langers2k
  1. They are on the Skoda website.... As mentioned by 100andthirty go to: http://updateportal.skoda-auto.com/en-GB Enter your VIN Scroll down the webpage Download the UK logos Unzip them onto an SD card (not the maps card!) Scroll down further Under Steps it has a section for Import of radio station logos Insert supported medium (SD, USB.) into the slot of your infotainment system. Press "Radio" > "Settings" > "Station logos" and select requested station. If the station already has the logo assigned, you have to remove it. Select the medium with logo images and select desired logo. Repeat also for other stations. Now you can remove the medium from the slot. No idea, the MIB3 systems seem to be confusing everyone when it comes to updates. It might take a while until Skoda/VAG actually decide how it should be done... Sorry
  2. If your car is 13 years old, the projector reflectors are probably shot. Check the condition of the reflectors and lens, replace as necessary Please don't use drop in xenon conversions, they are not road legal in the UK and cause glare to other drivers. They should also fail the MOT.
  3. If I remember correctly: - the cap on the top squeezes off, might need a light pry with a screwdriver - the purple locking bar will slide in one direction - you can then use terminal removers to push the terminal through Example with the top removed and a Purple locking bar, I think it's in the locked position, should slight right(??) to unlock: Pictures from https://www.mk5golfgti.co.uk/forum/index.php?topic=90500.60 You can see the barbs on the terminals below, this is what the terminal removal tool needs to depress: Hope that helps
  4. If I recall, you drive a 2018 Superb? The cost between a car scanner pro, OBDeleven and even VCDS is very little in comparison the the cars value... Obviously it's your choice, but personally, I'd want to reduce the risk of messing the car up by at least using an interface with known tweaks and guaranteed support from it's developer. As mentioned above, what are you wanting to achieve?
  5. You need to find which channels are fog lights. Take a look through all the channels for something with functions "Nebellicht links" and "Nebellicht rechts" and change those If you're able to get a full list of adaption channels and settings out of obdeleven, I can take a look.
  6. The stereo doesn't support normal USB hubs. If you do need more than one port, you'll need to retrofit a VAG specific USB hub, something like 5G0 035 953 D. You'll also need to recode the headunit, add wiring and find somewhere for the second USB port. Certainly doable but a few SD cards is probably easier
  7. As the OP seems to have VCDS, they can check the software version of the ECU. If it's above 9970 then it's been fixed, simples. VCDS can't perform a roll back as mentioned above
  8. Climate control does not mean it's dual zone climate control... You can get: - manual AC just has blue to red for colder/hotter with no temperature control - single zone climate control lets you set a temperature and flaps adjust to hit that temperature - dual zone climate control has different temperatures for the driver and passengers - tri zone climate control has different temperatures for the driver, front passenger and rear passengers In this case, I believe the OP wants to change from manual AC to single zone climate. That will let them set a temperature and leave the car to figure it out With used parts, it's probably only £100-150 at a guess. Certainly much cheaper than trading their SE in for an SEL.
  9. The MK2 Octavia is a CAN-bus based car with numerous electronic modules. This is a scan from a 2006 model to give you an idea: 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 2E-Media Player 3 -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 03G-906-016-BKC.clb Part No SW: 03G 906 021 LB HW: 03G 906 021 LB Component: R4 1,9L EDC G000SG 8501 Revision: --H02--- Serial number: SKZ7Z0F3652414 Coding: 0000071 Shop #: WSC 73430 790 00000 VCID: 6ADC5BAB45D8541F19-803E No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl Part No: 1K0 907 379 P Component: ASR FRONT MK70 0105 Coding: 0017025 Shop #: WSC 73430 790 00000 VCID: 3F8ADAFF6EDA01B79E-806A No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No: 1Z0 907 044 H Component: ClimatronicPQ35 084 0305 Shop #: WSC 00000 000 00000 VCID: 3B72AEEF7AC21D97B2-806E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl Part No SW: 3C0 937 049 E HW: 3C0 937 049 E Component: Bordnetz-SG H37 1002 Revision: 00H37000 Serial number: 00000004124048 Coding: E18A0F231004140046110D000000000000087F075C Shop #: WSC 66001 476 10392 VCID: 2B529EAF8AA28D1722-807E Subsystem 1 - Part No: 1Z2 955 119 A Labels: 1KX-955-119.CLB Component: Wischer SK351 012 0401 Coding: 00065525 Shop #: WSC 66001 Subsystem 2 - Part No: 1K0 955 559 T Labels: 1K0-955-559-AF.CLB Component: RegenLichtSens 011 1110 Coding: 00471077 Shop #: WSC 66001 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels:. 