  2. I've used them maybe 6 times over the years, as said you really do need to do your homework to check that parts are correct for your use, I use an online VW Group parts listing to get the correct and latest version of the part numbers for my cars first, then make sure, for items like road springs, that my part number is the only one that is listed against their offering. My mate wakened up the other morning to an offer from them for rear brake callipers for his old SAAB 99 - both his rear callipers have seized bleed valves and they are the small type - he claims them to be 6mm AF but I'd think that they started life as 7mm AF and have "rusted down a size", so if his latest Autodoc purchase works then he can either refurb the originals or just snap the bleed valves off (worst case), once they are off the car. He's had wrongly supplied clutch parts in the past, but as, unusually for him, he paid the "safe order" premium, the parts got swopped over FOC to him.
  3. Did you manage to sort this out? At least on my wife's 2015 VW Polo 1.2TSI, the area under this clip is hidden as it is on a plastic body part that bolts down onto the next metal body part - probably the lock carrier in VW Group speak.
  4. kenyaq joined the community
  5. which is mileage of a car? no new engine, just crankshaft machining and larger bearing. maybe only new bearing.
  6. Now dispatched and should be arriving today!
  7. Today
  8. yes on eco 2 engines, but on evo 1 engine it is unlikely, The V-belt tensioner does not allow tension in the other direction, the belt could fall off, while the evo 2 tensioner is completely different. instead, With an eBay memory module installed behind the dashboard button, your alternator operates in a steady, conventional charging mode rather than aggressive regenerative mode—and it is actually healthier for your 12V battery over time. How Your Alternator Works Now Simulates a manual button press. Every time you turn on the ignition, the module sends a quick electrical pulse that mimics you pressing the physical Start-Stop "OFF" button. Aggressive coast-only charging is disabled. Because the car's Energy Management System sees that Start-Stop is turned off by the driver, it abandons the fuel-saving "recuperation mode" (where it lets the battery drop to ~80% charge while cruising so it has empty room to absorb braking energy). Constant, steady voltage. Instead of fluctuating wildly between 12.2V (cruising) and 14.8V+ (braking), your alternator now outputs a steady ~13.8V to 14.3V during normal driving. Smart protection remains intact. Because the battery sensor on the negative terminal is still plugged in, the ECU still monitors battery temperature and health, tapering off the voltage once the battery reaches near 100% state of charge so it never overcharges. What This Means for Your Car Longer 12V battery life. Standard recuperation cycles constantly undercharge AGM/EFB batteries (keeping them around 75%–80%), which accelerates sulfation and shortens battery lifespan. Keeping the battery near 100% with your memory module typically makes it last noticeably longer. No fault codes or side effects. Unlike unplugging the battery sensor wire, the car treats this as a completely normal user action, so all safety and convenience systems work properly. Minimal fuel difference. Keeping the alternator engaged continuously adds a tiny mechanical load to the 1.5 TSI engine, resulting in a negligible fuel consumption increase (typically around 0.1–0.2 L/100 km).
  9. I believe the COD system engines do use regenerative (micro-hybrid) charging - the alternator ramps up the output voltage during overrun and/or braking conditions.
  10. my friend which works in a battery shop told me to charge up battery to 100% once a month to prolong lifespan. and i am charging it. maybe diesels engine have regenerative charging but mine 2 cyl off system when release acc pedal, dont charge anything.
  11. Quite possible in some cases that the 'smart charge' algorithm is not helping by limiting the alternator charging to around 75% max - if the battery is consistently not receiving the remaining 25% through regenerative charging, this could be a problem.
