Software Update available for Bolero?
Hi, is there newer update available then 1798? I have new Samsung S23 and Android Auto is not working
  • Replies 757
  • Views 183.4k
  • StripleRider03
    StripleRider03
    I just updated to 1800, I have a Skoda Slavia in India with the Bolero system. I can confirm that the issue with S23 Ultra is finally resolved! Attaching images.
  • radoszczak
    radoszczak
    Cześć, poniżej link do strony z opisem możliwych FW U Ciebie powinno pójść do wersji 742. https://www.drive2.ru/l/650934799095051499/
  • There are these updates, but not sure if the higher number will apply to your system.   MEN3_EU_SK370_P0113P_0469 MEN3_EU_SK370_P2135P_0742   MEN3_EU_SK370_P1185L_1760 ME
Hello everybody, in my city the service says that there are no updates for bolero, but reading the forum I discovered that they exist! Sometimes I have problems with Music folders, does not load them properly. Might an update help? Thank you
Hello everyone, I have a connectivity problem between my Bolero and Honor Magic 5 Pro. I hope to be able to solve the problem with a software or firmware update. Can anybody help me? THX
On 15.03.2023 at 16:32, varooom said:
Bu güncellemeler var, ancak daha yüksek sayının sisteminiz için geçerli olup olmayacağından emin değilsiniz.
MEN3_EU_SK370_P2345L_1790
Önerebileceğim tek şey denemek için 0742'dir (uyumlu değilse yüklenmez)
Yüklenmezse 0469 geçerli sürümünüzdür ve satırın sonudur.
Hi
I had version 0469 in my Scala and I replaced it with 0742. Then "Pre production hardware not for resale" started to appear on the android auto screen and I want to go back to the old version.
Should I reinstall version 0469 with usb memory or is there another way to return to the factory version?
In any case, can you share version 0469 with me?
2 minutes ago, PisAdam said:
Hi
Sent me pm
So can someone reply to me
No not yet
😞 i need fix for AA with S23, Skoda doing poor job
Hi everybody,
Rainesh was so kind and gave me access to the following Updates:
MEN3_EU_SK370_P3225L MU1798
MEN3_EU_SK370_P2345L_MU1790
Unfortunally i'm not able to bring one of them to work...
What i've done while following your instructions:
I have a 64GB USB stick from the brand "Keksin", this has USB C and USB 3 as connection (my Scala only has usb c, or im also too dumb to find any SD-Card-Slot).
I formatted the USB stick as FAT32 and copied the unzipped folders "MEN3_EU_SK370_P2345L" + "MEN3_EU_SK370_P3225L" to it.
The folders are recognized in my Scala, so I can select the source USB in the update menu "Service Update" and see the folder or folders I mentioned above.
But if I try to open one of them, "Reading Meta Info" only appears very briefly and I'm back in the folder selection that shows me the above-mentioned folders.
usb with the subfolders (meta) of one update - does not work, folders are not displayed in scala. As if there were no stick in the usb
usb with the main folder - does not work, folder is displayed in scala but cannot be opened.
usb with both main folders - does not work. folder is shown in scala but cannot be opened
I formatted my 64gb stick to fat32
Main folder, packed on the stick. The folder is displayed in the update menu and cannot be opened. both versions are affected.
folders decompressed, subordinate meta and data packed on the stick. USB stick is not displayed in the update menu.
same behavior with ntfs and exfat formatting.
I hope anybody can help me, THX!
Ah now i see that you need an intermediate firmware. Will sent you another one
Hi Rainesh, i dont want to disturb you, but could you pleased sende me the Update Files?
Hello all,
I have issues connecting to Android Auto, sometimes it works wirelessly, sometimes not even when connected with a cable.
I cant seem to get a decent fix, tried different cables, phone app restarts, cache and storage deletion, and playing with the bolero settings to try to remedy.
Each time i give up.
So here i am, wondering if an update might be available, my current car is the Kamiq 2020, and phone is fully up to date pixel 7 pro: -
any help or advice would be much appreciated, thanks.
18 hours ago, da02uk said:
Hello all,
Sent me pm
I'm having issues connecting my S23 Ultra for Android Auto. I am running version 1790 on my infotainment. Attached the screenshot. Would be great if you can share 1798 with me.
This is my software train:
@varooom @Rainesh it would be helpful if you can PM me the instructions and the link to download 1798
Can somebody sent him the link 1798? Currently not able to sent
Hi, is there newer update available then 1798? Samsung S23 and Android Auto is still not working, i f... want to hit the tree or something that Scala is ****ing me off, 1000dollars for phone and that piece of **** cheap Scala usb and infotaiment not support high speed usb transfer
So even after updating to 1798, Android Auto isn't working with S23?
Nope nothing works, but i found some emails from Skoda that they are planning upgrade on the end of summery even when i use Google Bard to check my writing of email to Skoda before i send it reply me that they are already testing SW in CZ and Slovakia but i dont know where the Bard find that info it looks like text from Skoda
@varooom
Hello varooom,
can I please you to send me the newest software and firmware for my Scala 2019? Actually there is software MEN3_EU_SK370_PO113P, 0469.
Thank you!
On 30/05/2023 at 18:41, Rainesh said:
Yes Skoda version. What do you mean?
i have the same 0278 can someone help me to update it thanks
On 28/07/2023 at 09:30, Rainesh said:
Check your pm
i will need the software too. my Kamiq with bolero cannot connect to s23 too...
On 01/09/2023 at 07:19, Rainesh said:
Sent me pm
Hi Rainesh,
I have a scala 2019 with the same spec. Is it possible that you will send the software update to me as well?
on the following link hxxps://www.drive2.ru/l/650934799095051499/ you can find the information on the right version update paths and the link for almost all software versions
