Fluorescent Yellow Wing Mirrors - Talk me out of it
Agreed. It's not chavvy, but do your really want to look like your big saloon thinks it's an endurance racer?
At speeds above 80km/h the power steering stop working, at consistent speeds above 110km/h some of the electronics stop working and the ABS and Braking red warning lights come on.
Also @Wino The reason I mentioned the alternator clutch is that it is a known source of failure when fitted, and easily checked either way. Similarly, it is not unusual for a control cable to pull off the alternator connector, and that's also easy to check. That said, since said cables are maybe 2cm shorter than would be ideal, if the easy visual checks (done) don't show a failure, you need to move on to continuity checking wiring, but again starting with the control cables.
Help, CAMBELT
You missed my point entirely; the reason for water pump changes on some engines is common sense, not service recommendation. Accordingly, the omission of such a recommendation on other engines is a reason to check other sources, not a reason to not do the work.
Skoda Fabia 1.4TDI 2007 Turbo problems - loss of power and high pitched whine
😞 Dead turbo.
Possible Colour Change!? Opinions Please!
Well, I've always liked Race Blue, and Black Magic is an ideal substrate for a metallic blue.
Ok, but I have a question first. Do you have white smoke and/or increased oil consumption since this noise started?
Help, CAMBELT
According to VAG the water pump doesn't need changing on the 1.9D or 1.8T either. OTOH it's 15 minutes work when the cambelt is off anyway, and has a life of about 1.5x the cambelt.
Help, CAMBELT
Well, if the cambelt breaks, a new engine is more like £5_500! An Indy specialist will be cheaper than a main stealer though.
Home Guard CCTV system.
I think it was a capacitor. It is now toast!
- Error service: leave vehicle only when selector in position p
Advice on exhaust system and downpipe
I don't know, but why do you want to even suggest to anyone vaguely competent that your engine is over-fuelling? (the usual cause of overrun pops and bangs)
Air conditioning unit retrofit.
Quite aside from the considerable cost, some of us (me for one) would rather have mechanical controls that stay put than a touch screen that can move controls.
Sudden Over Temperature warning
So maybe the thermostat intermittently sticking closed? That does seem to fit with all your reported symptoms.
2019 VRS 245 Oil Service Due Warning will not reset.
Not sure that matters. Mk1 and 2 will reset to/on fixed servicing if reset using the button technique and only need computer intervention if (re)setting to variable.
Main beam bulbs
No you don't! You may be enough of a fashion victim to think you need them, but no-one else should ever see that they don't match the dip.
Ah, should add that one or both of them do sometimes pull off the alternator terminals without the cable being broken.
and then all the yellow lights came on
Most likely, since ABS, traction control and TPMS all rely on the wheel sensors. Actually, more likely the wiring to the wheel, but the fault code will tell you which wheel.
Garage recommendations
AwesomeGTi
Scala,front tyre wear.
So you're running them under-inflated.
'slipping' starter motor - it spins fine, but does not seem to turn the engine until about 10s or more
Yes: They're even relevant so, in ascending order of cost:- solenoid or HVLT cable issue weak/old starter motor, or worn starter cog worn ring gear. Replacing this is a gearbox out job, so you might want to get the flywheel and clutch replaced at the same time.
Superb DSG 2014 loads of warning lights on dash board
OK, not what I was thinking of then.
Mac's Running Diary - edit jan '21 cycling too - edit jan 23 back @ circuit training,
@Gerrycan That really does make sense; for that matter, other people run on their insteps and wear the inside edges of their shoes.
- 378 replies
- ask questions
- chip in
- circuit train
- mtb
Tagged with:
What sort of usage pattern do you have?
brake pads
f you're not happy change them rather than waiting.
Zoe ZE50 one month on
Maybe they could even make you install metered chargers, and charge a fair (to everyone else) rate of fuel duty on charging electric cars?
