Past hour
ACC control
To Stonekeeper. That was a very comprehensive answer and in line with my own understanding of the Superb mk 4 ACC system. Very well done sir. Also to CNC. Thanks for the link to Dave sells Skodas. I have always found his videos quite informative. Thank you for your input. Keep it up guys. 😀
Stuartie started following ACC control
Today
Yes. Red/white wire is constant positive feed to window motor. The brown/yellow is a switched earth that is activated by the door catch and tells the control unit when the door is open/closed.
I assume fitting rear puddle lights. You’ve tapped into the correct wires so they come on when the doors opened ? 😃
Jamiek started following Superb Mk3 Estate 190PS TDI DSG MY2015 SE L Executive - Moon White
Photography Thread
Took a trip to Donna Nook earlier 🦭 VID-20261129-WA0045.mp4 VID-20261129-WA0043.mp4 VID-20261129-WA0040.mp4 VID-20261129-WA0041.mp4 VID-20261129-WA0042.mp4
Octavia VRS 2.0TDI DPF Issues HELP
Hey guys, recently became the owner of a 2014 octavia vrs 2.0tdi. shes currently @ 292xxx Kms and I have constant regenerations and my differential pressure at cold idle is at 50hpa, normal should be around sub 10, and during acceleration @ 3000rpms tops out at 900hpa. im looking for advice to see if this car is worth investing into or if i should just get rid of it, it has a decent service history with the turbo being replaced at 202xxx kms but i havent been able to establise whether or not shes burning oil, theres no weird smoke or pressure coming out the oil cap and dipstick, turbo and dpf look bone dry - no obvious signs of leakage, exhaust is bone try and oil doesnt smell of diesel - just a normal dark colour. anyone able to recommend some checks for diagnosis ? ive talked to a few mechanics and all say the same thing, a dpf clean is only temporary if shes burning oil or has a bad crankcase breather its pretty much a full emissions system rebuild.
vaxny started following Octavia VRS 2.0TDI DPF Issues HELP
Fifth gear popping out (gearstick)
Hi all, 1.9 TDI 2005 estate. I assume all original parts for gear system. Started a couple of weeks ago on the motorway; the gearstick popped out of fifth and so the revs shot up etc. Put it back in and all was well (this is Newport to Tenby). On the way back started fine then again once we'd been going an hour or so, did it again. This time, several times. You can hold the gearstick and almost feel it resisting, like something wants to pop it out. Didn't need to use it subsequently around town once back home; gears one to four are absolutely fine. Had it booked at a garage with a two week wait time; they took it for a test drive but it behaved normally. I took it out in fifth for the first time today and it seemed fine too, though again after half an hour or so I'd say the gearstick 'twitched' in fifth (a small movement) but didn't disengage. Then was fine. Any ideas or anyone had this?
JamieH86 started following Fifth gear popping out (gearstick)
vaxny joined the community
Park Distance Control: please clean rear sensors - 2022 Octavia 1.4TSI iV
Evening, thanks for the info. Unfortunately my scanner is a basic one and does not read measured values in the parking aid module. Walking past the sensors does not make a difference as none of them are giving any indication on the car display. The display shows an exclamation mark for the rear parking sensors. See attached.
Add ons
Thanks I’ll have a read there’s a few things I’d like to do. The rear puddle lights make me think is it worth it as the loom isnt fitted
Boru joined the community
Add ons
Tacks, oil slick, smoke, spinning number plate, machine guns, ejector seat. Drop in a V12. Stick another one in the boot. Any of that work?
Add ons
Very much horses for courses. And skill dependent. I have done lots of bits and pieces to correct some of the age related issues with mine. In terms of retrofits I’ve added front parking sensors, reversing camera and upgraded to 9.2” infotainment screen. And a lot of other little upgrades too. I’ve also fully dechromed the exterior and added some other bits to match sportline exterior look. Full details of what I’ve done here: https://www.briskoda.net/forums/topic/537947-superb-mk3-estate-190ps-tdi-dsg-my2015-se-l-executive-moon-white/ Plans for future include: front bumper splitter and maybe pedalbox to improve throttle response. Longer term I’d like to lower it, add wheel spacers and/or maybe different wheels but that depends on the next few years MOT outcomes!
keywacat started following Reverse doesn't always engage on the first try
Nazdar lads; I've got a 1997 Felda with a 1.3 where reverse sometimes needs another try to engage. I had the tranny fluid replaced 2 weeks ago and of course that didn't solve my problem. I'm thinking the linkage might be the problem, is that what you more experienced lads would look into? Cheers; keywacat
- Skoda Octavia 2018 – MEN2_EU_SKGPX_P7381L Firmware Update & CarPlay Activation
ABS fault codes in VCDS but no warning light.
Yep, bit strange. I did the clutch reset thingy in between scans, and as part of that on the test drive did a couple of heavy braking / hard acceleration - it's looking like maybe I dislodged some rust or junk. I'll post findings if/when it returns. Thanks.
Wheel spin on moderate throttle
Get your wheel alignment checked, have a look for uneven tyre wear and make sure your pressures are what they're supposed to be, preferably with a proper tyre pressure gauge because TPMS isn't universally perfect.
Austin Allegro V6 Street sleeper project by Jonny Smith Car Pervert.
Part 13 is now online. http://youtube.com/watch?v=DadcHQc4hz4 With some amazing cars.
SamSW_ joined the community
Regular False Tyre Pressure Faults
& a dragging brake or bearing on the way out can heat the hub, wheel so tyre and increase the pressure so the circumference and cause a warning. So it is one thing checking the pressures once cooled down. But when you get a warning stop as soon as you can and see if hub hot and check the pressure then.
Evolution13 started following Regular False Tyre Pressure Faults
Reading off DTC's certainly will help. One thing it could also be is a sticky brake caliper. From experience on another VW group car in the past, I had a rear caliper that was dragging and it popped up the tyre pressure loss indicator until it was stripped and cleaned. These ABS based tpms systems use rotational speed to determine tyre circumference, so a change wheel speed due to a brake dragging can be interpreted as loss of tyre pressure.
paulski started following Regular False Tyre Pressure Faults
Problem with humidity in the cabin and fogging windows
Kodiaq steering wheel vibration
Do you have any new information?
In my case, i have almost no vibration at all. But it’s cold now, it gets worse when is hotter.
RAPID 2014 1.2 tsi
Thanks again Pete for the info. I am beginning to think I may need to take it in somewhere and get confirmation of where the leak is and a price to sort it.
Dry mats don't mean a dry floor. Lift the front carpets and feel the insulation underneath, especially in the footwells. On the Mk2, blocked scuttle drains can let rainwater soak in there, and it evaporates into the cabin as you drive.
do you have a Climatronic system?
JP17 joined the community
Octavia Mk3 (5E) KUFATEC 43340 Heated Seats Retrofit – VCDS Coding Without KUFATEC 41899
BCM dont Support? BCM Change need odis online, because BCM have CP
