fuel efficiency on my 2015 fabia
You should be aware that the advertised fuel economy figures are not derived from actual driving conditions. Using Cruise Control will not usually give you the best fuel economy.
Tyre size
That answers your question - you have indirect (ABS) type TPMS.
69 plate superb service advice
... and water pump should be changed at same time as cambelt on TDIs.
PS - and I believe the fuel filter is integral with the fuel pump.
Cambelt is not due until at least 120K miles IIRC - but it (and tensioner) should be inspected for condition.
Tyre size
... So do your tyre valves look the same as in that diagram - are they fixed to the rim with a union-nut, or do they look the same as normal tubeless valves?
Tyre size
Hello, welcome to the forum. If your TPMS system does not display actual tyre pressures, it sounds to me as if it is the 'Indirect Type' - I.e. it uses the vehicles ABS system to monitor individual wheel rotation speeds and, therefor, pressures.
Please save my sanity! High level brake light issue.
Hello, welcome to the forum. I'd strongly suspect damaged or fractured wiring between body and rear hatch - you mention cracked insulation in gaiter. It is commonly reported for the internal copper wire core to work-harden and fracture inside the insulation.
Tow bar
The 'metal plate' you mention is likely the rear crash bar - AFAIK, this is removed and replaced with a different bar for the tow bar to be mounted on. This involves removing the rear bumper.
Valve adjustment - where/how to rotate the crankshaft?
Verify which way engine rotates when cranked on starter.
OIl pump belt
@CianKT it would be interesting to hear a report back on old belt condition when it is replaced.
OIl pump belt
Are you doing the crankshaft seal as an 'engine out job'?
No, you will just be rotating engine in neutral gear. Ensure engine is rotated in correct direction. One advantage of this method is that it can be easily noted when relevant piston is at TDC.
Almost certainly the easiest way would be to remove the spark plugs and rotate engine using the alternator / Aux. belt.
Fabia 1 1.4TDi 2007 Not Firing, Any ideas ?
You say the engine 'spins like mad' - does this seem to be much faster than previously? Is this is the case, I'd suggest getting a compression test.
- Rear brake drum to caliper conversion
OIl pump belt
I also have never seen any reference to this drive belt failing. I know, never say never! ☹️
OIl pump belt
I haven't seen any reference of maintenance / replacement for this oil pump belt - I believe it is a 'For Life' item. Clearly, failure of this belt would result in complete loss of oil pressure and any such pressure warning should be acted on by immediately shutting down the engine and arranging recovery.
Car Not Activated
Hello, welcome to the forum. @pab567 may be able to offer some advice. Not sure but a 'reset to factory settings' might allow access - but I wonder if it is possible that the infotainment system needs to be unlocked to allow activation.
Replacing the 12V battery
OPs original battery could well be EFB - but, if so, replacing with AGM will give better performance, but not especially necessary. Agree that correct adaptation (coding) to the vehicles BCM is important - but actual battery manufacturer is not. Critical battery adaptation information is - Type (AGM (fleece) or EFB. Capacity (Ahrs) Change battery serial number to inform BCM that a new battery has been fitted (this can simply be by changing the last digit of the existing serial number)
- Inspection required.
- Automatic Wipers Not Activating in Rain
After 4 years of ownership, my PHEV goes back to Peugeot. My thoughts.
The damn fools have put the A45 spoiler on the wrong end!
