Volume keeps turning up??
Almost a month after I disconnected the Skoda infotainment from my iPhone CarPlay, everything is OK—no volume issues. Temperatures were over 35+ for the whole of August. I will now connect Skoda to my iPhone and see whether the issue returns over the next few days. If the issue appears, then it is a software bug/glitch with Skoda infotainment and Apple CarPlay.
  • Replies 134
  • Views 47.7k
  • Hello, after reading this thread, I decided to share the information I’ve gathered so far. I started experiencing the same symptoms as others described here: randomly increasing volume, key press sou
  • LivornoBart
    LivornoBart
    Hello, I made a solution for this kind of issue and also made a short movie how to fix touch panel under the black panel which is under the display if you have problems with self clicking or volume go
  • mertpolat
    mertpolat
    @omeromeryigit Thanks for the information you shared. I followed the steps in the post one by one, and in the end my volume increasing issue was fixed. I solved the problem by cleaning the unit that
Hello @LivornoBart ,
That's really amazing. Thank you for sharing with us.
Can you also provide more details about the sensitive touch PCB being replaced(Part no, web link where we can buy it)?
All the best
All the best
Hi, I will make ebay auction for it asap and let you know. that touch panel was made by me. works great, already repaired 50 pieces of that radio in octavia 4. The problem is gone.
I’ll feature the video post for you, as a cure.
But if you contact @ColinD , the Site Owner, you can discuss options for being able to sell the repair product you have made through the forum’s market place.
ok thank you, will do that
I have the same problem, today i cleaned it with isopropyl alcohol (Spray PRF IPA/220) , so I'll keep an eye on it over the next few days and let you know.
I'd also be interested in this. I'll keep an eye out for your ebay link.
I've had the volume bar unplugged all summer which of course stopped the problem. I plugged it back in today to take it to the Skoda garage, and they of course have to do a software update (for £200) before even considering any other repairs/replacements.
No doubt as soon as the hot weather starts up again the problem will come back, and then I'll have a go at replacing the touch panel. Meanwhile Skoda are up £200...
Hello. can you please PM me contact to @ColinD? I can't msg him as I have less than 20 posts on your forum:)))
if you have problems with self clicking or volume goes up or down all the time - this is the solution. Sometimes when on/off button is self clicking all the time - unit keeps rebooting as well.
Hi
Does it solve the problem with the volume rising on its own that caused by heat.
I have the same problem, Volume increases by its own and even the screen has problem with responding to touch, even the 2 buttons on the left side not responding…..
Recently Browsing 1
