MartiniB
FREEDOMTech
Joined
Last visited
Currently
Viewing Forum: Škoda Superb
Everything posted by MartiniB
DSG Gear Selector Replacement
replacement procedure will be similar -> https://www.drive2.ru/l/507863872187663589/ -> https://www.drive2.ru/l/557678895751497206/
Superb sat nav positional accuracy issues
wrong, reception of GPS signal is awful in phone box area phone box provides only GSM signal, but not LTE and GPS :( -> https://www.briskoda.net/forums/topic/395894-what-exact-option-kills-gps-signal-reception-under-windscreen/ @Gyp have had that two times, position were several kms away reboot of Columbus din't helped, have no details what 'deep reset' were done by dealer to solve
- Columbus Map Update 2021-2022 (MIB1/2 HIGH)
Full Sized Tyre as Spare
+1 my choice too, but not tested yet on the road -> https://www.briskoda.net/forums/topic/494383-can-anyone-with-a-20-tsi-220-factory-spare-wheel-tell-me-the-size/?do=findComment&comment=5550057
Fuel tank
Gauge isn't linear -> Fuel Tank Gauge calibration attempt
Speed camera warning request.
+1 and little bit late i prefer Waze for daily routes and Waze+GoogleMaps for abroad trips
noise insulation
@Mech0z full sound deadening packing definitely works, now my Superb 2016 is quieter than Audi A6 2021, but little bit louder than BMW 530d xDrive
Broken vent
Welcome to Club https://www.briskoda.net/forums/topic/426372-rear-passenger-air-vent-part-number/?do=findComment&comment=5332587
Can anyone with a 2.0 TSI 220 factory spare wheel tell me the size?
What are You talking about? why comparing to "standard" 215/60R16, have You ever seen one Superb with that size of tires on it? sorry form my, not native, short English, but what is the reason of attempt to split one hair? few mm in tire width doesn't matter as much as huge difference of OEM spare wheels circumference all what is ask from spare wheel is comfortable ~100 km to service 1. what else dealers can offer when no other sizes provided by manufacturer. 2. that isn't about price, but safety and comfort. 3. personally for me, it's optimal choice, second of several we have: a) same size as all other wheels -> https://www.briskoda.net/forums/topic/493502-full-sized-tyre-as-spare/ + can be installed on any axle + can be used for unlimited distances + no size diff = no speed limits + Cruise control will be available - boot floor will be pushed few cm up - most expensive b) custom 205/65r16, full diameter (my choice for 220ps) -> https://www.briskoda.net/forums/topic/442912-full-size-spare-wheel/page/2/?tab=comments#comment-5040470 + minor width diff will provide safe driving on + 30% of speed printed on spare disc. Important note, when installed on rear axle. + can be used for longer distances + minor circumference diff will provide ability of Cruise control usage. In theory, i haven't had to test it after OEM 205/55r16 were replaced. + fits in it's place, doesn't change size of boot. - !!! doesn't fit on 272/280ps even on rear axle !!! c) custom 205/60r17, full diameter (my choice for 280ps) -> https://www.briskoda.net/forums/topic/520234-superb-mk3-spare-wheel/?do=findComment&comment=5818139 Pros are equal to b and fits on 272/280ps, which has bigger brake discs, 340/310, while all rest have 310/298 (front/rear) d) OEM 205/55r16 + lot wider than 'd' = safer than 'd', but don't think printed speed limit can be exceed more than + 10%, even when installed on rear axle. + fits in it's place, doesn't change size of boot - huge circumference difference disables usage of Cruise Control - huge circumference difference isn't healthy for 4x4 e) OEM 125/70r18 + fits in it's place, doesn't change size of boot - huge width difference = absolutely unsafe, even when installed or rear axle. - huge circumference difference disables usage of Cruise Control - huge circumference difference isn't healthy for 4x4
why confuse with that bul**it? 1. -1.9% in diameter have you read post where i wrote why OEM 205/55r16 were changed to 205/65r16? that weren't ~80km mileage, but difference in diameter, what cancels usage of Cruise Control. and i can only repeat, there is no space for wider tire - i have added 10mm sound deadening foam under boot floor and with 205 wide tire there is clearly visible round footprint, any wider tire will push boot floor up 2. painted red 3. a correct place for spare wheel
compartment has enough space for full diameter tire, but not enough for full width - max 205mm i have installed FULL Diameter Tire on 16" OEM disk -> Full Size Spare Wheel visit also this tread, there are several similar
What size wheels/tyres will fit to Superb III
@Tokebluff winter's Bridgestone Blizzak Ice 225/55 R17 101T XL mounted on OEM Stratos 7J ET40 summer's Michelin Primacy 3 225/55 R17 on AVUS Racing AC-515 Felgen black 7.5J E45 pictures -> https://www.drive2.ru/l/491122983021052184/
Updating Mapping
isn't that about firmware? happy with two year old files?
@Tell I prefer two independent screens, built in Columbus 8" for media and car menu sections and second(Samsung Note 10+ 6.8") for navigation, Waze(https://www.youtube.com/user/WazeGPS1) in daily routes and Google Map for abroad travel but yes, that weren't easy mission to able get good GPS signal under heated windscreen -> https://www.briskoda.net/forums/topic/395894-what-exact-option-kills-gps-signal-reception-under-windscreen/ extended version isn't translated, ask Google Translate -> https://www.drive2.ru/l/506537861164564915/ p.s. i have had two cases when built in navigation traveled few km away from the place where i were. Columbus reboot did't helped there, have no details what were done by dealer's mechanic to solve
exact content in \Mib2\NavDB\DBInfo\0\default\DBInfo.txt PartNumber1="V03959802TM" PartNumber2="V03959809P " PartNumber3="V03959810BT" PartNumber7="V03959804ER" PartNumber5="V03959804QF" ApplicationSoftwareVersionNumber="0192" SystemName="ECE 2021/2022" Variant="ECE" ReleaseName="2021/2022" DevVersion="P192_N60S5MIBH3_EU_NT_Q3.20"
Updating Mapping
delete previous and extract new files on empty SD card repeating, on Škoda's portal files are one year old, download from VW's/Seat's portals -> https://www.briskoda.net/forums/topic/493850-amundsen-mib2-map-updates-2022/
Updating Mapping
no, Amundsen can read maps only from original SD cards, which are identified by id number if you have been interested on old files
Retrofit Heated Washer Nozzles
Partcodes https://www.briskoda.net/forums/topic/398484-washer-nozzle-retrofit-heated-version/?do=findComment&comment=4614855
Skoda superb estate 2016 front washer pipe and jets.
