Everything posted by gumdrop
My Felicia has a broken windshield wiper
Find an engineering shop and show the tube nut bits they could make one if the cost suits you.
Accessories for the mk.4 Fabia .
Rubber Floor mats with a raised edge A boot liner that fits up the rear seat backs Just something for our increasingly wet climate.
Any new car always needs an accessories, whatever its trim level; Mine was a proper clock type, Tyre pressure gauge a proper hand filling gauge. What are the can't be without accessories nowadays
Gear change recommendations displayed on dash for Mk 4 Monte Carlo manual no longer accurate
I had a Fabia Monte Carlo estate and just used the gearbox to keep the engine spinning lightly in whatever gear suited me, the suggested gearchanges were largely ignore as they had little or no bearing on the real road conditions. Save your money,
Waze on Android Auto has stopped showing Notifications
I was reading that MICROSOFT has stopped supporting ANDROID apps. so they no longer work?? I have used wayze it seems very good.
Car won't lock after replacing fob battery
There is a limited (but adequate) time to replace the battery but also the battery must be the correct way up when inserted.
DSG gearbox repair price
The DSG is electronically operated I seem to remember someone having a similar problem on here, the problem was poor battery condition.
- Skoda Fabia mk4 video
Steering wheel Clamps, added security?
Apparently the Disc is best as the baddies just cut the steering wheel into pieces to remove the hooked on or over varieties.
Thanks for that but I'm not a fan of Halfords.
Thank you, it is as I thought, more a deterrent to be seen than taken seriously at the cheaper end of the range, the Disc being around £150.
I have noticed more people using steering wheel clamps for extra security, especially on key less vehicles. One in particular stood out, the Big Disc steering wheel clamp. Does anyone here use a steering wheel clamp, would you recommend it?
Remove rear seats
I tented with a Fabia estate and found that I could get almost as much in the car with the seats up as with them folded. Put heavy stuff across the rear seats, then fill the footwells then the boot with lighter stuff (this helps the handling) Later I did add a huge top box just to carry the Duvalay bedding rolls and some clothing.
10 years away from Skoda (and this site) - back again with a Kamiq Monte
Nice motor, mine has dsg, swapping for little Fabia 110 also dsg.
Adblue
Initially I used to carry a couple of litres of AdBlue, but the usage was so frugal (I was very surprised) you get plenty of warning to refill.
Best Skoda ever?
I have had two Yeti, 2x wheel drive 110ps they both towed beautifully, first my Eriba then my Orion. They carried almost everything I offered up including several Ercol captains chairs and all sorts of camping gear. It was quick, handled well, braked well and, I thought, looked amazing in and out.
New Fabia noise query
In a couple of years the Fabia will be electric and you might find it worth staying as a Skoda customer
New Fabia auto
https://www.skoda.co.uk/discover/download-a-brochure I have an SE-L on order (stock car)
I was told that a tyre manufacturer built a factory close to Skoda (Kumho ?) I had these on one of my Skodas, a premium tyre for mid range tyre prices, I found them excellent. Skoda are using Eco tyres from which ever company, these are often run at high pressures and have tread pattern for low speed rolling so at speed may produce more noise.
Battery? Seems very poor.
My milage is lower nowadays than previously, so I use my C-tek At Least once a month, battery charges overnight.
Adblue
Anni, Bexhillian is right you do need to clean up any spills straight away. Kitchen roll is good, with a sealable plastic bag for the used stuff.
Adblue
I used to buy my AdBlue from a VW parts supplier the price then was very reasonable and I also had two types of dispenser. One dispenser came with a small cap and probe the other was a long tube and cut out automatically when the tank was full. (actually they both did) I think the VW parts supplier advertised on e-bay.
Driving a DSG Auto
Thank you, I find the manual confusing as every version is included so I tend to rely on Briskoda. 😉
Driving a DSG Auto
I was told D and hold on the footbrake, for longer stops Handbrake and P . Neutral is for towing or some such function. I would love to know the official explanation
is dpf/egr still an issue with newer diesels?
I used premium fuel when towing It did seem worth it, the diesel was happy and I felt it performed better (I am sure it did) The result should have been lower ash.
