infotainment update
On 25/12/2023 at 22:28, spurf said:
I found this site that has the firmwares available for download
https://www.digital-eliteboard.com/threads/skoda-columbus-aio-mib2-5-mhi2_er_skg13_p4526_1-mib2-mhi2_er_skg11_k3343_1-carplay-android-auto-ifs-root-el-patch.493556/
You need to register and the site is in German but chrome can translate it for you. You can download from mega or mibsolution.on (login details are guest/guest)
Enjoy 👍
Just bumping up my post as people are still requesting updates here. I updated mine using the files from the above website and it went very smoothly. There are a bunch of YouTube videos that will guide you through the update process too.
  • Replies 217
  • Views 76k
  • @xyboox You shall have update by PM
  • No. And it's probably a good idea to do this on a used car anyway (hopefully the dealer will have done it, but there's no harm in you doing it just in case 😉).
  • @Joncs23yes   @Ievgeniii need to download it from the server for you   @bluemoon2020sent me pm
On 04/12/2022 at 19:24, varooom said:
I will send you a PM shortly to 0480 version
can you help me too please? I have at the moment the same version...0475..
Thank you,
Dan
Hello everyone.
Can someone help me with the information about the latest update available for the current version of the Amundsen on my 2017 Kodiaq?
What would be the advantages of this update?
And if you could post the procedure, I would be grateful.
Many greetings.
The current details are in the photo.
Hi all,
Is there any new software available ? Having issues with carplay over cable and hopefully sw update will help.
My actual is:
 MHI_ER_SKG13_P4523 with SW MU: 1382.
Can you point me to newer version if available ?
I didn't understand what do following that German forum...
0?ui=2&ik=536dbd1821&attid=0.1&permmsgid=msg-a:r1114984822599598700&th=18ec4e8803e8fc57&view=fimg&fur=ip&sz=s0-l75-ft&attbid=ANGjdJ-Legq91P8oWmFT3ixToaZkkeYQvAkfEm67OiliJdDqDuxYKAFM9JxTvud-UWnGheiKq9mWBGUUfcUXzY3kzrZU0aewM3GlAji3MBVz2h7ij3CfYzm8i_5iMEw&disp=emb&realattid=18ec4e8732dbee5f62c1
@varooom do you have any update for this one? thanks
I doubt that @varooom will answer since last time he was online was August of last year.
After a bit of digging, I found the files and tutorial that anyone can follow.
to check if there's any update and download: https://mib-helper.com/
tutorial:
don't think we need anything else
Hi everyone, there is an update for this version. Thank youIMG_7384.thumb.jpeg.10719a1966921d9e86a9367f2d48340d.jpeg
Hi everyone, new here, have a 2017 Octavia for about 3 years.
It’s on the below/attached firmware / SW MU version. 0363.
I’ve been getting infotainment crashes and also issues with CarPlay (have googled a lot including this forum as it sounds like the problem could be one of multiple sources, really hard to tell). I’m keen to try an update to see if that helps.
Can anyone help me identify how I can get this updated? The car says it’s got 0363-1 available. Is there a way I can do this myself?
My closest dealer is 30 mins away but they haven’t responded to me so far on requests to do an update.
Pozdravujem, ja mam momentálne toto v kodiaq 2019. Existuje niečo novšie?
Hi, does anyone have an update for a 2020 skoda kodiaq?
It was said in one of the recordings that the car should be on all the time while running the update. Should I turn on just ignition or the engine as well ? If just the ignition how do I know that the battery is charged enough ?
Hi, I am new here and have a 2021 Skoda Kodiaq a would like to update the infotainment system. Can anyone provide the latest update?
Many thanks in advanced
IMG_0906.HEIC
Hi @varooom, hi Guys, i am also new here and would be very thankful, if you could help me to update the Bolero in my 2018 Kodiaq. It seems that the pre-owner of my car wasn't very interested into updates in the past.
Many thanks to you in common!
Just read "a little" to the update-thing. It seems, that P0480T from 2021 still is the latest update-version for the Technisat-Bolero? Could this be or is there any newer stuff? Thanks in common for your hints and tips!
In the meantime i managed it on my own to update my MIB2 from 0472 to 0480. Maybe there is now an error somewhere in the Memory, but can't do anything against it without an OBD-tool. Also recognized no changes to the older software.
I've got multimedia firmware updated last year because had some issues, freezing and etc. Some of them gone. I've got new functions as weel, for example voice control using russian language. I wonder if there any newer update available for my car? Last time I got update from user varooom: MHI2_ER_SKG13_P4526, MU 1440. Also wondering is there any possibilities to get engine/ECU and gearbox firmware update without going to dealer? Which scanner and which app should be used for check and update? Which is the final version for my car skoda kodiaq rs diesel 12/2018, VIN TMBLM9NS7K8036627. Thanks.
Is there any way to verify if the firmware is legit ?
regarding infotainment, you have the latest update. i have no answer for your other questions
latest is 0480 -> https://mibsolution.one/index.php/f/142698
tutorial:
for everyone looking for updates, I believe you missed what I wrote before. you can check by yourselves if there's any update, which is pretty cool
I know I am coming very late to this topic ... 8 pages of postings to read through!  My 2018 Kodiaq shows:
SW Train version:   MH12_ER_SKG13_P4177
Installed SW MU version:  1125.
I presume this is out of date. I had the car serviced at a Skoda main dealer in July, under a 2-year service and warranty plan, and was told that software update is not included. It will cost me up to £150 to have this done by them.
My questions:
Is it right that it's not part of servicing?
What are the benefits of updating the software?
Would that allow me to then turn on full personalisation (the garage said not possible without the update)
Can I update myself through this forum?
Many thanks!
Hi.
I have the following version on my Kodiaq Sportline 2018 year, is there a newer version please?
Hi all
Anybody has pinout description for Skoda Multimedia Columbus MHI2 ?
Edited by pepeEL
On 10/10/2024 at 06:55, pepeEL said:
Hi all
Are you after which wire does what? I just did this on a kodiaq.  Search for quadlock wiring diagram for your car.  Sorry, but i cant find the link i used.
Hello,
I would also like to update my car. Is it possible to get somewhere the files?
Release Version: MOI3_EU_SKMQB_P27000P
Version: 0270
Thank you very much.
