Everything posted by Gabbo
Glow plugs, which ones do I need?
I think it's this one: https://www.skoda-parts.com/spare-part/03l963319d-glowplug-tdi-cr-skoda-15152.html And this one with a pressure sensor: https://www.skoda-parts.com/spare-part/03l905061m-glowplug-with-pressure-sensor-skoda-23614.html
Superb issues...
If you replaced the battery with the same type (AGM Vs EFB) & approximate size it doesn't really need coding... I changed the battery on my Octavia myself (Same AGM type & 3Ah larger) & didn't recode anything. Stop start & all other functions worked immediately without any problems. After 4 years the battery is still going strong. To solve your issue, you need somebody with some basic diagnostic tools. I would say it's worth paying a Skoda or VW garage the price for the investigation even if you end up replacing the parts yourself... I would says it's still most likely an ABS sensor signal problem (next thing would be wheel hub with the magnet elements) or perhaps Cam/Crk sensor problem (more likely for the OPs issues). Gabbo
OCU Update 03A6 - Settings Lost after Update
So I figured out why I think the icons on the virtual cluster have changed... (I'm not going crazy)... The settings of the virtual cluster were lost with the update.... Previously I had the Driving assistance info as one of the main entries in the in the big circles. Now it was only gear and speed. When you put the driving assistance in the main display, the mini icon in the bottom center of the display disappears (this new icon after the reset was one of the things I'd noticed has changed). Have now put back the virtual cluster settings to my liking so all is good 👍
Superb issues...
There must be a fault to trigger those errors in the system & even if it is intermittent, the fault codes should stay in the history as "passive" errors if you use the correct tool to read them. A Skoda garage should also be able to install a data logger to monitor the wheels speeds and capture the behaviour This was how I diagnosed my fault, I could see the right rear wheel speed intermittently to 0kph while the others were working.... At least pinpointing the source will help the next investigations... Which wheel Sensor (already done) Check wiring harness Wheel hub
Superb issues...
When I changed my rear right ABS sensor, I read that often it's not actually the sensor but can be the trigger wheel of the sensor which is built into the wheel hub. Without seeing a list of DTCs & performing some diagnostic is difficult to say what is the cause. In my post on the Octavia forum I showed how you can read the ABS wheels speeds to help diagnose which one if any is causing the problem...
Good news. This morning, after leaving it overnight, the functionality seems to be working again. Bluetooth is now active, although I had to tell it to connect to my phone manually. Lane assist vibrations are back & the icons are now showing on the virtual instrument cluster. I don't know why, but I have a feeling that the icons are different than before & the fonts for the Gear & speed have changed but I don't know if that's just me... Like the ocu update has allowed some other OTA downloads which weren't working before.... I'll try to find some pictures from before to prove I'm not going senile...
Yes, I know the settings for the lane assist quite well thanks to @nicknorman . Original I was driving with only ACC selected in the driver assist menu & the lane assist was very weak. Nick helped me find the button on the steering wheel to enable the driver assist option where other assist becomes much stronger. If it's not working 100% tomorrow, I'll book it into the garage. It's still under warranty for 14 months & I know the service guy quite well. I'll also try to logout my profile and login again just incase this is needed. I'd assume that others should have the same update offered so was interested if anyone else had problems after the update. Gabbo
Last week, my car offered me an OTA update for the "OCU" Online Communications Unit. I chose update and after a few days it told me the download was ready to install. The install would start when I next turned off the vehicle & would take 10 minutes where several systems would not be available & I should not drive the car. I accepted & 2 days later I came to the car. On Startup it told me the OCU update is complete. However, i realised afterwards the car was not behaving like usual & several features were unavailable.... e.g. Lane Assist is not working, speed sign recognition is not working, ACC predictive speed reduction (for roundabouts & sharp curves), phone connection/bluetooth is not working, the climate control settings were all "random" like Hi - 25, Auto-off. I checked some of the settings & found many of them were "deactivated" in the settings menu. I've turned the ones I can find back on (Lane Assist, Speed Signs, ACC Pre Learning) however, several things are still not working. Driver Assist is not working (although it is enabled) and the lane keeping is weak (like it is turned off). Lane Assist Steering vibration is not working (although it is enabled) Bluetooth/phone connect is not working - If I select "phone" from the menu the MIB hangs saying "please wait".... I can then only access the navigiation but no other menus... The update did mention that the main user would need to "login" again but it didnt prompt me to do it (There is only 1 user configured). I also had problems with the MySkoda app which reported "Window Status Uknown", however after a GooglePlay update yesterday, it seems ok now. Has anyone else seen this update & had any problems with it ? I was hoping that a quick ignition-off/on might sort it but it did nothing. I will try it again tomorrow to see if things are better....
