pab567
FREEDOMTech
Everything posted by pab567
  1. Not possible, the best option is to use MIB STD2 PQ unit from Alhambra
  2. What is your Sat Nav - Amundsen or Columbus?
  3. @Grain get someone with Vag Can Pro or ODIS and upgrade your KESSY. If you don't find anyone locally make it with SKODA dealer. I bet all your issues will be solved (assuming Clumbus unit is 100% electrically OK).
  4. A lot of aftermarket units have any issue with OEM sound systems. You must either get the unit that is guranteed to work with OEM sound system or return to OEM system - either Columbus RNS510 or Bolero / Amundsen MIB STD2 PQ unit.
  5. Your factory installed instruments cluster part number is 5E0 920 941. Virtual cluster part number is one of 5E0 920 790, 5E0 920 790 A
  6. Nope, 9.2" screen will NOT work with your unit as it requires MIB2.5 Columbus due to higher resolution. What is your car? VIN pls.
  7. Let me know model number and SW version of your KESSY module (address 05) - there were some issues that were solved by SW upgrade. I originally had 5K0 959 434 A with SW 0802 and had similar issues. I have solved them by upgrading SW to 0902 which caused model number to be changed to 5K0 959 434 B.
  8. Hi. Unfortunately it looks that both are broken 😞
  9. I think not, let me know some VINs so I can check
  10. @Birdy1 do you have rear video recorder camera?
  11. @kellow87 your car is Fabia MY15 and your infotainment unit is Bolero 5Q0035820. To get Android Auto you must have it repalced either with Bolero (no OEM navigation) 5Q0035842x / 565035842 or Amundsen 5Q0035874x / 565035874 (x - letter A, B, C). new unit must be patched to enable new features. I can have such unit delivered - if you ar einterested pls contact me on PM.
  12. Typically this is the problem of START/STOP button itself. It can be dismantled and simply cleaned with alcohol.
  13. Link for MST2_EU_SK_ZR_P0480T sent via PM to both
  14. It's not so easy... What do you exactly need to achieve and why?
  15. Do you need anything from my side? I have a screen but I'm located in Poland so I guess you may find one locally.
  16. Looks like water... What is your location?
  17. Sorry, I missed it... have two, will verify them over the weekend and let you know.
  18. If you are located in UK then I suggest to get a display locally as UK is outside EU and I'm in Poland
  19. Yes, 3V0919606 is the correct display unit. usually it shoul dhave the problem solved, th eonly symptom I don't like is losing programmed radio station (unless the unit made itself reset to factory setup).
  20. @varooom don't be so modest, I started it but as I'm quite rarely here (typically when somebody pings me) you make most of this job now
  21. usually dirty contacts needing a clean
