Exhaust warning light
Good evening
I have a 2019 Skoda Superb.
The exhaust warning light came on a week or so ago. I ran my OBD Eleven and I can clear the warning light. However it does keep coming on. Having had a similar issue with my previous Superb my partner suggested driving it at high revs for 15/20 minutes which we did.
I cleared the light, but the next time I went out in the car it was back on.
Any suggestions or advice will be gratefully received.
Best give some clues like WHAT ENGINE, how many miles done, when was it serviced last. Could there have been some issue with the last fuelling of the var?
It's a 2l 150hp engine that's done 118591 miles.
Oil change done at 118488.
Last full service 12/09/2025 at 112689.
Last fuel fill up on 21/09.
Light came on either 27/09 or 28/09.
I ran the OBD Eleven on 28/09.
Diesel
What’s the error on OBD11?
Driving at high revs heats up the exhaust and helps cause a passive regen (burning off the soot) but if that’s not the key issue then it’s not the solution to the problem.
You could have a sensor breaking down which is sometimes causing an implausible signal - driving at high revs does nothing for that.
Thanks for your response.
Well that's the thing it doesn't come up with an error code. On the scan page it shows the same symbol with CHECK, but it doesn't show anywhere that I can see as an error code.
I will run it again tomorrow and see if there is anything that I've missed.
I ran the OBD11 again this morning.
It shows the exhaust as a passive fault with no error code - photo attached.
I emailed the results to myself before clearing the codes. Nothing on them for the exhaust, they mostly relate to the doors!
Any ideas??
Doesn’t give much to go on.
Although the yellow battery indicator on the right; is OBD11 saying battery is one of the error codes? A battery on its way out is famous for all the most random errors - can you get a decent tester on it? How old is it?
No error code for the battery.
I have no idea how old it is (I've had the car for 3 years) but I know that if I put it on charge it charges up quickly. Maybe I'll put it on charge tomorrow.
I should say that my car gets used for lots of short trips, nearly every day down the road for about a mile and back up again.
I need to use my other car more see photo ........but only in good weather! Or walk down and up.
I'd suggest getting the battery properly tested first.
There is probably a date code stamp on the top surface of the battery neg. terminal, code format is WW/YY.
If the MIL (check engine) indicator is lit, there should be a DTC logged - perhaps your OBD reader is incapable of reading it.
What charger have you been using?
Edited by Warrior193
question
Thanks for you reply.
I cleared the light and charged the battery yesterday.
Started off today and the warning light came back on.
Below is a photo of the battery.
I think it was manufactured in 2022.
It seems to need charging more often than expected so it maybe needs replacing.
We have a Streetwise intelligent charger.
Yeah my OBD11 is just basic, although I think I can buy credits to run a more detailed check or I know of someone locally who i think has the relevant code reader. I need to catch him and ask if he can run it for me.
The joys of motoring.
If you have OBD11 you need to figure out how to use it and read the DTCs...
It says there are 6 control modules with faults which means there are at least 6 Pcodes available.
It's pointless guessing what the fault might by based on an icon in an app.
The engine light can be related to lots of different faults from sensors to actuators, battery to communication.
Gabbo
If you cant figure out how to use OBD11, you can download Car scanner or OBDTorqueLite.
They are not as nice looking or user friendly but they can diffinately read the DTCs in each is the modules
Edited by Gabbo
Gabbo
Thank you for your reply.
I'm just a little old lady with a Superb I love to drive 😉.
Here are the Pcodes
P06DA00 Engine Oil Pressure Control Circuit/Open static
P064C00 Glow Plug Control Module static
There are also these Bcodes
B10AF04 air con
B122D29 central locking driver, passenger and rear left doors
B122B12 as above
B122B11 as above
B105413 GPS antenna
Be good to know where I go from here, possibly not in my Superb 🤣.
All advice is very gratefully received.
Edited by Tresco
As that is probably not the original battery, it is possible that it was not correctly adapted (coded) when it was fitted (possibly 2022?)
It's quite possible that it is failing - failing battery can cause multiple issues even though it still appears to start the engine normally.
I'd strongly suggest having the battery properly tested first.
These are the 2 codes which are causing the engine light & what you should concentrate on:
Checking the battery is cheap and simple but usually you have lots of other warnings & messages on the display with a bad battery (ACC, park assist, Tyre monitor, etc not available after starting).
Next I'd check the fuses for both modules (or perhaps they have a shared fuse) to make sure it's not just one of them blown.
Otherwise I'd suspect something electrical as they are not really related.
When you charge the car at home, do you connect the ground off the charger to the charging point behind the battery (not into the terminal of the battery) ?
Gabbo
Edited by Gabbo
Thanks for the reply.
It clearly needs more investigation.
I may have to wait until my partner is here.
He thinks it maybe the glow plug control module.
I don't get any other messages re park assist etc. On my old Superb the first thing to play up when the battery was low was the stop/start.
I'm sure I can check the fuses with my partner's help.
Yes when I charge the battery I connect the ground to the point behind the battery.
I’m guessing there’s an allusion to using the ground point - I’m still old school and connect to the terminals. Is it better to connect to the grounding point?
Recently Browsing 1
