Engine hunting 600 - 1000rpm on idle
Well, if a sensor throws an "implausible signal" error, I would tend to suspect it of being the actual fault.
Traffic sign controlling ACC??
Yes. I am telling you how the package actually works, since that's what you;re complaining about.
By not switching ACC on. Part of the function of ACC is to reduce your speed if you have selected a speed above the ruling speed limit.
Catalytic converter discoloration
How can you tell? I can't see the cat itself; just the metal box it's contained in.
Hint; those are normal temperatures to reach when braze welding steel.
Intermittent hard /loss of brakes.
Easy explanation; you braked so much and so often that you drained all the vacuum out of the servo, and the engine/vacuum pump took a few seconds to rebuild vacuum.
My Scala configuration, comments please
Well, I wouldn't bother with the front parking sensors or the lattice grey rhubarb rhubarb. I did wonder about the kneebag, but I suspect it's something you'll be glad to have if you actually use it once.
Strange Traction Control Problem
That seems pretty good to me. I'd also check for something around 14.4v with the engine idling.
Octavia 2021 Seat belt and 7 Gear View
It's quite usual for an auto box (so I imagine a DSG too) to only show D when in an automatic mode.
Is it possible to retrofit steering wheel controls?
Well, post more then. Join in some of the Off Topic threads like the "First Word Thread".
Sorry we can't help more. My best shot for a "hard brakes" issue is a problem with the servo leaking vacuum or the vacuum line that feeds it being blocked. Actually, that gives me an idea. If that line is externally fabric armoured rubber, there is a known failure mode where it collapses internally, resulting in a loss of vacuum and hence of the servo assistance function. If there is such a line, then if someone squeezes it, it will feel squidgy.
Bike ride stats/Strava etc
@e-Roottoot Note the word "pedestrians". If you're riding, or even pushing, a bicycle then you're not a pedestrian.
Bad vibration at motorway speeds
Maybe the tyres are out of round from sitting still so long.
Installing vRS Suspension on an Elegance Model
I'd say that for £20 the pair, new top mounts make sense.
Fabia 1.2 HTP Oil Pressure light flashing
Red or amber? It indicates a different reported issue and fix either way.
I've got a 'knocking noise'!
Somewhat cheaper to diagnose and, if needed, replace an engine mount, than a clutch, never mind a gearbox...
M spline bolt exstractor
Or don't; they're easy to break and if they do you also have a lump of hardened tool steel in the bolt head...
Something metal come loose?
As @Liger1956 suggests, a front disc shield. Alternatively, one of the exhaust heat shields.
2018 245 vrs
About 272bhp; more with a remap!
Skoda fabia
Which says to me that the real problem is something else presenting itself as a MAP issue. I find myself wondering about a wiring problem or a bad spark plug. Neither of which I can do much more about over the Internet. Do you have an independent VAG specialist near you? They're often better and cheaper than Skoda main stealers.
Help me squeeze a few more HP or rather more important torque Nm out of my 1.4MPi 60HP 2001 AZF engine
Define "costly". A generic remap might be £400 (top end), for about 10% better power and torque on a non-turbo engine.
Skoda fabia
Yes, but was the recorded error code deleted? If not, then the car still believes it has a duff MAP.
Morning engine warm for TDI
@ords @Wino I'd go further and say that, when the gauge "reads" 90C, the actual coolant temperature could be as low as 60C.
Air con - strange behaviour
I agree, and can't see how that could be due to refrigerant either. Still, with a 4.5 YO car, an air con recharge is probably wothwhile anyway.
2018 245 vrs
For instance, the Russian consul is actually in Berlin!
