Everything posted by Dean
Fabia VRS LE Register Part Trois
I've just gone through and updated this all again. So, thank you everyone for joining in. I've managed to add 3 that were missing. Please remember to pass this around so we can keep the list updated.
Octavia vRS electric problems
Check the fuse box located on top of the battery, look for blown fuses & for signs of burning/ melting. The large cables that go to it are notorious for causing problems due to bad crimp connections.
Door molding delete
Quite a few topics on this, take a look and decide yourself. ๐
Thanks to everyone who's been on updating their SE ownership. I've got a couple of pages to work through, but I'll get them updated as soon as I get some time. ๐
Help!
I've seen other get this error with the pickup pipe too. So while you're there, get this done to. Clean out the sump, new gasket seal and new pickup pipe with bolts.
Help!
If the car is running fine I would clear the code and see if it comes back. It couldโve had a funny moment and it does happen, quite often it seems with the code. 16395/P0011/000017 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced) Possible Symptoms Power Loss Possible Causes Camshaft Adjustment Valve 1 (N205) faulty Fuel Pump Relay (J17) faulty Mechanical Timing not correct, including Chain and/or Belt timing. Possible Solutions Check Camshaft Adjustment Valve 1 (N205) Check Fuel Pump Relay (J17) (applicable for vehicles with J17 only) Check Mechanical Timing I would keep an eye on it, if youโre worried. Take it to a garage that you trust to do a few checks.
Passenger doors can not be open inside/outside instead of using the car key
If you have checked the loom for continuity on all of the pins across the blocks and there are no breaks, then youโll have to go down the route of getting into the door and replace the locks. Full guide here; Decent after market locks are around ยฃ17 each. And, as much as I wanted to keep it OEM, the originals are far to expensive. I use aftermarket ones from eBay and a year later, theyโre still working perfectly fine.
Skoda Octavia mk1 vrs new clutch help??
The bedding in process can be up to 500 miles of mixed driving. Some do less, but it's just to play it safe. Keep your eye on it, as some lighter flywheels (if you previously have a single mass flywheel) will rev up quicker due to being lights. If you feel there is a problem, get the garage to have a look over it.
MK1 vRS - Stage 2 R-Tech Tuned
The reason my black one is back n the road is so I can use it around London. ULEZ stopped my diesel and I refuse to change the car because itโs cheap to run. So, when I need to visit London and the outskirts now, I take black VRS for some fun. I think we will be going up another Euro for 2030 now which will screw up our 1.8Tsโฆ ๐
HELP NEEDED! Boost Fluctuating
I'd be looking at the ECU map. Any proof of who has done it? Is it a generic slap on map? If you can get access to an original or someone that might have a deimmobilised ECU and try that.
TDi & 1.8T Clutch/Flywheel Change - (Video)
Similar thing to me. I purchased extra's to tackle my gearbox.
MK1 Skoda Octavia VRS - Dead Locked Doors - How To Gain Access From Inside (Full Guide)
Excellent! I'm so glad that you managed to fix it.
Parts For Sale: MK1 Octavia VRS CORRIDA RED (04/05) Rear Bumper x2
View Advert MK1 Octavia VRS CORRIDA RED (04/05) Rear Bumper x2 ยฃ100 (EACH) Excellent Condition, just been taken out of the garage. Items do have a couple of tiny scratches from storage (much to my annoyance). They will be cleaned prior to collection. - 1 Bumper has reversing holes cut into the black bump strip/bumper (after market). This will be perfect for the same replacement, or simply buy a new rear strip from Skoda/TPS. - 1 Bumper has no holes for reversing sensor. P.S. Don't ask for the bump strip, yes they are original, but they will be going with the bumper. Advertiser DeanVRS20VT Date 14/11/21 Price ยฃ100 Category Parts for Sale Shipping Estimate ยฃ0
Firstly, let me just state that there might/will be slight differences between the VW/Skoda/Audi/Seat range of these engines (in regard to the clutch master cylinder, etc). But, this guide will certainly help in learning the process on how to change a clutch and/or flywheel. Excellent work from a guy who does this daily.... And, on his back for that matter. I'm certainly addicted to his channel. Please refer to your HAYNES manual for exact torque settings and procedures. Or, see our topics on specs.
Octavia RS TSI DSG my2021
That looks very smart in Red. Very, very nice!
New Member
Welcome to the community!
Mk1 Octavia VRS Estate
I reckon the door sill and itโs creating a puddle on the bottom of the door and trickling down. So, get a bucket or hose. Sit in the car and get someone to poor water until you see it coming in.
Hi! New to the group and Skoda.
Hi and welcome to Briskoda!
Skoda Octavia MK1 VRS Corrida Red
How's the car @jules68leo??
Electric seats in Mk1 Octavia
Right, so you could only spec it on an elegance, at an extra cost. Which tallyโs up with the pictures above. Obviously a rare option and probably wouldnโt take much to get it retrimed in the VRS style.
It's overpriced, that's for sure. Let us know how you get on.
- Saving a MK1 Octavia VRS Police Car, FJ54 WYP
This was my original thinking. Other regions also got the rear seat arm rest, and auto wipers.
You sure it's not the clutch.. ๐ Neither of mine do.
So, I thought I'd update this post as I've just come across this (to me), the most well spec'd out Octavia I've seen. This L&K seems to have electric seats? So I gather this must've been an option from the factory, unless it has been retrofitted, but I can't see it being in this example. Multi-fuction steering wheel also, which is a nice touch. It has Xenons too.