1Z0-919-475-V1.clb Part No SW: 1Z0 919 475 HW: 1Z0 919 475 Component: PARKHILFE 4K H06 0004 Revision: -------- Serial number: 66640904803454 Coding: 000002 Shop #: WSC 73430 790 00999 VCID: 7EF467FBE950C8BFD5-802A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 R HW: 1K0 909 605 R Component: Q4 AIRBAG VW8 018 2300 Revision: 04018000 Serial number: 0038MD0G5EUP Coding: 0020788 Shop #: WSC 73430 790 00000 VCID: 3B72AEEF7AC21D97B2-806E Subsystem 1 - Serial number: 6332MSME0F20057DD Subsystem 2 - Serial number: 6342MSME0E7E4673R No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG Component: J0527 034 0070 Coding: 0003042 Shop #: WSC 73430 790 00000 VCID: 77FA72DF066AF9F796-8022 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: KOMBIINSTRUMENT VD1 1610 Revision: V1610036 Serial number: SKZ7Z0F3652414 Coding: 0007401 Shop #: WSC 28027 067 57207 VCID: 397EB4E770FE2F87A0-806C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb Part No SW: 1K0 907 530 AD HW: 1K0 907 951 Component: J533 Gateway H07 0112 Revision: H07 01 Serial number: 300410F2000053 Coding: E9A07F06400612002303 Shop #: WSC 01324 020 00200 VCID: 69DE24A740DE5F0710-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1Z0 920 942 D HW: 1Z0 920 942 D Component: IMMO VD1 1610 Revision: V1610036 Serial number: SKZ7Z0F3652414 Shop #: WSC 00000 000 00000 VCID: 397EB4E770FE2F87A0-806C 1 Fault Found: 00003 - Control Module 014 - Defective Freeze Frame: Fault Status: 01101110 Fault Priority: 2 Fault Frequency: 1 Reset counter: 255 Mileage: 246370 km Time Indication: 0 Date: 2000.00.00 Time: 13:15:24 ------------------------------------------------------------------------------- Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl Part No SW: 5N0 035 342 G HW: 5N0 035 342 G Component: SG EXT.PLAYER H19 0770 Revision: A1001003 Serial number: 7665406599 Coding: 020100 Shop #: WSC 00788 648 00255 VCID: 2B529EAF4AA28D1722-807E No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb Part No SW: 3T0 035 680 E HW: 3T0 035 680 E Component: RNS-MID H61 3984 Revision: AB001001 Serial number: SKZ6Z7M9023136 Coding: 06000402040100010011 Shop #: WSC 33361 790 00999 VCID: 326C83CB6D88DCDF61-8066 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl Part No: 1T0 959 701 B Component: Tuer-SG 024 2346 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 3664BFDB41E0C0FF4D-8062 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 346085D3579CD2EF73-8060 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb Part No: 1K0 959 433 AK Component: KSG 0401 Coding: 08D002407B008505C85F861004CC Shop #: WSC 73430 790 12345 VCID: 79FE74E7307EEF87E0-802C Subsystem 5 - Part No: 1Z0 951 171 Component: Innenraumueberw.008 4801 Coding: 00000000 Shop #: WSC 00000 Subsystem 6 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Subsystem 7 - Component: NGS n.mounted No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl Part No: 1T0 959 702 B Component: Tuer-SG 024 2346 Coding: 0000758 Shop #: WSC 73430 790 00000 VCID: 377AB2DF46EA39F756-8062 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels:. 1T0-035-680.clb Part No SW: 3T0 035 680 E HW: 3T0 035 680 E Component: RNS-MID H61 3984 Revision: AB001001 Serial number: SKZ6Z7M9023136 Coding: 06000402040100010011 Shop #: WSC 33361 790 00999 VCID: 326C83CB6D88DCDF61-8066 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl Part No: 1K0 959 703 E Component: Tuer-SG 021 2435 Coding: 0000144 Shop #: WSC 73430 790 00000 VCID: 326C83CBAD88DCDF61-8066 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl Part No: 1K0 959 704 E Component: Tuer-SG 021 2435 Coding: 0000144 Shop #: WSC 73430 790 00000 VCID: 336286CF5292D5D76A-8066 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 7P6-035-730.clb Part No SW: 5K0 035 730 D HW: 5K0 035 730 D Component: TELEFON H09 2902 Revision: 1B001001 Serial number: 00007661251715 Coding: 0210000001010110 Shop #: WSC 00028 028 00023 ASAM Dataset: EV_UHVNA A01719 ROD: UHVNA.rod VCID: 26446F9B5940B07FFD-8072 No fault code found. End-------------------------(Elapsed Time: 02:25)-------------------------- As you can see, there are separate modules for the engine (ECU), airbags and many other things. It's entirely possible for a fault to show in the airbag system causing the warning light without an EML showing. You might even find that it's a previous issue so all you need is the code clearing as airbag faults typically won't self-reset.
