pab567
FREEDOMTech
Everything posted by pab567
  1. This means you have done something wrong. Use Manual SWDL and select all but emergency in Main and emergency in CPU.
  2. First of all: this is NOT Amundsen, this is SWING. Pls share VIN in PM.
  3. Yes, you can change all RequiredVersion lines to "0". It can be done befor you start the update.
  4. @Aciduzzo your antenna amplifier is 3V5 035 577 F:
  5. @augusto73roma you have to patch swdownload from toolbox and then start installation of 0480 firmware. It will break with some error messages - you have to modify metainfo2.txt (change "RequiredVersion..." lines from any version it has to "0").
  6. MIB STD2 Toolbox is the answer
  7. It's never Plug&Play. New unit must be reworked - patch must be applied for Component Protection and activations, unit must have coding and adaptations adjusted to match car's equipment.
  8. Yes, remote rework for single SD units is not possible. Another yes - swapping single sd card MIB2 unit in the glove box for a double SD card MIB2 unit means you could use a sd card patch to activate it. No need for the display unit to be changed.
  9. @EvilBono you must have SMS soldering skills, QNX knowledge and either UART or EMMC-SPI. This will allow you to load MIB STD2 Toolbox into your unit that you can later use to activate new features like SmartLink and othe FEC/SWaP activated features.
  10. Yes, I will contact you in PM.
  11. Weird, but sound issues are typical HARDWARE issue of dry joints in power amplifier ICs.
  12. I sent you download lonk for MHIG_EU_SK_K1552... what do you expect from the new firmware?
  13. Check your PMs
  14. Forget Chinese Android units, you need Bolero 5Q0035842x / 565035842 or Amundsen 5Q0035874x / 565035874. New unit must be patched first.
  15. @kasfearless PM sent
