Past hour
Battery light 1.0 mpi 59bhp
So, as the alternator appears to be working, does this indicate a problem on the bcm? A dud led for the battery light is unlikely isn’t it?
Ceratec diesel additive to Octavia mk3 2.0 tdi
And for touring coaches. Went on a Leger Holidays coach trip to Italy this summer and chatting to the driver about all sorts (remember I used to own a 1950 ex-LT country bus!), he told me the oil had never been changed in 450,000 miles; just checked and topped up (if necessary) at its annual safety check..... Transmission oil doesn't get checked!
SwallownAmazon started following Ceratec diesel additive to Octavia mk3 2.0 tdi
Battery is new as a result of these lights and car has not been widely used since. @12.5v with nothing operating.
Just an old dog having to learn many new tricks with a Kodiaq PHEV
I don't suppose you've got room to chuck a 5KW genny in the back😁
Warrior193 started following Just an old dog having to learn many new tricks with a Kodiaq PHEV
Apart from the missing 'battery' indicator, the common cause of the others is either low battery SOC - or failing ABS wheel sensor. What voltage readings are you seeing at the battery terminals?
This is fantastic, thanks. There is 1 wire from the 4 way connector and I didn’t notice a splice. I’ll have another look. The bcm is not the same as the ecu is it? Do you know where is may be physically situated?
campaign
This page sets out the scope of the information that can be made available via a smart home app or any other app provided its developer does the necessary work: https://public.api.connect.skoda-auto.cz/docs
Are there two green/yellow wires emerging from pin 1 of that 4-way connector you've called 'engine block plug'? If not, I guess that splice - B549 - where the one green/yellow wire becomes two must be wrapped in the loom somewhere.
XrayCharlie started following Skoda Octavia Mk3 (2013 - 2020)
Circuit info for the alternator warning lamp (K2) just shows it driven by CAN info from BCM rather than showing actual electrical connectivity. So not hardware linked to alternator.
Chain, tensioner and guide replacement
Good afternoon. Am currently on 89k, chain is at -3.6 degrees via OBDELEVEN. Am thinking of getting it done, preventative only, car runs perfectly. Had a quote for £996 inc vat, without a new cam bridge. Charmers Inverness provided the quote. Anyone used them before? Cheers Graham.
Jonnyhatesjazz70 started following Chain, tensioner and guide replacement
Yeah, my bad. I started to type that in my first post earlier but then was struck by doubt. There is just the one, LIN bus control wire. Alternator right at bottom of this page. BCM right at the top. LIN data comms wire comes from alternator in blue, changes colour at 4-way connector pair to green/yellow then splits off to battery monitor control unit and BCM (Brown 46-way connector pin 26). Green dashed line shows the omitted connectivity between the two boxes labelled 18.
REZT joined the community
JD52 started following Regular False Tyre Pressure Faults
Today
- S3 owners - electric tailgate / hatch closing from inside
We have had to defer a long trip with the new car, planned for the coming week, due to violent storms cutting electricity to the area we were to visit. So, I'll wait until we have actually covered some distance before offering any opinions, other than so far we like it. Sounds dumb (probably is) but I have had to do some online research to find out some of the technical details of what we have bought. A lot of it is quite a new experience for me. The 1.4tsi in our 2014 Octavia was a relatively simple 4 cylinder turbo, but gave excellent fuel economy, and/or performance and yet was smoother than most other engines I have driven. I still love it. The 1.5tsi in the Kodiak builds on that and adds Active Cylinder Deactivation (yes, I know some applications of the 1.4tsi had ACT too), the 'remaining active cylinders' can oscillate between Miller and Otto cycles as befits power/economy demands, and a variable blade geometry turbo is fitted. Numerous other changes but I hope they have also upgraded the plastic water pumps that are prone to failure in the earlier models. From what I read in this forum, something that seems important to owning an 'electric' car is the Skoda Connect App. Unfortunately, this is not available in Australia and in fact the equivalent is not on any VAG group car here either. I have just read that Audi are soon to release their version here so hope that the lessons from that are passed onto other members of the group so we can eventually get Skoda Connect 🤞. Remarkably, the Kodiaq iV has a better drag coefficient (0.29) than my 'sleek' mk3 Octavia wagon/estate/combi (0.31) although the frontal area is much larger on the Kodiaq so the total drag will be higher, but still it surprised me. The big difference between the mk3 Octavia and the Kodiaq is the 400kg or so extra bulk of the Kodiaq and that is going to have an effect on handling and economy. More revelations of my ignorance of the technology and my insights into the Australian electrical infrastructure and recharging facilities and costs to come.
There’s only 1 wire from the alternator connector - blue one. Goes to green/yellow from the engine block plug
Will look shortly, but that may be the LIN control wire rather than the exciter.
What have you done to your Kodiaq today?
It is scary how quickly time goes... I met my wife when I was 21 and my eldest is now 22. The intervening years have shot past.
Regarding warning lights - non today!?! Previously though front assist, rear parking, tpm, other tyre/wheel associated ones and occasionally stop/start. I’m guessing wheel sensor with these, but the battery light is confusing thinking. Could be 2 (or more!) different problems I guess. Random lights have been in the last 2 or 3 weeks but the battery light may not have been lighting for longer.
Going through the obd11 data it claims the battery has a total energy throughput of 14,500ah. VW claim when it reaches 16,800ah( for a 70ah efb battery) the battery is coming to it’s end of life. You multiply 70ah x 240 for EFB’s. For Agm’s you multiply the 70ah x 360.
I tracked it to the battery module and checked continuity and its good. I guess from there it goes to the ecu?
We have passed through your phase of life and are entering a new one where we needed a bigger, newer and safer car (Kodiaq Phev) to cater for a pending exponential increase in additional grandkids. A combination of three child/baby seats across the back will probably do for now. I must admit I did not think that retirement would be this busy, or this much fun.
From what I've seen in other posts, most likely to be the ABS wheel sensor - I'd suggest having the OBD checked for any logged DTCs and get the NSR sensor replaced if that shows up. Is there any significant difference in wear between rear tyres?
Warrior193 started following Regular False Tyre Pressure Faults
Replacing gearbox - the replacement gearbox has different speedo gear
I saw this too late, yes it is removable i have posted photos from the tip of this cable, it's square shape and i have lubricate it (plus the whole wire) before install it back.
In the last month I have had 6 Tyre Pressure Faults arise (5 of which have been for the same tyre, Rear N/S). However every single one has been false as when I check the pressure it is fine and matches the opposite side tyre. I was leaning towards a faulty ABS sensor but my assumption is that I should also be seeing ABS/ESC faults also as it's my understanding the sensor controls this elements also. Octavia III Estate L&K 2015 Anybody have any ideas or guidance?
CaptainHaddock70 started following Regular False Tyre Pressure Faults
DCC Slider adjustment option mod
Sadly changing the Gateway is no trivial matter - sorry. It's at the centre of everything. Everything talks to it. I personally wouldn't change it just to get the DCC Mod.
