Tested and working coding Octavia mk4
5 hours ago, Cairus said:
I'm trying to organize an Octavia 4 where I save the data set then make the change with obd 11 and then save the data set again and compare
How about (For Matrix beams):
To turn off the dipped beams for CH/LH:
Change the following channels:
(8)-Leuchte6ABL LC5-Lichtfunktion C 6, change active to not active
(8)-Leuchte7ABL RB1-Lichtfunktion C 7, change active to not active
  • Replies 294
  • Views 119.7k
  • Self moderation is the key to happiness. The best reply is sometimes no reply at all.   we’re all free to do what we want to do with our stuff.   Why would someone buy a brand new
  • @SkOmk4, My answer in line: 1. All the Release Active DTCs will be present only on the SFD locked modules. The reason why the DTC is still present on that module is that you forgot cu SFD Lock the m
  • I think both sides of the argument have some validity.   Perhaps an addition to the first post by the OP stating that you should backup the configs before doing anything, you should understa
I'd be surprised if it worked. The function is the parking light, not CH/LH. That was a separate function in the MQB Classic. As you can see, it has been adapted separately in the MQB EVO.
So, what would be the solution then according to you?
Edited by SkodaOctaviaIV
You have to decide what you want to do. I need a test vehicle and then I have to run the OBD11 app so I can compare what has been changed in the data set.
Are you able to get a test vehicle?
Without having to pay for it, not quickly. I do it all in my free time.
Dont know if this will help but it might as has all the different lights named The same names should apply to the same type on other models Not a very good scan Im sorry but cant find where I got iPet scan.jpgt from to redo it
Thanks for this overview, very handy!
I now have the opportunity to regularly work on an MQB EVO. First, the thermal fog lights and daytime running lights...
If somebody Like To des:
NHTSA Properties
Limitation Dependency
Speed Threshold
NHTSA Limitation Switches for Android Auto without Video Playback
On
NHTSA Limitation Switches for Android Auto without Text Input
Not
On
NHTSA Limitation Switches for Android Auto without Voice Input
Not
On
NHTSA Limitation Switches for Android Auto without Setup
On
NHTSA Limitation Switches for Android Auto with Limit Display
yed_message_length
On
nhtsa_limitation_switches_for_carplay_no_softkeyboard
d
On
nhtsa_limitation_switches_for_carplay_no_softphonekey
ypad
Not
On
nhtsa_limitation_switches_for_carplay_limit_nonmusical
Lists
Data in Real-time
Not activated
NHTSA_Limitation_Switches_for_CarPlay_Limit_MusicLists not activated
Long coding
NHTSA_Limitation_Switches_for_CarPlay_No_IAPAN
Adaptation
Not activated
Hi @Cairus
What exactly does the above listed settings do? And in which module?
Which module? If you had read the text carefully, you wouldn't have had to ask this point.
  • 3 months later...
Hi guys,
I tried sort of codings from this topic today on my Octavia 4 RS 2021:
30 ambient colors - working
Lane assist setting memory - working
refuel quantity in dashboard- working
drl menu - working
menu control door release - already there
automatic rear wiper - already there
dsg temperature - already there
G-meter - X not working
laptimer - X not working
needle sweep - X not working
Lights off while driving (or DRL to work after 10km/h) - did not find the coding
I would like to ask if someone managed to code CH/LH to have only DRL + FOG LIGHTS.
I tried with one app from obdeleven, but when I set value: via foglights, the CH/LH included all 3 of them: low beam, fog and drl, and I reverted to original via low beam.
If you have an answer, would really help. Many thanks!
You can Turn Off ISA With 5W Camera. By Modell year 26 is a big Change, Kamera With 3W is installed. By 3W ISA can not Turn off
Hello,
I’m wondering whether it’s worth buying an OBD 11. I’d like to be able to check the oil and DSG temperatures, and perhaps the fuel level when I need to top it up. It might also be useful to know if the battery needs changing in the next 2–3 years. €120 for the basic package is a bit pricey.
I’m wondering if my Skoda dealer might put up any obstacles if they find out.
Had my car 2023 coded with various and been to dealerships many times never had an issue
Lane assist was the first one coded out
Hi, I activated adaptive lane guidance on Octavia 4, but I don't have the option to turn it on/off in infotainment. There is only the Lane assistant option. The camera is 2Q0 ... and I activated it as mentioned everywhere. Unit A5, long coding Point_of_intervention late_setting_over_menu. Does anyone know why adaptive lane guidance is not shown in infotainment? Thank you
Octavia 4 and 2Q Kamera?
sorry , 5WA 980 653
Der adaptive SA wird nicht im Infotainment angezeigt...nur der spurhalte wird im Dashboard angezeigt.
Ersichtlich an der Orange Farben Darstellung.
Sometimes the adaptive lane assist coding goes straight to Travel Assist mode, and you need a button on the steering wheel to turn it on.
Edited by Acher