  10. Odd. Next step is probably connecting diagnostic equipment to see if the headunit will communicate and check for error codes. Otherwise, maybe check for power on the quadlock to the main unit above the glovebox.
  11. I didn't say it was? You said the airbag light was on, I said there will be a fault code explaining why... If your current obd tool doesn't show any faults relating to airbags, it sounds like you need a better obd tool.
  12. Welcome! Sounds like you need a better OBD scanner If the airbag light is on, there will be a fault code stored explaining why.
  13. Seems unlikely as there are no obvious hits on Briskoda: https://www.google.com/search?q="Car+Scanner+Pro"+site%3Abriskoda.net Personally, I'd stick with something tried and tested.
  14. Google? VCP is probably this: https://www.briskoda.net/forums/topic/486882-fixed-my19-enabling-both-rear-fogs-not-working-led-tail-mod-now-available/ Q3 is probably this: https://forums.ross-tech.com/index.php?threads/19771/ Passat is probably this: https://forums.ross-tech.com/index.php?threads/20786/ Dron420 is probably this: https://www.drive2.com/l/554598613926281295/
  15. Nope, the standard headlight range dial won't do anything with factory xenons...
  16. Not something I've done or have direct experience of. At a guess, you'll need: - a replacement control panel - possibly a new facia - a wiring kit and sensors like this: https://www.aliexpress.com/item/4001212098968.html It'll the also need coding and some basic settings doing.
  17. Can you post an adaption map from 09? These are the stock colours (I posted above) where the top is the dashboard/radio and the bottom is the ambient LEDs: Quite a difference between the top/bottom colours but as the ambient LEDs aren't properly calibrated, they look good enough for Skoda in real life When I was looking, I found a few alternative colour pallets for 30 colours. I'm not 100% on the original sources but I think the below is accurate. From VCP: From a Q3: From a Passat: From dron420 on drive2: I think like most things, you just been to pick colours that suit you
  18. Well, they should turn on with a bulb warning if that's what you mean? They won't self-level so will cause dazzle for other road users though
  19. A single 30a fuse at the fuseboard will protect both the cable and TEC3M. Same deal for the TEB7SA, it just needs one 15a fuse at the fuseboard. This assumes the cable used is suitable for 30a or 15a
  20. Take a look for the westafella towbar fitting instructions, pretty sure it tells you exactly which fuses to use 👍
  21. I believe the max figure is provided by the ECU. Your tuner may need to increase it in the ECU software for you
  22. The owners manual states: If that doesn't work, they may need enabling with VCDS or similar first
  23. Yes it'll need coding. You also need to add a AFS range control module and level sensors You should also fit headlight washers if you don't already have them.
  24. There are no 'original' codes for 30 colours in an Octavia, it was never a factory option The 10 original colours are below. They are ordered for a 245 'edition' which means that red is the first colour. If you want them in the standard order, you'll need to reorder the first four colours. IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,40 ,30 IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,57 ,30 IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,235 ,30 IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,5 ,30 IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,55 ,30 IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,240 ,30 IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,222 ,30 IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,255 ,30 IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,255 ,30 IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30 IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30 IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,255 ,30 IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,221 ,30 IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,172 ,30 IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,108 ,30 IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,116 ,30 IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,76 ,30 IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,102 ,30 IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,192 ,30 IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,204 ,30 IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,242 ,30 IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,182 ,30 IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,217 ,30 IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,255 ,30 IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,253 ,30 IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,252 ,30 IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,132 ,30 IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30 IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,1 ,30 IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30 IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,2 ,30 IDE12412-ENG154527-LIN Ambient light color list-Blauwert_Farbe_10_lin,0 ,30 IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,71 ,30 IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30 IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,6 ,30 IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,106 ,30 IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,182 ,30 IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,254 ,30 IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,153 ,30 IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,4 ,30 IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,9 ,30 IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,132 ,30 IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,231 ,30 IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,200 ,30 IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,73 ,30 IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,134 ,30 IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,140 ,30 IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,110 ,30 IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,255 ,30 IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,245 ,30 IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,255 ,30 IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,57 ,30 IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,120 ,30 IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,255 ,30 IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,173 ,30 IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,255 ,30 IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,106 ,30 IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30 IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,29 ,30 IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,58 ,30
