Start and stop disable permanently
HI to everyone I have a request for  disable start and stop permanently.
Somebody know how i can do that?
i try with standard metod with OBD eleven but don't work i read the VW group "change the software"  to make things more difficult
. I tried the OBD eleven quick methods but they no longer work, you need to change the code, do any of you know how to do it?
  • Replies 90
  • Views 44k
  • also interested, start and stop is one of the most anoying thing ever created in the human history 😁
  • Ballcocks! A mate of mine taxied a Superb with Stop/Start in urban traffic and the battery lasted 3 years before the Stop/Start ceased to operate.
  • ^^^^ rubbish on killing new batteries in 12 months.  There will be plenty here that do not just switch off stop start when they start a trip and have batteries lasting the period of the Manufacturers
Following Dieselgate VAG have removed all the diagnostic tool methods of disabling start/stop.
yes I read but I saw that someone by changing the manualy the code (bit) can solve the problem the issue is that I don't know on which ECU and which bit to modify
As far as I know this is not possible with coding.
Sometimes stop-start is irritating, but if you keep light pressure on the brake pedal while stopped, the engine will keep running. With heavier pressure it stops. Works for me.
Its not possible with coding but in the software its possible. Just had it finally changed during my stage 2 tuning.
Was that by adaptation change or firmware change?
Please give more details.
It's firmware change. With a custom map tuners can change also various other settings in car's computer which are not possible with coding. For example changing start/stop to remember last setting, left foot braking, disabling auto-**** in manual mode, etc...
That's what I thought you meant but wanted to clarify that the firmware needs 'modifying' by a tuner.
Go to AliExpress and search start stop module for your specific car
those kind of modules only work for cars with physical buttons
Oh, they've removed the physical button? Seems like a retrograde step.
Depends on who you ask. 😂 Skoda engineers would disagree with you for sure.
But yes, now you need at least 3 clicks to disable it. And usually you also need to wait a bit for infotainment to fully load before you can disable it.
Is start stop disabled if the gearbox is in sport mode? (it is this way on some Audis).
No
Seen this on Aliexpress
Link?
Thank you.
Really poor installation instructions. 😞
Thanks for posting @Andy585
LOL !!! plug & play it's written. Besides the fact that you have to remove the Vehicle Voltage control unit from its location to play with connectors, in the control unit you have 3 connectors: 2 73 pins connectors (T73a + T73b) and 1 46 pins connector (T73c). Either you have full detail on wiring in the installation manual or ... good luck! because without that information I would not be able to install it.
  • 6 months later...
Hello. After installing the heated steering https://www.briskoda.net/forums/topic/518453-retrofit-of-the-steering-wheel/#comment-5815149, I decided to work on disabling the start/stop system. What I found:
1) China adapter which is not clear how to connect https://pl.aliexpress.com/item/1005005381695131.html?gatewayAdapt=glo2pol
2) China adapter which is easy to connect https://pl.aliexpress.com/item/1005006284446645.html?gatewayAdapt=glo2pol
3) Coding + Arduino
What do you think?
Edited by Dimex
Which is why I am reluctant to change my 4 year-old Scala battery. The car is smart enough to turn off SS (permanently?) if the battery is old!
I have also read that there is also a brute force procedure involving disconnecting the battery sensor wire, at the battery, if you are desperate!
Up with this post.
Somebody did a try on the second option from @Dimex?
As far as I can see, sold articles are going up and with positive feedback.
