Update to Version 1969
32 minutes ago, shadyk2 said:
hey man im stuck in the same problem, same exact infotainment info as you. i tried to download 1805 file update for mib solution but its weirdy small in size, only 300mb and when i extract it on the usb, the car screen is showing it empty, did you find any info ?
Hey! Unfortunately, I haven't found any reliable links or files on my own either. To avoid any risk of bricking the unit, I've decided to hand it over to a professional 'pro' who specializes in these updates, whom I found through a local Facebook forum here in Slovakia. It's safer than DIY-ing it with questionable files.
  • Replies 545
  • Views 171.5k
  • The update files for the update can be found here, credit to @Giannis20 for providing these. megaload link:  https://mega.nz/file/994DUTwL key to access file on Mega  u22UzB0cTcz6sutX
  • I haven’t tried exFAT unfortunately and not sure why I decided to format to ntfs after fat32 didn’t work:) Well it sounds like both ntfs and exfat are supported and importantly the update didn’t brick
  • New Download Links:   I have uploaded the file to a couple of my cloud services, and no password is required. Give them a try and let me know if they are working okay for you.  The firs
for how much?
How I get 1969 software
  • Hi guys, I have an Amundsen/Bolero HW56 currently stuck on version 1668. Could someone kindly share a Google Drive/Mega link for a bridge update (like R1810L or R1896L) so I can finally jump to 1941? Thanks!
The links in this thread are for Columbus software I believe, not sure if Bolero updates have been posted, or even if they carry the same 4 digit reference as the Columbus updates (such as 1941)
I have columbus
Has anyone encountered a problem where the radio freezes at the loading metainfo screen and nothing else happens? Is there no way to proceed any further? How can I resolve this issue?
I have columbus
Just you mentioned Bolero above...
Which link
Hello,
I have Skoda Octavia 2021y.
And there was done update using following archive "MOI3_RECOV_R9900L_5FA919360AS".
The logic why it was applied is very stupid, I don't know why it was done, looks like he was very boring.
It was applied to 5E3035820E, 1803. So unit now have black screen and constantly rebooting.
Is it possible to recover it using FW 1941?
On 30/08/2025 at 19:46, Wabbelbabbel said:
Hi everyone,
If anyone’s wondering whether it worked - yes, it did!
Here's what I did:
- Updated main software from 1804 to 1941 -> MOI3_EU_SK_R9410L
- Updated main software from 1941 to 1985 -> MOI3_EU_SK_R9850L
- Updated radio software from 1.31.48 (version after the 1985 update) to 1.31.58 -> MQB3_LGe_Europe_v1.31.58
- Everything else will update automatically when you're done -> just give it some time
My original system information:
Device part number: 5E3035816F
Hardware: H56
Software: 1804 (now: 1985)
ABT hardware: H47
ABT software: 2092
Navigation database: 20.7 (now: 25.8 -> will update automatically from now on)
Media codec: 3.1.4
Radio database: 1.30.24 (now: 1.31.58)
You can find the main software on mibsolution.
For the radio software, it’s better to check phonostar and enter your VW part number, not the Skoda one, as it won’t return results otherwise (Skoda part number: 5E3035816F -> VW part number: 3G5035820D). I found the VW part number by searching through various forums.
So far the system seems to boot faster, works more smoothly, and feels generally more stable (e.g., no sound issues with Android Auto).
Hello,
I am quoting this post as it is a similar situation for me.
I own a SKODA Octavia Combi iV (build in March 2021) with following specs:
  • part number: 5E3035816D
  • hardware: H56
  • software: 1803
  • ABT hardware: H45
  • ABT software: 2092
  • navigation database: 24.2
  • media-codec: 3.1.4
Now I did the update to 1941 as explained in several threads. The system seems to work very smooth, no issues at all, everything seems to be fine.
