ords
Everything posted by ords
  1. It tells you in the manual how to reset the one touch operation. No coding needed.
  2. Sorry for the multiple quotes
  3. This thread should help.
  4. Near the end of page 1 of this thread is a possible answer.
  5. How is the heater output? How long before you get any heat coming through?
  6. Do some searching on this site. There are so many threads. Some ppl advise to tell the car its got a new battery, others say it's not needed.
  7. The locking barrel is under a plastic cover on the drivers door handle. Just prise it off.
  8. Presumably the car battery is ok now as you've changed it. I'd uncheck the setting for all doors. See if that then only unlocks the drivers door. If that's the case, then set it to open all doors. That may clear the fault.
  9. I think you're lucky to get the glow plugs & heated windscreen changed. Looking at the wording in the link you posted, it says "It’s assumed in law that the fault was present at the time of purchase unless the seller can prove otherwise" Presumably the glow plugs & windscreen were working at the time of purchase.
  10. If you had read thru this link I sent you it mentions 2 part no's
  11. Also many links on Google about this problem
  12. De-activate it & see what happens
