  1. Yesterday
  2. Thanks for that. Found one on eBay for £30 which is slightly more tolerable than new at £80 odd but now know what vehicles they’re from so I’ll keep my eye out…
  3. Challenge accepted
  4. @Zlatko580 Hi, Could you summarize exactly which train versions this solution is compatible with? Thanks in advance 👍🏽🙂
  5. Timber2b joined the community
  6. Ok, thanks. Appreciate the reply nonetheless.
  7. It’s borrowed from a VW, won’t put the full model Part number is 3T0 947 417 F 9B9 I can get a clearer picture tomorrow if needed
  8. Mine is 3T0947417B. Looks like it goes up to E. I’d be keen to know your part number @Danoid it’s on the inside under the battery cover. Mind you it’s £80 odd from Skoda so swapping might be the best way of getting one!
  9. If this is the map update I think it means engine running. It will do it as you drive and auto continue in the background from where it left off. You don’t have to do it in one go.
  10. I have just dowloaded the update via the portal. been waiting on a new sd card and laptop being returned. the instructions say the engine needs to be on for the duration of the update. is this the case or does it mean the ignition on. cheers
  11. Pricklythistle joined the community
  12. Hi @pab567 567, I'm looking for firmware MEN2_EU_SKGPx_P0080L_8755 for my Skoda Fabia. Unfortunately, I can't send private messages yet because I'm a new member. Is there another way you could share the download link? Thanks!
  13. Toensie joined the community
  14. Hi everyone, I've just bought a 2022 Superb 1.4 IV Estate and day one I love it. Probable will have many question as I get into it, so please be patient 😁
  15. wbarge started following Hi, new user
  16. wbarge joined the community
  17. fraizzo joined the community
  18. Reynard001001 joined the community
  19. What about one of these... https://reversee.co.uk/
  20. This tempted me once. But as I have good relations with my dealer and the whole team. I thought it wouldn't be fair... I've kept my yellowish torch light.
  21. I think it should. Just have a look on ifinterface.com and compare the P/N of your own one and the P/N from a 2023 FL version (the latest manufactured Mk3).
  22. Sunset over Mordor? :)
  23. A total of 4 Abarth in this small car park; just a shame not enough spaces for the fourth to line up with these, and the third is parked nose in.
  24. You missed your opportunity when yours was in for the work!
  25. Just go to the dealer and do it whilst looking around a car….. hmmmm
  26. Also another thought. If it is OEM does it have a part number on it. I wonder if they can be bought from Skoda?!
  27. A few more from today. Sun was setting on the return journey so snapped some more.
  28. Very jealous. I came to the forums too late for @ApertureS to be doing the cool white upgrades. Was it from a newer Skoda? My father in law has a new enyaq, I wonder if I can swap it without him noticing…
  29. Got to try out my new boot light, fairly impressed It’s a direct replacement courtesy of a rental car, company played me about bit, so swapped my old warm looking rechargeable torch, that’ll teach em 😂
  30. Misty today.........
  31. The only proposed Duracell for mine is unfortunately too high and too short...
  32. Nothing over bumps. Just when releas and press aceleration pedal in low speed and low gears. Thank you for test