This is the current setting now:
  • hardware: H56
  • software: 1941
  • ABT hardware: H45
Now I am wondering if it makes sense to update again to 1969 or maybe directly to 1989 ? What is your experience for these 'old' cars build in march 2021 and updates to 1969 or 1989 ?
Thanks in advance,
Andy
Octavia Mk4 Estate 1.5TSI Manual – SE L First Edition
Manufacture Date: 2020
Infotainment Hardware: H56
Display Unit/Control Panel Hardware: H44
Display Unit/Control Panel Software: 2088
I formatted the USB stick to exFAT copied the files to the root, when I did the update, I had the engine running, the bonnet and the windows open and the AC turned off.
I started with 1896 and moved to 1941, this took about 25 minutes following the on-screen process listed in the original post.
This went smoothly with no issues, the main thing I noticed was how fast the screen was after the update.
The dealer put my car up to 1985 when it went in for a service in February. It was absolutely fine, and my only negative experience with it was that there seemed to be far fewer radio station logos.
Last week the car went in for an OCU update, and they also updated the infotainment to 1989. So far it all seems fine, and there seems to be a lot more radio station logos available now.
I know looking at the threads on this forum that some people who've updated to 1989 have benefited from doing a factory reset of the infotainment after the update completes. When I picked the car up from the dealer I did have to login again, set myself as primary user, etc. So I suspect they did a factory reset (but I know the OCU update was also forcing people to sign in again).
Here is a link to where I go the last update from.
On 03/09/2025 at 16:37, Tarle18 said:
Hi @Wabbelbabbel,
Few questions regarding your instruction:
1) Which exactly files you used for updating to 1941 version because I found two files for this version on mibsolution:
2) Where exactly did you find VW part number related to your Skoda part number for radio software? Because I couldn't find anything similar (my Skoda part number - 5E3035816G).
Thank you for your help in advance!
@Tarle18: Sorry for the late reply. I haven't been active here for quite a while.
In case this is still relevant:
1) I used "MOI3_EU_SK_R9410L MU1941".
2) I found the number somewhere in a forum. Unfortunately, that was the only match I could find.
Hi,
So, I am going to update from version MOI3_EU_SK_R8100L MU1810.
Can I go directly to version MOI3_EU_SK_R9410L MU1941 and then to the latest MOI3_EU_SK_R9890L MU1989?
Thanks in advance (:
Yes, that's what I did.
Okay, I will try.
Thanks for your reply 😊
Hello!
It has probably been discussed before, but an update of the information is welcome...
My problem was as follows:
- recently, I had a problem with the MIB III, a defect appeared on the motherboard (diagnosed at the SKODA service representative) which led to the fact that the image of the reversing camera disappeared;
- the conclusion of the SKODA service representative was the need to replace the MIB III;
- the price offered by the SKODA service representative was exorbitant;
- the defective MIB III had the following characteristics:
  • PN 5E3035816H
  • Hardware H56
  • Software 1985 (from USB)
What I did:
- I bought a MIB III from a dismantling center
- I went to a dedicated center and replaced the MIB III unit
- the components were transferred ONLINE via ODIS and other software applications
Result:
- the old MIB III successfully replaced
- the components work correctly
- the new MIB III has the following characteristics:
  • PN 5E3035816F
  • Hardware H56
  • Software 1810
Now, to bring the new MIB III unit to a software version that is as current as possible, can I do a gradual update?
If so, what would be the safe steps and possibly some links for those updates, that would be welcome!
Thanks in advanced!
On 26/01/2025 at 03:26, Simon812 said:
Hi,
Did anyone successfully update SW 1810 to newer versions 1969 or 1985?
PN: 5E3035816F
Hardware: H56
Software: 1810
HMI HW: H44
HMI SW: 2088
I plan to update to SW 1941 and then to 1985. Thanks in advance!
I want to do the same steps! Did you manage to update according to what you wrote? Can you share the update files? Thanks,
On 25/07/2026 at 01:04, Matty93 said:
Hi,
Hi,