Supurb sportline dashboard errors
I have a Carista Bluetooth adapter which was €17 in Amazon and am using a free app on Android to read the DTCs & live data
Here is a link to the post I made about it with some screenshots & methods for investigating the fault with an OBD tool & free app. https://www.briskoda.net/forums/topic/533111-rear-wheel-speed-sensors-are-they-the-same/
I had the same problem on my Octavia (with the same errors in the display) and the fault was caused by an Wheel Speed Sensor Error. It was intermittent because the signal some times worked but it was an easy fix (€30 sensor) and should be 1 hour work.
Navigation Route Selection Type
This is also my experience & I can never understand the logic of how it chooses the route. Often when I chose to ignore it, the ETA will drop 25%. As for the "learning" I also cannot figure this out. I've been to Europa park once last month and every single morning it offers this as one of my "suggestions" when I get into the car. I drive every day to a small village where the kids go to school (using the nav to help with traffic issues along the way) and it never suggests this as a destination. I always have to type it manually myself...
Advice after belt and water pump change
I guess there's technically no need to do them together. But if you have to change the pump you might as well replace the belt at the same time as it's an expensive job that you don't want to pay for twice. Unless you do relatively low miles so a belt change would be in 5 years times, you might as well save yourself £800 and get it done together knowing that you don't need to pay again for another X thousand miles
Part no needed please
Looks like the support pieces are separate, see the "you might also need" section
Is it this? https://www.skoda-parts.com/spare-parts/3V0805588.html
Coolant leak after servicing water pump and timing belt
Part number?
2.0 TDi fuel sensor clip
Electrical connectors are always a pain to remove because the rubber seals create a nice vacuum and make them tough to move. What I like to do is to push the connector firmly into the sensor (the opposite to what you'd normally do), then squeeze the tab and then pull back. Pushing the connector onto the sensor removes any pressure on the locking mechanism making it easy to lift the tab & remove the lock before sliding off the sensor.
2.0tdi sluggish at low revs.
A boost leak would more likely show at higher power than idle. You most likely wouldn't see smoke because it would be caught by the DPF but it would fill up pretty quickly. Could be a split hose in the intake before the turbo ? Or perhaps sticky/dirty turbo actuator ? MAF sensor dirty/faulty? If you have a OBD tool you could try to measure some real-time data when you pull away, boost pressure, engine speed, Mass AirFlow etc
Water temperature problem
+1 for logiclees comment. Typically if it's the water pump, it will go towards the red line but then drop back to normal once per drive. I.e. it will only happen once when the engine is warming up and then will be fine until the next time the engine is cold. In the past VAG were offering 50%-60% towards the replacement cost as a goodwill payment. I'm not sure if they're still doing this now. I would also recommend replacing the timing belt at the same time as they have to take it off to replace the pump and it's expensive to do it alone later.
Columbus MIB3 Nav Maps Update
The last poster is downloading the map updates via USB to the car. Nothing to do with Skoda servers as they already have the files downloaded to a usb C stick... Yes the files might be bigger than MIB1 but the hardware should also be more capable. My point was, It should take hours rather than days to install
New battery time?
All modern vehicles have battery management systems which cycle the battery to keep it in good condition. As long as the voltage is above 12.5v it can be fine depending on the state of charge at the time.
On the MIB1 it would take about 2hrs. 45minutes to 1 hour to download the update to the unit and then the same again to unpack it on the device.
There traffic has been particularly bad on my commute the last month. A combination of end of season roadworks, accidents and random events. I always program a destination even if it's just "home" as previously the navigation was informing me of traffic congestion & routing me a different way. However recently, the navigation seems to have stopped this & always selects the shortest instead of quickest route. On Friday it informed me my ETA to home was 18h45 and told me to take the highway exit and take the A roads. As the traffic in front was moving ok I decided not to exit & a few seconds later it updated my route & with an ETA to home of 18h07 (almost 40 minute saving). I was surprised it didn't already offer this quicker route to me. In my Octavia with MIB1 I can choose fastest, eco, shortest route. I can't find any settings like this in the MIB3 ?
OTA updates
Just download the new firmware? No need to erase the error code or do anything else special?
Superb issues...
My issue was in the Octavia but I guess the system in the superb is the same. Here's a post about how you can diagnose the speed sensors with a free diagnostic tool and some pictures of the repair. Note: it seems I was lucky and my issue was only with the sensor. Sometimes the issues comes from the trigger wheel which is built into the wheel bearing which can be a more expensive and difficult repair www.briskoda.net/forums/topic/533111-rear-wheel-speed-sensors-are-they-the-same/
