  2. scottymcstig joined the community
  3. Welcome to the forum. Who is the supplier - are they reputable? Is there any visible mis-alignment to hatch? Likely the catch is faulty, return it and source another from a reputable supplier.
  4. Warrior193 started following Boot latch
  5. Not sure for the Mk4 - but the drains should be visible at either side of the scuttle. NB. you may have to remove a layer of dirt to reveal the drain openings, they are fairly small.
  6. Today
  7. Xurde started following Constant app updates
  8. Don’t worry. More AliExpress items en route!
  9. Bet
    VAGCF replied to Bet's topic in Skoda Fabia Mk4 (2021 > )
    That could be the problem if it's anything like the stupid design of my Audi TT. With that, if the scuttle drain gets blocked the water overflows the scuttle and has run into the car. With you having the car facing uphill then this is more likely to happen as there is less of a barrier to stop the water running in. If the drains are clear you should see water running out under the car if you run a hose into the scuttle area.
  10. oooooooohhhhhhh im telling...... you're cheating on Aliexpress 🤪
  11. Thanks , but links in this doesn't works.
  12. I found this tutorial on YouTube really helped me uplift mine.
  13. I am saying a MPI does not have a turbo. So going by what the OP said.
  14. Belky joined the community
  15. johnche joined the community
  16. good evening everybody . I am looking for software to my octavia mk3 2018 . below is soft already on unit and i assume MST2_EU_SK_ZR_P0480T is next one . thanks
  17. Thanks Alasdair, I'll have a look. Does anyone know if it is safe to short out the plug to the sensor, and if so if the alarm still shows it must be the wiring?
  18. edwdom started following pab567
  19. Replacement mirror unit installed and now all working again with no error codes.
  20. Fix thermostat and sender and see. At least the car should run at right temp. If the symptoms happen after I would, get it scanned to see if there are any stored codes that could point you in a rough direction. Had a quick google and wiring loom for injectors I think goes under rocker cover/cylinderhead area and due to the heat and oil is prone to failing over time and usually when engine hot. Alasdair
  21. I find the Briskoda forum equally chaotic as Skoda and my local dealership. As to whether or not you have a turbo engine version I couldn’t say but others are jumping straight in and saying the Comfort model doesn’t come with turbo. There is such a mish mash of specs for the Fabia that only you can find out exactly what you have. Below is what showed when I asked on Google for detail on the engines.in the Fabia Comfort. AI Overview The fourth-generation (Mk4, 2021+) Škoda Fabia SE Comfort is most commonly paired with a 1.0-litre 3-cylinder petrol engine in 95 PS (94 bhp) or 110 PS (108 bhp) outputs, with 1.0 MPI (80 PS) and 1.16 PS variants also listed on UK market specs. [1, 2, 3] Common SE Comfort Engine Options (1.0 TSI 95 PS Manual) Engine: 1.0-litre (999 cc), 3-cylinder turbocharged petrol (EVO series) Power: 95 PS (~94 bhp) Sklinda, I’d try to part exchange it for something more suitable for your needs. It’s never going to be a vehicle you will trust or enjoy. I wish I’d bought a car about 10 years old instead of a new Fabia. The extra few units of horsepower from the turbo were planned to get us out of any tricky situation on the road. Instead, we have been rewarded by “limp mode” when power is required. There’s lots more I could say about the Fabia but it would be a waste of time here. It’s worth pointing out that there are garages that specialise in VAG cars (includes Skoda) if you decide to keep the car. I’ve used a local garage which has always been supportive and informed but they are not able to access the full range available to specialist technicians. Good luck.
  22. Hi dmjma and welcome.
  23. minsy started following Hi All from England
  24. Right now the area round the cig lighter socket resembles a rats nest of wires, I have a double outlet socket that is feeding my Head-up Display [2 speeding tickets] and now the cold has set in I have installed my heated front seat covers, both these being fed by the permanent live socket, I am terrified of one day forgetting to pull the plug and have a totally dead battery as a consequence, is it feasible to get this socket fed by an ignition on only supply. I have successfully hard-wired my Nextbase dash-cam & have just updated it by installing the 222x which has both front and rear cameras in one unit, fortunately it is the same wiring making it a quick job just to swap cameras
  25. Or increased it's pressure from the setting it was set at when the likes of a sticky brake or bearing failing causes a wheel to heat and the air in the tyre. Lets ignore that in your case, but that is something not uncommon that triggers a TPMS warning. So not jus a loss of pressure and circumference and more wheel rotations. Less wheel rotations can be detected. But then when 1 new tyre with full tread gets fitted to a car with this TPMS maybe even over inflated you can reset the TPMS and it logs that as a thing.
  26. Hi All, Just got a 2020 Skoda Karoq 2.0 TDI Edition 4x4 😀 Trying to get to grips with the Skoda way of doing things, but loving the drive. Cheers dmjma
  27. dmjma started following Hi All from England
  28. So @Sklinda Is your Fabia a 1.0 MPI engine car with a 7 speed Dry Clutch DSG?
  29. dmjma joined the community
  30. Bet
    Bet replied to Bet's topic in Skoda Fabia Mk4 (2021 > )
    The first time was after torrential rain,so we thought it was rain coming in. The second time we hadn't had any rain for two days but we'd jet washed it two days before ( purposely to get it wet). The car is always parked on our drive on an incline ( engine up).
  31. Bet
    The first time it happened, water/ fluid ran down the front doors. The second time it ran from just above the glove box. Skoda have "looked" at the car but found it to be dry, so it's not faulty. They have "looked at the scuttle and said it was dry but obviously it could be blocked further down. Whatsnthe best way to check it please.
  32. Don't know much at all about diesel engines, sorry.
  33. @Breezy_Pete Was wondering if you had any ideas on this? You are the Great Wizard of All Things Skoda and the font of all knowledge I know that fixing the thermostat and the temp sender will help, but it will also bring the temp up sooner and thus the problems will occur sooner too ☹️
  34. Possibly rainwater from air intake in front of windscreen - check that scuttle drains are clear.
  35. Warrior193 started following Bet
  36. No there is no pressure limit shown, just an orange symbol on the dash indicating that the rear offside tyre has lost some pressure.
  37. Reset through the infotainment under the car settings, tyres menu, not the dash display. Set all four to the door placard cold pressures, store them, then drive normally so it relearns. Also measure the old tyre's tread against the new ones, a few mm difference can trigger this system.
