  2. I can do one in about an hour and a half on most VAG cars without rushing, I'm not a qualified mechanic and that's working on a jack on the workshop floor. I'd be seriously impressed by anyone who hits the 30 minute mark. I'd say about an hour per side. Bear in mind, labour rates have gone up a lot in the last few years.
  3. Redboy posted a topic in Skoda Karoq
    After 18 years of Skoda ownership I thought I could sort all the little annoying noises. Each Octavia, Superb and Karoq has had its own rattle or quirk. Both of my Karoqs have developed the same binnacle rattle in the cold. However I was stumped by my current car's squeaking driver's door as it opened or closed. Door strap and hinges hav been coated in grease and silicon spray etc to no avail. My friend has a new Karoq SEL and immediately knew the source. On the door's bottom inside edge is a black rubber strip, it's front tapered end runs along the door sill. A dab of grease stopped it.
  4. Redboy started following Squeaky door fix
  5. Fortress53 joined the community
  6. As a diversion - I'm going to pay much less than the advert - for a new car on PCH. But I'm not in a hurry. Just a thought.
  7. received a package today...
  8. Do you have two phones? Maybe answer is: "The number 1 or 2 indicates which device is connected in order. Škoda infotainment can hold two Bluetooth devices at the same time."
  9. About an hour per side for the CV boots then more time to check the alignment. Thanks. AG Falco
  10. Today
  11. Don't think you will find AT tyres in that size. If it is through the tread there is a possibility of a puncture repair. Thanks. AG Falco
  12. Thank you. That sounds like a logical explanation but it wasn't open. Could there be a reason why the warning system thinks the boot is open?
  13. Yes 4 years and/or at 40K Miles with air filter at 6 years and/or 60K miles, which ever is first. I always do the air filter when I do the spark plugs as you need to take the air filter off to do the spark plugs anyway. Thanks. AG Falco
  14. I just bought the AAWireless TWO+ and it works flawlessly on my 2018 Skoda Rapid. Worth every penny! Thanks for the tip!
  15. It sounds like it was telling you that the tailgate/hatch was open.
  16. Simon24ct started following Ashbe89
  17. Ashbe89 started following Simon24ct
  18. Ashbe89 joined the community
  19. It's possibly the so-called safety system warning you of some danger it imagined.
  20. I was driving peacefully along when a loud chiming started, along with a flashing white image of the car body which seems to be highlighting the rear window. This was 5 minutes into a journey. My fuel range was showing 210 km. I stopped and turned off and checked that all the doors and boot were closed. They were. I started up again, same thing. Any suggestions? Thank you.
  21. Just scanned for fault codes and got a few come up. It feels like it tried to move a bit but is stuck. Will try to take cap off tomorrow and see if I can see why it’s stuck or anything obvious.
  22. They would only be used on snow, have had chains before so no difference . Car and hence tyres are new and don’t intend to buy a new set of tyres yet hence looking at socks in case they are needed. Last street we lived on had speed humps on a hill and when the snow froze they were e impassible unless you were going so fast that it was dangerous.
  23. LongDitton joined the community
  24. The Toyota and Hyundai will have had closed pressurised coolant loops with a separate system. one for the petrol system and the other for the power control unit, inverter / converter. The hybrid battery with Toyota and Hyundai uses cabin air cooling.
  25. VCP
    Tom1214u replied to andyvee's topic in Diagnostics & VCDS
    Apologies, but please someone contact me or here in regards VCP Already posted about it. Apologies if twice still learning website etc. It will be much appreciated for any help Thank you
  26. Tom1214u started following VCP
  27. You cannot do it by long coding. It has to be done with datasets. Soft and hard reset restarts the modules. It says bad elm obd module when it can’t read or write data. Doesn’t mean your device is bad. Have a look at this post. If it doesn’t work it cannot be done.
  28. Please anyone can get me in touch with vcp locally to Hereford ( happy to travel 1hr or so) Seen Ludlow but can’t message Thank you
  29. Hi Everyone I've not a clue when it comes to mechanics, including how long a job should take, so may I ask for your help please. In a nutshell my Fabia Combi failed the MOT test on the following 2 defects: 1)Repair Immediately (major defect) Offside Front Outer CV boot - split or insecure, no longer prevents the ingress of dirt. 2)Repair as soon as possible (minor defect) Nearside Front CV boot - leaking not split. I had the required work to replace both CV boots carried out on the day of the MOT by the garage (an independent business) who then re-tested the car which it passed with no advisories. I paid the bill at the time, however after studying it, I'm currently querying the invoice with the garage and it would be useful if anyone can advise me how long, time wise, it should have taken a trained mechanic, in a fully kitted out workshop to replace both the CV boots. I wasn't advised at the time that any difficulties had been encountered, nor have I since, so I presume it was a straightforward replacement of both CV boots. Asking the question on AI it suggests 1 to 2 hours total (roughly 30-60 minutes per side). Is that about right or should I take those times with a pinch of salt? Thanks in advance for any help.
  30. Also meaning of soft/hard reset and what will it change please
  31. @Binx1310 do you know what that means? If I change as on this photo you reckon will I be able to do successful coding of closing via button inside?
  32. Yes able do other coding but not all if that make sesne. Wonder why sayings faulty etc especially both of them genuine too. Very frustrating…
  33. Hi. My car’s steering box was replaced by the service. I know that if steering box is replaced calibration should be done. But the tech said that there is no need to claibrate. Can you tell me whether calibration should be done or not. If needed which procedure should be applied that is to say static calibration or dynamic calibration?
  34. I've had toyota and hyundai hybrids in the past and don't remember a sealed system before, but then again I may not have need to have looked,I wouldn't attempt to completely refill the system but a simple top up was easy