  12. I'm happy for you that you have had good experience. I ordered from there 4 times and 3 times there was a problem. But agree that prices are competitive
  13. Following up on the previous email, they’re waiting for a shipment of thousands of those screws and will give me a call once they arrive 😅
  14. Reading this post answered my thought's as to use a usb cable or android auto from my phone for satnav. I will use the power socket in the armrest and connect via android auto.👍
  15. robsie started following USB cable connectors
  16. Don't know - that's all I have
  17. Long coding (changing the bits and bytes) is carried out to tell the vehicle what equipment is installed generally. For the tailgate opening and closing this requires modification of the datasets installed on the control module for the tailgate itself. Soft and hard reset restarts the control module (I am not sure of the difference) to ensure the new dataset is being used. VCP historically was the only tool available to edit datasets on control modules. However sometimes CarScanner can do it as detailed in the linked post above. BUT I have seen it where for an unkown reason CarScanner can not communicate with the control module. I am not sure why and I think it is dependent on hardware/software combination of the control module. As per the CarScanner FAQ: 4) In the current state of the coding, it says “Coding is not supported or faulty ELM327 device”, although other codings are applied normally. Should I change my adapter? No. You are shown two possible reasons: either the coding is not supported, or the problem is in the adapter. If the adapter allows you to use other encodings, then it is logical to conclude that the problem is not in it. By the method of exclusion, we discard one of the reasons and we are left with one reason: the coding is simply not supported by your car. The coding of tailgate opening /closing on key and internal button is very variable and some people have encounter major issues with the control module from just trying it.
  18. I've just tried to use one of the spare key for my 2024 Superb and it's dead. Changed the battery - still dead. Is there a way to re-programme without going back to dealer? Seen videos online showing reprogramming by using key in ignition, however, my Superb has a button rather than key slot for ignition. Any help greatly appreciated.
  19. Evolution13 is right that it changed in April 2026, but the change helps here rather than hurts. The Finance Act 2026 (section 97) set the line at £50,000 for zero emission cars and £40,000 for everything else, and it applies to any tax period starting on or after 1 April 2026. EVs first registered from 1 April 2025 are the ones in scope, which is what GOV.UK means by "this also applies to electric vehicles registered between 1 April 2025 and 31 March 2026". So for a car first registered in November 2025, any renewal from now on is tested against £50,000, not £40,000. If it was first registered in November 2025, the first payment covered 12 months, so the renewal due around now is the second time it's taxed, the first one at the standard rate. That one is either £200, or £640 if the price was over £50,000. One thing to add to my earlier post: the "price" in the law is the list price plus any non-standard accessories fitted when the car was first registered. So factory options count, which is why the spec of this exact car matters, not just the vRS base price.
  20. Not ABS. Need 3Q0 for Gateway. The Gateway gets parameterized. The DCC (Suspension) gets a software update. Nothing is done to the ABS (Brakes) module, for the DCC Mod.
  21. +1 to wat @Binx1310 said in regards to jacking up the front end, removing the front wheels and wheel arch liners. It is so so much easier. I replaced my xenons with LEDs a few years back now, with J.W.Speaker brand. Great quality, great light output, no errors.
  22. Hello, does anyone knows how the front RS badge is fixed on the grille? I ordered the RS emblem 57H 853 679 0RS and the dealer is telling me that the fixing plate comes with the grille. But I don't think this is possible. It is about the items 3A and 3B from the below picture. I found online the OEM code for this fixing plate, but can anyone confirm that this is the correct code and how is this plate mounted on the front grille? OEM code for fixing plate: 5E3 853 736 B ZD4 Thanks!!
  23. Cheers JR. I have 3Q0 on ABS and 5Q0 on the DCC/Suspension; is that what’s required?
  24. How long have you had them installed? Are they a lot brighter than the xenon?
  25. gord replied to gord's topic in Škoda Elroq
    Yeah but I thought luxury car tax only applied to EVs over £50k AFTER April 2025.
  26. gord replied to gord's topic in Škoda Elroq
    I bet that's not a Vrs though.
  27. I've got a 2023 Octavia 110tsi. Battery tested faulty during service last year, and was replaced under warranty. That battery replacement has once again tested faulty at this year's service, and was replaced again. Car was driven ~5000km in that timeframe. Seems to me there some systematic fault in the battery, or it could be that the dealer did not code the battery in some way.
