Update my car from 0156 to 0306
Yes, the problem is known. However, you won't get the navigation back with a firmware update to version 03xx. The FeC has become invalid.
  • Replies 157
  • Views 66.8k
  • @chli @vegarz @ace_finland  with the B201A error, u need to generate a code, using an XOR Calculator.  This is generated based on your existing adaption value (Step #1), in combination with the d
  • Well, time for an update 😉   Everything works now! Thanks to varroom, I also updated to 0324 with a sidestep to 0308 (0306 —> 0308).   The main problem I had, was updating the O
  • It only shows up in the control module when you scan for faults. Nothing you will see on the screen.
On 04/04/2023 at 17:40, varooom said:
Thanks for the write up of this for others to follow.  I am sure there are others out there on older versions, and looking for an upgrade path.
I look forward to the next chapter, of getting the activation code input 🤝
@varooom Hello I'm looking for MOI3_EU_SKMQB_P30800P, I hear you are the one who can help me with. Thank you in forward <3
No warrenty
https://mega.nz/file/1vMSzIqL#H43T7RVK8uOXyxRH9LoNOWUD1hca8lvFoKGpbFvxwP4
 with the B201A error, u need to generate a code, using an XOR Calculator.  This is generated based on your existing adaption value (Step #1), in combination with the decryption key, which in turn generates a new Key (Step #2) for you to enter (Step #3).
below is a screenshot from a how-to document i created, which contains the steps to fix the B201A error.
I tried this today with VCDS and I got errors. Firstly it said it was an uninitialised module and suggested adding the default workshop codes, then with those i got this error. My initial values for those 3 bottom fields were 00000/000/00000. Has anyone come across this before? I got the correct new code from the mib-helper site
Edited by Dave77
  • 4 months later...
Can I ask - I'm on 0276 and I have the daily "update" message that apparently needs a FW update to be carried out.
Reading this thread, it seems that if I update it manually, some other things will break and I can't fix them?
Is that correct, or is there a full fix now?
Thanks.
Thanks.
Managed to get the first in the path on earlier today, looks good so far.
Will do the other 2 later.
And now all done. Went without any trouble, thankfully.
Update for anyone who uses an EV energy tariff where the energy company control your charging - such as Octopus IOG.
After I updated the car the first time, the API sync was broken. I didn't notice at first, but the Octopus app no longer recognised I'd plugged my car in, so it didn't try to find me a charging slot and the car just kept charging by itself.
You need to remove the device (the car) from the Octopus App, and re-add it.
And top tip, it asks for Mileage and VIN - get them from the app, the mileage on the app has to match, and it isn't always exactly the same as the mileage on the dashboard!
Recently Browsing 1
