Everything posted by D402
Diagnostic check in Warwickshire?
Try here 🙂
Fuel econnemy and DPF regeneration 2.0TDI 190HP
I do a journey regularly that, like your commute, is long and fast enough to trigger a regen but is too short for it to complete. When a regen is in progress the idle speed is raised, stop/start is disabled and DSG selects a lower gear. Watch out for this happening and extend your journey until things go back to normal, it probably won't take long. Otherwise the car will keep trying to regen on every suitable journey until it can complete. When it really needs to regen you will see the raised idle speed all the time, this is a sign that you need to do a long, fast drive.
Airbag Theft
It's laughable to suggest that "you may not even know the part has been stolen". No way would a thief replace an airbag with a dummy part or weld up an exhaust system after cutting the cat out. ETA: A really unscrupulous garage might I suppose...
Amundsen MIB2 Firmware Update
Air vent tabs
On the production lines I've visited, the entire dashboard including the HVAC, steering wheel and column is delivered and installed as a single module.
Adaptive Cruise Control Quirk
I guess it's falsely identifying something ahead of you as an obstruction in your lane. Were there overbridges at the junctions where it happened? I'd get it checked at the dealers but I bet they will want to charge you for re-calibration.
Ok, can you be more specific about the circumstances, particularly what vehicles in front of you are doing? I've worked on these systems so might be able to provide an explanation.
This will happen if there is only one car in front of you and it takes the slip road then slows down. The radar has no way of knowing that the motorway continues straight ahead and can only assume that you will follow the car that turned off. If it can see another car ahead on the motorway then it knows it can continue straight.
2016 superb style radio volume
Does the steering wheel volume control wheel have any effect? Could it be faulty and overriding the knob on the display?
Mk3 (2016) gearing / idle engine speed.
Yes, mine's always done the same.
Front Shock Absorbers - OEM or not?
Cheap DCC shocks in this thread from earlier in the week: Monroe Shocks
KESS model, Superb, how to effectivelly prevent keys being scanned?
On my wife's SEAT Ateca, you can disable keyless entry by locking the car with the key fob button then tapping the lock sensor on the door handle as if you were keyless locking. Is it the same on the Superb?
Steering / tracking mystery finally solved
You need to get the tie-rods adjusted equally but opposite (one lengthened, one shortened) so that the rack is centred while the wheel alignment stays the same. This happens because most garages won't do more than adjust one tie-rod to get the toe-in correct, which leaves the rack off-centre.
Odd door trim
Looks to me like the trims have been wrapped and rear windows darkened, sign of a ex-taxi?
Superb -16 2.0 280hp idle problem
That thread didn't come to a firm conclusion unfortunately. Suggest you reconnect yours and see if it helps with your problem.
Your mention of Sport mode reminded me of this topic: https://www.briskoda.net/forums/topic/495154-superb-mk3-epc-and-faults-advice-needed/
What bulbs are fitted to the S3 & upgraded bulb recommendations
These are the reversing lights recommended in this thread, no issues with them in 2 years for me: AUXITO 2x 1156 Ba15s 382 Reverse Led White P21w Indicator Fog Brake Light Bulb
Standard cruise control on an ACC equipped Superb
Sport mode ACC does accelerate more aggressively when you pull out, but it also brakes late and hard when you come up behind someone. I prefer normal mode, despite its sluggish acceleration, because it backs off the throttle early and doesn't usually need to brake; you can accelerate faster with the pedal if necessary.
Skoda Superb 2023 model
The 2024 VW Passat looks familiar!
Amundsen cold/warm start up
Does anyone understand the logic behind why Amundsen performs a cold or warm start? From new, mine nearly always performs a cold start with the Skoda logo splash screen and a frustratingly long wait for Android Auto to start up. However, it occassionally does a warm start and AA is available immediately. Weirdly, it seems that the longer I leave the car, the more likely it is to do a warm start, I'd expect the opposite! Whether it's on radio/media/phone/nav or app when switched off at the end of the previous journey doesn't seem to make any difference. It's MIB 2.5 Amundsen in a 2017 Superb III.
Glove box won't stay closed
While investigating mine, I found that it's easy to dismantle the latch mechanism - pull the button outwards and all will become clear. No tools are needed and all the parts can be accessed so it might reveal the problem if your latch pins are sticky. The actual fault on mine is that the left hand hinge doesn't clip firmly into place on the dashboard and occassionally needs to be lifted back into place. This realigns the latch pin and all will be well for a while.
Starting issue 2.0 TDI CR 2018
Stop/start is disabled, idle speed is higher, and gearbox holds a lower gear than usual. You wouldn't know if it regen'ed during a motorway journey.
Rear Brake Discs & Pads change - Battery Life
There's no need to leave the car switched on while you're working on the brakes, the park brake system will remember it's in service mode and allow you to reset it when you switch back on afterwards. The important things are: don't turn the piston to retract it, push it straight back don't reset until the brakes are fully reassembled
- Windscreen Rain Deflectors on A-Pillars
280 TSI 2018 Exhaust valve making a buzzing noise
This post has a source for replacement exhaust valve actuator springs:
