TIRE
does anybody use different tire than goodyear?
I find the factory Goodyear EfficientGrip too stiff — every road imperfection is felt very clearly through the car. It’s a homologated tire, marked AO, meaning Audi Original.
Has anyone switched to a different type of tire? Which one worked well for you?
I tried the Toyo Proxes Comfort. It was indeed more comfortable, but at higher speeds it caused a noticeable side-to-side vibration through the steering wheel, so I switched back to the Goodyears.
However, they’re not very comfortable. Does anyone else find that road bumps and imperfections are felt this strongly with the Scala?
Which country are you in? Would all-season tyres not suit you? How about saying what size tyres you have on, and what Speed & load rating they are, & are the XL (Reinforced) Also what tyre pressure you set at? There is a tyre / wheel section on Briskoda.
I didn't know.
I'm from Hungary.
205/55 R16 91V
2,2 -2,3 bar
So far, I’ve only tried the factory Goodyear, which is homologated, and the standard Toyo. I noticed that Nexen also has homologated tires. Do you guys take the AO marking into consideration when choosing tires?
Edited by thomaser07
Nope I pay absolutely no attention to the homologation / AO etc. markings.
I simply look at reviews an find something that fits my requirements then buy it at a price that suits. Here in the UK next to the Pennines that has generally meant a tyre that prioritises wet-weather performance over dry grip and over the past few years given the need to deal with snow on a fairly regular basis through winter, has meant All Season Tyres.
what do you use?
I have fitted last fall Michelin Crossclimate 2 205 55 r16 size for all seasons, and it's much better tyre then factory.. still noisy but handling is better
That's perfect tire!
What kind of difference in handling do you mean?
Were the factory-fitted tires Goodyear for you as well?
On highway car is more stable on high speeds. Yes, I had Goodyear tyres
1 minute ago, thomaser07 said:
what do you use?
Over the past few years on various Skoda's and other cars I've used Vredestein SporTrac, Falken Azenis FK520, Falken Zeix ZE310 Ecorun, MIchelin Cross Climate, and Goodyear Vector4 Seasons.
I've also got some old Goodyear Hydragrip and Goodyear EagleVentura and have also used Vredestein HiTrac and my daughter's Citigo has Falken Sincera SN110 and iLink L-Grip 55 (the latter not fitted by me) which are all decent.
Choices I would NOT use are Goodyear NCT and Goodyear Eagle F1 and Dunlop SP01 Sport as I've had them and they were poor.
I have had GT radial FE2 for a few years on my Octavias and also a Seat and pretty good tyre all round. Good in dry and wet. Sons got GT radial all season on his Fabia and also excellent in dry,wet and snow. Not too expensive either.
Alasdair
Has anyone ever put a different size of tires on their car? I currently have 205/55 R16 tires. I want to switch to 195/60 R16 tires to reduce the load on the car's suspension and increase clearance.
Edited by Zelinski
The Wheels and Tyres are 'Unsprung weight'. How much lighter will the narrower tyres be? It will depend on what is fitted, type, tread depth, reinforced sidewalls or not. Plenty have changed to that size, maybe for Winter Tyres. Lots of threads on this forum.
Edited by Evolution13
