G 38:
nicht aktiv
Lichtfunktion H 38:
nicht aktiv
Lichtfunktion I 38:
nicht aktiv
Dimmwert GHI 38:
0
Dimming Direction GHI 38:
maximize
Lichtfunktion J 38:
nicht aktiv
Lichtfunktion K 38:
nicht aktiv
Lichtfunktion L 38:
nicht aktiv
Dimmwert JKL 38:
0
Dimming Direction JKL 38:
maximize
Leuchte 41 Zusatz_hecklicht_HR A67:
Lasttyp 41:
not_active
Lampendefektbitposition 41:
0
Fehlerort mittleres Byte DTC-DFCC 41:
0
Lichtfunktion A 41:
nicht aktiv
Lichtfunktion B 41:
nicht aktiv
Lichtfunktion C 41:
nicht aktiv
Dimmwert ABC 41:
0
Lichtansteuerung HD ABC 41:
always
Lichtfunktion D 41:
nicht aktiv
Lichtfunktion E 41:
nicht aktiv
Lichtfunktion F 41:
nicht aktiv
Dimmwert DEF 41:
0
Dimming Direction DEF 41:
maximize
Lichtfunktion G 41:
nicht aktiv
Lichtfunktion H 41:
nicht aktiv
Lichtfunktion I 41:
nicht aktiv
Dimmwert GHI 41:
0
Dimming Direction GHI 41:
maximize
Lichtfunktion J 41:
nicht aktiv
Lichtfunktion K 41:
nicht aktiv
Lichtfunktion L 41:
nicht aktiv
Dimmwert JKL 41:
0
Dimming Direction JKL 41:
maximize
Leuchte 40 Zusatz_hecklicht_HL C9:
Lasttyp 40:
not_active
Lampendefektbitposition 40:
0
Fehlerort mittleres Byte DTC-DFCC 40:
0
Lichtfunktion A 40:
nicht aktiv
Lichtfunktion B 40:
nicht aktiv
Lichtfunktion C 40:
nicht aktiv
Dimmwert ABC 40:
0
Lichtansteuerung HD ABC 40:
always
Lichtfunktion D 40:
nicht aktiv
Lichtfunktion E 40:
nicht aktiv
Lichtfunktion F 40:
nicht aktiv
Dimmwert DEF 40:
0
Dimming Direction DEF 40:
maximize
Lichtfunktion G 40:
nicht aktiv
Lichtfunktion H 40:
nicht aktiv
Lichtfunktion I 40:
nicht aktiv
Dimmwert GHI 40:
0
Dimming Direction GHI v:
maximize
Lichtfunktion J 40:
nicht aktiv
Lichtfunktion K 40:
nicht aktiv
Lichtfunktion L 40:
nicht aktiv
Dimmwert JKL 40:
0
Dimming Direction JKL 40:
maximize
Leuchte 26 NSL L A72:
Lasttyp 26:
not_active
Lampendefektbitposition 26:
0
Fehlerort mittleres Byte DTC-DFCC 26:
0
Lichtfunktion A 26:
nicht aktiv
Lichtfunktion B 26:
nicht aktiv
Lichtfunktion C 26:
nicht aktiv
Dimmwert ABC 26:
0
Lichtansteuerung HD ABC 26:
always
Lichtfunktion D 26:
nicht aktiv
Lichtfunktion E 26:
nicht aktiv
Lichtfunktion F 26:
nicht aktiv
Dimmwert DEF 26:
0
Dimming Direction DEF 26:
maximize
Lichtfunktion G 26:
nicht aktiv
Lichtfunktion H 26:
nicht aktiv
Lichtfunktion I 26:
nicht aktiv
Dimmwert GHI 26:
0
Dimming Direction GHI 26:
maximize
Lichtfunktion J 26:
nicht aktiv
Lichtfunktion K 26:
nicht aktiv
Lichtfunktion L 26:
nicht aktiv
Dimmwert JKL 26:
0
Dimming Direction JKL 26:
maximize
So, it's anchored here in the dataset. It's clear that not a single light channel is wired with CH/LH... if you read the app, it says that the instrument cluster is flashing and causing malfunctions, as well as the indicators... that means it's being flashed... so OBD 11 is specifically writing to the EEPROM memory of the CH/LH function.
Which app? I code directly, not via apps...
CH/LH is working perfectly as I stated in my earlier messages and I coded the front Fog lights to lit up as well.
So, at current I have both the front dimmed beams and fog lights enabled for CH/LH.
I just want the fog lights to be lit.
It doesn't work with your control unit. You can't solve it with coding. You have to change the data set. The one-click app from obd 11 does that.
Edited by Cairus
I'm trying to organize an Octavia 4 where I save the data set then make the change with obd 11 and then save the data set again and compare
Thanks for the effort to take!
