Everything posted by Gabbo
Remote lock/unlock nit working
Can confirm that wireless android auto is available in my Superb. I had similar connection problems with my android phone and Bluetooth audio. After deleting my phone from the car and connection from my phone it eventually worked after 2 or 3 attempts. It also took me several attempts to pair the phone and headunit for wireless android auto. My phone was saying accept the connection in your car but there was no message on the display. After a few ignition off on off on it eventually came up
Accelerator pedal goes dead for 2-3 sec, post Auto Start/Stop "starting" car
This seems to be common on modern automatics now when they try to "anticipate" you are going to stop. I had our Volvo at the dealer 4 times for the same issue where the engine would cut out whilst still moving when coming to a stop and then take some seconds to make forward progress when it restarted. After finding nothing and contacting the "development centre" they said it was expected behaviour & couldn't do anything. It's stupid things like this that make people turn off stopstart. If the stop, start & abort was always consistent it would be much less worrisome especially at roundabouts and busy junctions
Moving forward
It's the "Autohold" (A) button on the bottom left below the gear stick.
Hit The 399999 km Today Ya cant beat a Skoda Superb Diesel !!
I do mainly long journeys each day ~150km and also service at the approved "adaptive" intervals which means every year for me. I keeping meaning to ask the dealer for a DPF measurement but I think I'll buy an OBD11 this year so that I can monitor it better. I want to keep the car another 5 years if possible so hoping it can reach >300k km without needing to replace it
How's the DPF holding up or have you modified it to allow the air to pass though? I'm quite please to be nearing 250k in my Octavia TR but 400k is a nice distance!!
Electronic Parking Brake affects takeoff acceleration
I'm not familiar with the superb but if I understand right the EPB uses the rear brakes? It really sounds to me like the brakes are binding or sticking/not properly releasing & causing the harsh pull away & engine stalling. The stalling is worrying though because an automatic should never really stall. I'd expect the clutch to open/slip to prevent it..?? Perhaps it suggests a deeper problem with the DSG? If you turn off AutoHold & just do some stops & pull always using only the brake pedal manually with your foot, do you have the same problem? Do the brake lights switch off immediately when you release the brake with your foot?
- Electronic Parking Brake affects takeoff acceleration
- Winter Wheel Pictures & Recommendations
Lane / Travel Assist
You were correct, it doesn't activate the feature without ACC being activated. The TA mode is remembered between driving cycles (TA active or ACC only) but you must enable ACC for it to work... It's my first car with this feature, however in the last Mercedes we had you couldn't really turn of lane assist (or ACC) which I guess is what you both want here on the superb. The Mercedes lane assist was very aggressive however & the Skoda seems much more subtle & precise
I tried TA on my car this morning on the way to work. It seems on my car it remembers the last setting & it was already enabled after my experimenting before Xmas. I will confirm this on my drive home tonight. The icon on the virtual dashboard changes when TA is enable (orange lines with a slalom symbol in the middle) & the lane assist works much better. It's really smooth & keeps the car centred without intervention from the driver & didn't require heavy input on my previous Volvo which made its use tiring on long journeys. I didn't make any modifications except for activating it with the button on the wheel *I only tried it with ACC Active, I will test without today.
Need Suggestions on multiple issues.
With so many issues and so many parts replaced in the last 6 months, I would stop sinking money into this car, get what you can selling it "as seen", to a scrapdealer or as a trade-in for another. I would also look for a different garage with the new car or take a service agreement/ extended warranty to cover any problems...
Update - tpi 2049459/14
Theres a parrot bluetooth update you can download from the Skoda update portal. Not sure it's related to the TPI you mention but something you can try yourself.
Glow plug change - MPG drop
What temperature was it with your delayed start? On my Octavia TDI I had a few years where I thought there was a software problem because the engine would take 2-10s to start on occasions. My battery eventually died & after replacing it, there's been no problems starting since. Did you have problems with the glow plugs that lead you to change them or just poor starting performance?
Is the coolant temperature & oil temperature working as normal? Glow plugs obviously help with starting when cold but will also run while the engine is warming up for a short time after starting. I find it difficult to understand how they could impact fuel economy so much. It would be more likely something else was disturbed during the change. Why were they changed in the first place? What is your "tank to tank" economy and has it really change? You could just have been unlucky that the last trip you recorded included a regen? It would be better to monitor over a tank or two as long as you don't have any warning lights.
MySkoda App Honk & Flash
Ah you're right! Thanks
Wiper Replacement Recommendations
I've always bought Bosch wiper replacements in the past but they're not available for delivery to Switzerland by amazon at the moment. Fronts: A860S Aerotwin Rears: A331H I've seen there are several other brands now available from Conti & Valeo. Does anyone have any recommendations or alternative Bosch models that would still fit the Octavia Combi?
I have the full subscriptions at the moment as I have a new vehicle but at the current rate, I don't see any reason why anyone would pay in the future. The only thing vaguely useful is live traffic information & navigation update but as long as I can download them manually like my Octavia MIB1 is enough. Remote unlocking is very slow when it works but often didn't seem to have a signal to connect with the car. I will try android auto in the new year.
In the MySkoda App it mentions the ability to "honk & flash". However the only function the app seems to offer for my 2023 Superb is remote locking/unlocking. I can't change the lights or open the boot remotely (or configure any settings, send a navigation destination etc.) I was expecting a bit more in 2023 despite the mk3 being an older model.
VCDS help Superb 4x4
Do you have a facelift or original Superb? The reason there are 2 posts is the coding and some security details are different between the original and facelift superb
Did you check the 2 pinned posts at the top of the forum for the standard and facelift versions?
The tyre size and spec you have chosen match the official Superb 16" sizes. The only part that doesn't match is the wheel offset ET50 instead of ET41. The difference is 9mm so relatively small. If I've got this right in my head, this will mean it sits further inside the wheel arch and will look like it's sunken a bit because is 6.5J instead of 8j or 8.5j. However because is a thinner wheel, the overall clearance will be slightly more. I think they might look a bit strange & sunken into the wheel arches, but I've no experience if ~2cm overall narrower wheelbase would have any effect on the general handling, I'd assume none a normal driver would notice.
Superb 2021 model virtual cockpit new theme upload
Can you not select the style and circle content thought the navigation menu for "virtual cockpit"? There is usually some limited choice via the right hand side series on the steering wheel.
🎄Happy Christmas S3 Owners!🎄
Merry Christmas to all...!
