Everything posted by ords
Engine management light..
Didn't realise you're not in the UK
You should be worried, it will fail the MOT
Air Con Service?
My MY13 has never been touched either, works a treat.
- Octavia Estate coolant bag burst
Code P173600
Did you have reverse gear?
Help deciding on which mk3 estate
The smaller engined cars use the DQ200 7 speed DSG box which does not require servicing or oil changes. It's up to the owners if they want to change the oils at regular intervals. I haven't touched mine and its been fault free.
Source Towing Hook Tow Eye 8K0805615
I don't see the link to eBay
Which manual to download?
If it's just a pdf opener or reader you're looking for, then download Adobe Acrobat Reader for free. This will open any pdf file.
Centre consol button panel - change of button order
You're correct. eBay UKSKODA OCTAVIA 5E MK3 AUTO START STOP CENTRAL LOCK SWITCH...MODEL OCTAVIA S. MAKE SKODA. BODY TYPE HATCHBACK. ALL FRAUD ACTIONS AND ATTEMPTS TO SCAM WILL BE REPORTED TO ACTION FRAUD. Channel Islands. GEARBOX MANUAL 6 SPEED SEE. However, they are fully opera...
- 1.4 tsi coolant temperature sensor location - under reading coolant temperature
Weird (turbo?) noise
I have the same engine, no noise like yours.
my small informant screen is stuck on compass
The on/off button for the entertainment system
- "Fuel bowl" - You what now?
- Leak under battery tray
1.6 diesel engine
What's the error message?
- Audio quality/problem Skoda Octavia 3 (1.0) 2018
sat nav stops working, intermittently
Could try cleaning the contacts on the card
engine noise increased on speed rotational
Which model, engine, gearbox?
Fault in car that causes a kind of air pressure issue in the ears like a plane taking off or landing?
- Post driving fan noise concern?
- Octavia Mk3: Does the 1.4 have a petrol particulate filter (PPF)?
Volkswagen GroupVolkswagen Group introduces particulate filter for petrol...The Volkswagen Group is continuing to work assiduously on the environmental compatibility of conventional drive systems. The company has now decided upon wide-scale use of particulate filters for p...- Amundsen MIB2 (HW H41) – ECE 2025 map update missing metainfo2.txt
- Fabia 4 Start/Stop battery
Don't assume, mine came with an AGM - Post driving fan noise concern?
