Cairus started following Carista SFD2 support
- Thinking of buying a petrol VRS estate- Some help please
OccyVRS started following Jack Point , Thinking of buying a petrol VRS estate- Some help please , 1.5 TSi - engine mods - intake / exhaust etc and 2 others
Be careful with the clutch with a remap - the MQ200 isn't the best. Completely different engine. I've yet to hear an EA211 with a modified exhaust that sounds any good, but I'm prepared to stand corrected someday.
- OBD Eleven Mode Changes
DCC Slider adjustment option mod
All the data required for the mod can normally be found here.
No GPS Reception
p.s. Somewhat unsurprisingly, this maps update has made no difference to the intermittent 'No GPS Reception'. So a new shark fin is required methinks.
Dead battery in Sardinia — EFB vs AGM replacement & DIY registration (Superb Mk3)
Please remove your VIN @Lee01 @ColinD (or anyone else I can’t think of!)
- Yesterday
No GPS Reception
@ords Thought you might want to know, and thought it worth posting in case someone else seeing this thread encounters the same problem. In summary, I originally did the portal update download, the unzip, copy & paste etc to the Skoda SD Card on an Apple computer. But received a "Please insert a data medium with valid data info" on-screen error message when inserting the SD card into correct slot in the head unit. However, since repeating the whole process on a Windows pc, inc' deleting the Russia & Ukraine map info' to avoid any repeat, no disc space errors. The car is now reading the SD card, and the maps are updated to the 2020/2021 version. Which is the most recent update available for the MIB1 set up. The following was pointed out above: Not 100% sure if the platform caused the issue of the system not reading the SD card/data, or if the process just needed to be started afresh. But, thankfully, it's now working. Thanks for your input everyone, this matter is now resolved.
235/40/18 Tyres on 8.5" wheel - Mk3 Estate
https://www.tyres-pneus-online.co.uk/tyre-equivalence-advice.html https://www.willtheyfit.com/ A 225 on a 7.5J isn't stretched - the Gemini wheel is just a slightly unusual design with a very prominent outer lip. On an 8.5J I would be running 245. An 8.5J ET45 will have 18.7mm more poke and be 6.7m further inwards. I'd personally pair an 8J with a 235, but you'll be fine with an 8.5J providing it is ET45. Any less than that can cause scrubbing.
Jack Point
Bit late to this, sorry. I use the inserts on my Octavia. Rather than having them in permanently, I have sliced the flange off and am able to pop them in an out as required. The first time I used them, I pushed one into the hole and ended up having to drill and cut it out. The pinch welds are only designed to be used when on a proper lift, or in an emergency. Everything else should be done via the frame points, or the subframe. I have the cut out/slotted jack pad, which only ruins the underseal. The insert is the one you want, but make sure you don't get it stuck like me. They can go at the front, or the rear, and the rear has two positions for them.
Tyre rotation
There is a logic to the process to get the longest life from your tyres with a decent tread. FWD front tend to wear first and often at the outer edges first. Back ones wear very slowly and normally more even. RWD rear tyres wear first and the front wear at the outer edges first New tyres only have 8-9mm and you should really change at 3mm So on a FWD when they are due to change the front the back will probably be at 5mm so you put the back on the front and new on the back, within a few month you need new front again so you do it again and have bought your full set spread over a few months. RWD you need rears first so you probably just do that and when the front need changing later put the new on the back and the slightly used backs on the front. If rotated properly you will need four at a time (If i was someone who ran the tyres down to 1.6mm before changing i would put the new on the front)
Firmware 6276 source
Any chance of getting the firmware update sent over having problems with no sound via Bluetooth if I have the track listing showing many thanks
skodary started following Firmware 6276 source
Tyre rotation
I think you misunderstood "most worn tyres on the front", if the new tyres go on the back then the ones on the front must now be the "most worn". However Chris49 is intending to change all 4 but trying to even up the wear until that is necessary - so new tyres on back advice is irrelevant.
Tyre rotation
Don't think that "most worn tyres being on the front " is what is advised? "New tyres" go on the back and the least worn go on the front
Stonekeeper started following Tyre rotation
Tyre rotation
I use front to back exchange at 15k miles (ish) on my Octavia, and have done similar on all previous cars. Yes - change to some decent all-seasons as soon as you can, most summer tyres are rubbish when it's cold and wet, let alone actually wintery or muddy. Yes you need to check pressures and set TPMS through the menus on touch screen. As for having the least worn tyres at back or front - if you rotate as advised (advice on Briskoda or Skoda manual) you will inevitably have it sometimes one way and sometimes the other, but the difference in wear should not be great and if you replace the tyres in good time rather than waiting until they are near legal limit (which is pretty useless in wet or winter) you shouldn't notice the difference.
BazzY started following Tyre rotation
Tyre rotation
I’ve never liked the idea of the most worn tyres being on the front which is where you need the best grip for traction, steering and braking. I understand the logic is front end under steer is easy to deal with than rear and oversteer.
When will Epiq be in showrooms.
Under estimated demand so are now prioritising their own customers orders?
Stonekeeper started following When will Epiq be in showrooms.
Late March!!!!!! Ordered an Epiq through Octopus EV, just had a call. Originally December delivery, now due Late March!!! Issues across all Skoda vehicles apparently (or maybe just EVs?) Oh well, just have to keep the Mazda running until then.
Porsche Alloys - 5 x 100
EBay listed Please see link to my Porsche wheels and adapters I took off my MK2 Fabia If a briskoda member is interested I will give a good discount Up for £550 currently!
What have you done to your Kodiaq today?
New battery ordered. I've finally bought Varta N70 (70AH 760A SAE).
New to me Karoq owner
- What summer tyres do you drive on 19'' wheels with your Kodiaq?
Hi, Time has come to replace my summer tyres (235/50/19)... A bit hurried by a special bargain by the end of this month actually. I plan to have them replaced once my winter tyres will be on. This way, I can make a good detailing on my summer wheel and remove weights properly myself. It should avoid careless removal and damage on my rims when I drop them to have the new tyres fitted. I'm currently hesitating between Michelin Pilot Sport 4 SUV and Michelin Latitude Sport 3 SUV. Any feedbacks on either of these? TIA- Octavia Mk3 (5E) Facelift Heated Seats Retrofit – What Parts Am I Missing?
- Fob dead locked out? What if?
- Trunk Torch/Light - LED Upgrade
Thanx @Binx1310 I tried looking at mine to see what the bulb was like to see if I could replace it myself with the plastic started falling apart,, tried searching for another casing on AliExpress but could only find complete units so I’ll wait to see how your eBay one turns up- Google maps error / Android Auto, My Skoda
Hi you may right, I thought that too at one stage it may be the phone software and in the process of troubleshooting did make sure google maps and other such as android auto was up to date, in the meantime also the phone OS updated to one UI version 8.5, android version 16. I dig check and see that there is an android 17 and ui 9 software update but that isn't available in my region at the moment, don't know if that's causing any issues. I mostly connect with cable to keep the phone on charge and it connects to Android auto that way, but then and again at times I also use wireless too to connect, and it appears to do the same, it's just I've never encountered this issue before. I'm wondering though now that you mentioned OS and update Google maps if that is causing the issue. Maybe it is a bug. My phone is the galaxy A34. - What summer tyres do you drive on 19'' wheels with your Kodiaq?
