Infotainment system switches itself on
Congratulations, I'm glad you made it.
  • Replies 101
  • Views 32.1k
  • DeelyStan
    DeelyStan
    I have just disconnected the touch bar/volume slider using the instructions from this forum. So far it has fixed the issue. If it helps the exact steps I followed were: Remove long trim piece under
  • MartinOctavia1969
    MartinOctavia1969
    I bought it from a dutch company called vd Ven is a dealer in parts for all cars.. I saw that RRR.lt sold them to. Ebay.co.uk has them. But watch the H49 hardware versions there should be a picture w
  • Well, I had another go at disconnecting the flat cable as suggested earlier in this post. I had both, the black and blue plugs connected and the radio was on (not sure if the ignition was also on). I
@omeromeryigit i have to. Disconnected until i get a new unit thank you for your explaination
After a few days driving with a disconnected slider i replaced the screen for a H49 hardware version from a 2024 Octavia.
Hope the screen demons that belong to the H47 are gone now.
30 min to swap simple job.
May I ask how much you paid for the screen and where you got it from?
But watch the H49 hardware versions there should be a picture with the right hardware on it.
I paid 425 euro's for it. Mine is a year old from a 2024 plate
Just started getting this issue yesterday! Mine's a 2022 Mk4 unit.
Thanks for sharing the tip on disconnecting the white cable - I'll see if my agent can do it as a short term fix.
To update on my case - they said it's the first unit to face the reported problem in Singapore!
The whole headunit will need to be replaced, parts coming by Thursday.
Have left the car with them as this is causing my 12v battery to be drained overnight.
I hope they replace it under warranty.
My head unit is replaced to. From hardware version H47 to H49.
Hopefully it will solve your problems
Thanks for asking! Yes, it's covered by warranty here 👍
Are they replacing screen or MIB though? Cause on my car they were replacing MIB at first but issue is not there, the screen should be H49.
Edited by Edela
Hello,
I got my car back from the workshop today.
Can confirm that only the display unit (5E3919605) got replaced under warranty. The previous display unit was hardware H47, now the new one is H49.
They also did some software update to my DSG gearbox which was a separate matter.
Edited by EldridChapman
Hello,
The H49 are good my H47 is also replaced
  • 6 months later...
On 12/07/2025 at 14:08, petersu said:
Bene, ho riprovato a scollegare il cavo piatto come suggerito in precedenza in questo post. Avevo entrambi i connettori, quello nero e quello blu, collegati e la radio era accesa (non sono sicuro se anche il quadro fosse acceso). Ho quindi scollegato il cavo piatto mostrato nella foto del post precedente e questa volta lo schermo è rimasto acceso. Quindi, quando chiudo la macchina, lo schermo si spegne. Quando sblocco la macchina e accendo il quadro, lo schermo si riaccende. Il pulsante di accensione/spegnimento sotto lo schermo ora è inattivo, così come il cursore del volume. Il volume può ancora essere regolato dal volante. Dato che non ho mai usato questi comandi (ora inattivi), non mi mancheranno.
L'auto ora è parcheggiata al sole nel vialetto e a questo punto sono abbastanza sicuro che questa sia finalmente la fine dei continui riavvii del sistema di infotainment e della radio a tutto volume quando l'auto è chiusa.
Grazie molto@omeromeryigitgrazie per i vostri suggerimenti!
hi, After removing the sound bar, did you have any more problems restarting it? thanks
You need to make sure the infotainment system is on when you disconnect the soundbar because the on/off button will not work anymore. So far there was no need for me to do a hard reset by pressing and holding the on/off button.
Thanks, I'll try that and the important thing is that it doesn't restart with the car off and locked to avoid draining the battery.
Exactly! No more issues like that.
On 20.05.2024 at 16:56, petersu said:
Привет,
Уже дважды такое случалось: я проходил мимо своей припаркованной и запертой Octavia Mk IV и замечал, что информационно-развлекательная система включена и играет радио. У кого-нибудь такое бывало? Оба раза это происходило в солнечный день, поэтому в машине было довольно жарко. Есть ли способ сделать так, чтобы информационно-развлекательную систему можно было включить только при наличии ключа?
Автомобиль выпущен в сентябре 2020 года, версия программного обеспечения — 1941.
Спасибо,
Питер
It's much simpler. The problem is caused by static electricity. Attach a grounding cable to the muffler. The effect won't be immediate; wait half an hour.
Привет,
Спасибо,
Питер
Columbus is glitching due to static electricity. Attach a grounding cable to the muffler. The effect doesn't appear immediately; wait half an hour.
On 10/07/2025 at 19:12, Benjybobs said:
I could have written the same post.
June July every year, then fine with no interventions until next year.
Bit earlier this year, but it’s doing it again. Been fine since i last posted. Started with the alarm going off with the engine running today and car unlocked which is a new variation. Now the constant boot cycling and volume turning down.
Coincidence that it’s the first warm day of the year?
Update.
It was looping terribly, so i pulled fuse 30 (30amp, picture below, one below the yellow tag on its own) and then left it out, locked the car Abe came back 30 mins later, reinstated the fuse and started the car.
Seems to have fixed it.
Edited by Benjybobs
On 03/07/2025 at 18:01, petersu said:
Thanks. I got the front panel off but I can't get the panel behind the screen off. Is there a trick?
hey, how did you do it? I can't get my head around getting the back panel off. Should both cables at the back remain connected? Should it come off when I remove the screws?
Made it, everything came off after removing the screws :)
Hi All,
I have this issue and it's driving us nuts; it's bad when parked at home and suddenly comes on at maximum volume, same thing happens when driving, last night on trying to restore the fuse it boot cycles.
I'm thinking of buying the screen as others have done; H49 version.
Does anyone have the part number?
Full model is Skoda Octavia SE TECH TSI E-TEC S-A Estate.
I'm calling the dealer also; but it's not longer under warranty and anyway they never call back.
If I buy it I'll find a local garage to fit it I guess.
Time being I've removed the fuse 30; I broke the glovebox slider doing so.
Hello, we've found a new solution for the multimedia issue. I believe this problem is caused by liquid getting into the touchscreen or moisture accumulating there. If you can remove the screen, clean the touchscreen with isotopic alcohol. Wipe the power button and volume bar thoroughly. I haven't experienced any issues since May 2025. The power button and volume bar work perfectly.
