SKODA FELICIA 1.6, General questions and fixes (help me pls)
2 hours ago, Paws4Thot said:
Also @Felicia98noob Speaking of, what is the water pump impellor made from? VAG plastic impellors typically have a life of 1 to 1.5 times the cambelt change interval.
No clue man
Okey, pretty sure i cleaned the whole system in an okey way, everything seems to be warm and stuff, about to put everything back together and see how it runs.
  • Replies 114
  • Views 7.6k
  • Felicia98noob
    Felicia98noob
    No worries i have the cap! Just took it off while thinking i have an AC 😂
  • Looks like a bodge to me, I wonder if someone had previously wired-in an override switch to that loom.
  • My concern is over the very existence of those joints, not the quality of the work under the tape.
Am i dumb or… cant see a relay…?
3 hours ago, Papez said:
there are more types of AC. Factory type has relays and fuses near activated charcoal canister, on the opposite side from the battery.
@Felicia98noob f
Edited by Papez
The vables from the fan seem to go into cockpit..?
Just to remind you, when taking a photo it is generally best if you take it in landscape not portrait as above) as this generally shows more.
In this case I see a strut brace that looks newer than the car but I could well be wrong, where strut braces standard to the car from factory?
No clue man.
Looks like factory brace - they were standard on cars equipped with airbag.
@Felicia98noob can you make a pic of the entire engine bay?
Could it be in there? 😂
Just found these haha maybe one of these?
@Felicia98noob from what I can see, your car doesn't have AC. That means that radiator fan is switched directly by the switch in the radiator. It also kicks in rather late, when temp gauge shows around 105° - (+-5° or more, since these switches can drift quite a lot with age)
Not one of those i guess
Oh okey hahahahahha, i thought it had because if these things 😂
Its very importsnt that i am a noob
Car looks very good in your photos.  Oil filler cap upside down ! 😆
Any idea what that white plastic female wiring socket, in the engine bay near sub-loom, is for?
Also, when outting the themostat back in, is there anything i should think about?
and bith of these are supposed to fit. But which one do i pick lol…
fixed it haha.. noo i dont know lol.
The cables in the ECU are exposed, no plug cap.
This means that dust, moisture, water etc are coming.
That's just heating ant ventilation, AC has extra buttons for cooling and recirculation, like this
Or like this
That's for headlamp washers.
Check this part in the thermostat housing
viko-skrine-termostatu-skoda-fabia-i-octavia-ii-1999-2013-neoriginal-032121121k.thumb.jpg.eb77418cbbabd0dfbda63c0b73ef8893.jpg
Or like this
yea okey 😂
that part looked fine.
You have what we used to call 4/60 air-con, wind 4 windows down and got at 60 mph.  😉
Whilst on side issues, any wires, cables, hoses that are close to the suspension bracing strut I would over-sleeve to stop any wear from rubbing vibrations.
Your radio doesn't look like it was from 1998 so as I mentioned before check the wiring installation of that, messed-up wiring can cause all sorts of strange effects and issues, may not have anything to with the Bosch cooling fan but these things are always best checked.
ETA: I don't know what the bracket in the air vent is for both if it's for any add in electronic or electrics of any kind check that wiring too.
Yea i will go through the cabeling at some point but ill do that back home where i have my father who is a mechanic 😂
Hellooo again. SO the fan works it’s obvious to me know that they have done something here. The old thermostat is only two pins and its broken. I put it boiling water and it didnt connect. So i have a new one. It has 3 pins and now im confused. Please help 😂
it seems like they have done something, ALL the cables work, i have measured all of them. So.
from the battery comes a yellow and brown (grounded) cable. The brown cable goes directly to the fan motor. The yellow goes to the thermostat and then the red goes from the thermostat to the motor fan.
what do i do
blue is to the fan
yellow circle is to the battery (the red one does not continue it just stops there)
Res circle goes to the thermostat
Edited by Felicia98noob
Thia is their cable management
two loose ones are the thermostat switch
the 3 pin next two them goes to the battery (the red one in this does not connect to a cable only yellow and brown)
and the brown red big one goes to the fan.
