Update To Infotainment Version 1985 - Download Link and Guide
  • Replies 160
  • Views 62.8k
  • As a point of reference, I have just done a 300 mile round trip and version 1985 was solid and stable on my Octavia.  Obviously that doesn’t necessarily translate to another vehicle as other factors a
  • I was told by a VAG software specialist that you can apply the update with the engine running...    Regardless, thanks for the info. I have the file, but as a new Octavia owner (less than a
  • Well just did a factory reset which came with another OTA update so will see how this goes...
Thank you for sharing it!!! 👍
Thanks for this - have downloaded but won't update yet. I had a hard time with the dealer when getting parking sensors replaced under warranty as they did not believe that 1969 existed (and charged me for the effort to find that out). So I think I'll hang fire until Skoda formally (?) announce 1985 even though I have have issues with my Canton unit (reboots, disconnects, screen being blank).
Thank you so much for sharing the file.
I did the update. Everything is fine.
Hallo hab das Update gemacht alles in Ordnung. Danke
Thank you spcdust, I've downloaded the file and will update at some point.
I did the update and work fine for the moment...
Thank you @spcdust!!!
As a point of reference, I have just done a 300 mile round trip and version 1985 was solid and stable on my Octavia.  Obviously that doesn’t necessarily translate to another vehicle as other factors at play such as individual module firmware versions etc.
Thanks for uploading that. Most appreciated.
Hello. Can someone please put a list of languages supported by the new program? And for which regions it is intended. Thank you.
Thanks a lot for sharing the file, appreciated. 😃
Thank you for sharing the file. I updated yesterday from 1941 to 1985 and so far no issues. Some changes to AA as reported in the other thread.
Merci good work
Thanks so much mate!
Updated and all working well.
Edited by Pete
Thanks for sharing the update. I’ve just updated mine with no issues with the update process unlike on update 1969 where I got errors for the last few modules.
will test and report back with any issue.
Edited by Logan2194
Regardless, thanks for the info. I have the file, but as a new Octavia owner (less than a month) and currently not experiencing any issues whatsoever (touch wood) with the infotainment system, I'm quite reluctant to mess with it. If it ain't broken, don't fix it kind of thing....
Yes you can update with running engine did it myself this time and no issues. Do you have warranty when yes better update by dealer.
That's what I did with the update to 1941, left the car running and all went well.
No warranty mate as bought used
So like me ok
No problem.. all fine
Hello,
i'm located in morocco this is the version of my software 1900, can i use this version shared here ?
42 minutes ago, souflam said:
Hello,
Yes I'd imagine so, I ran the update to 1985 from 1896 following advice from a VAG software specialist. Seeing as 1900 comes after 1896 I'd have thought it would be good..?
I can use this version of logiciel for my skoda octavia mk4 in morocco?
