Quietest Karoq?
Try a PM to @East_Yorkshire_Retrofits for feasibility and cost.
Quietest Karoq?
Try a search on the forum - ACC retrofit.
Roomster not starting
Do you mean crankshaft position sensor? (rather than 'Camshaft') - this can apparently cause the issue of diesels cranking but failing to start - and seems fairly common.
Quietest Karoq?
There are members on this forum who can decode what options are factory fitted from the VIN.
Start up Dashboard
Provided the indicator lights do extinguish when the engine is started, nothing to be concerned with - normal operation.
Quietest Karoq?
If ACC is particularly important to you, a retrofit is usually possible and may be worth considering.
Mystery overheating
In your case, at the very least insist that your fault complaint is recorded as having occurred before expiration of warranty. Given the known nature of this fault, personally, I'd be insisting of more extensive test by the dealer.
Cannot refuel!!
It may seem rather improbable, but it will be interesting if your fuelling issue goes away after the rear spring replacement.
It would be best to get the battery properly tested first before considering replacement. Does the engine appear to crank at normal speed when it fails to start? I'm concerned about your reference to jump-starting another vehicle before this issue first occurred, are you certain that you followed the correct procedure when you did this?
Did the RAC responder actually test the battery?
Automatic Distance Regulator Error
'Voltage terminal 15: 11.3V' looks low - does stop/start work, have you had the battery tested?
- Octavia VRS burning 1.5liters oil every 500 miles
Another Hot Start Problem - 2017 Octavia 2.0 diesel
Hello Lukos, welcome to the forum. The 'engine must be running' message just means that the automatic idle stop function has been inhibited and the engine will remain running - there can be a number of reasons for this; low battery charge state/high electrical load, low or high cabin temperature, etc. A failing crankshaft position sensor (not camshaft) can apparently cause your symptoms - and may not log a DTC code.
Cannot refuel!!
Does the rear of the vehicle appear to squat excessively when the van is hooked up? The 'clunk' could possibly be from the rear bump stops.
Gear stick intermittently stuck in 1st and 2nd position
That sounds like clutch-drag from plate not releasing fully - or contamination of clutch lining.
Clutch pedal hits the floor
In that case, I suggest you look for a good independent garage.
Tyre change from 215 to 185
Provided there is ample tread and the rubber is not displaying signs of significant degradation, there is no need to replace tyres, based on age, below around 10 years.
Unless you intend to change the rims as well, you will have to use R16 tyres.
As the fault can be caused by either a failing slave or master cylinder, suggest that your dealer workshop replaces the master cylinder first - that is a simple job not requiring removal of the gearbox.
ECU fault message
Hello S W, is yours the 110 PS engine?
Cannot refuel!!
When this latest failure to fill happened, did you try rocking the vehicle to see if that cleared the filler tube?
2012 1.2 77TSI misfire and ESC light
Hello, welcome to the forum. Did you inspect the old spark plugs - particularly number 3, how did they look? Suggest a compression test as the next step.
Lane assist
It is actually a statutory requirement in the UK to indicate lane changes - especially on motorways.
New tyres - load rating
Personally, I'd go for the higher speed rating if that price is correct. My money's on the difference in ride comfort being indistinguishable.
