Stop/Start issue / Battery Question
The 11.9 volts standing voltage is low, but could possibly be because some of the modules have not gone into sleep mode yet - the standing reading can be unreliable unless taken at least 20-30 minutes after the vehicle has been fully shut down. However, it's very likely that your battery is faulty - which can be confirmed with a full battery test.
"Front assist sensor impaired" – talk me through troubleshooting
I'm pretty sure that the front assist being unavailable is not a MOT critical failure - as it can be deactivated by the driver. Apart from a few occasions where mine has thrown a brief warning where there was no real risk of a collision - usually when I was overtaking a vehicle that was turning-off to the left in front of me - I've found the system pretty reliable.
Is the sensor wiring ok? in the second image you have attached, it looks a little odd.
The front radar doesn't affect the steering - just the proximity warning and, eventually, the full ABS avoidance braking. If fitted, lane assist steering intervention is monitored by the front (A5 ?) camera.
It does appear that your mount is broken, most likely that the grill has been nudged in a parking manoeuvre, deflecting it sufficiently to push the sensor back. I would think it's possible to confirm the radar sensor functionality with VCDS, but certainly worth replacing the mount and getting the calibration checked.
Hello JL, welcome to the forum. There should not be any movement in the radar sensor, check that the mounts haven't been damaged or broken. Hopefully the sensor will be undamaged if it's just been displaced in a parking bump. Radar will almost certainly require recalibration if the mounts are replaced.
Electronics suddenly gone crazy. Car won't start.
Possibly something as simple as a battery connector not correctly tightened when the battery was replaced in January.
Very likely that there is a problem with either the battery or, possibly, the alternator charge rate - my money would be on failing battery. Battery disconnection is highly improbable to improve the issue - but will not affect any settings, there will likely be several transient faults indicated when the battery is reconnected, which will all clear after a short drive and turning the steering from lock to lock. Do you do a lot of short runs? How old is the battery?
Gidday from Berowra
Do you also get the option of the Aisin 8 speed TC gearbox in Aus?
Errors - is my car gaslighting me?
Is this a Mk4 hybrid? Multiple and seemingly random faults like that can be a symptom of low 12V battery levels on the MK3 - and there have been a number of Mk4 owners reporting issues with 12V battery charging.
Gidday from Berowra
👍What is your new car?
2011 VRS, no power. very slow
IIRC, relative boost should be around 1.5bar (22psi)
EPC and MIL light on
Received an update call from the garage this morning, turbo flap actuator is OK - the issue is sticky/tight actuator arm. A repair kit is available and has been ordered (£40) - no information available if the kit is a revision, but a possibility.
Gidday from Berowra
Gidday, welcome to the forum. How's the weather down there?
Basics: how to restart the engine after manually switching off?
It sounds like you have 'keyless start' - Not full KESSY (keyless entry and start)
Update 3, Fabia into garage this morning. When I scanned for faults last week, there was just one DTC - P003A, garage called me to say the DTC now recorded is P334B00 - Charge pressure actuator position sensor - which fault appears to be fairly widely reported and, I understand, there has been a TPI issued by VAG. Waiting on results of further investigation.
Cold start noise; 2011 VRS 2.0
That engine appears to be misfiring fairly badly, have the spark plugs and coil packs been tested?
front park pilot automatique
Hmmm, looks like Op has disappeared. I'd think that this feature would require the complete set of sensors to work - unlikely to be present if PP not originally installed from factory.
Lower Door Mirrors in Reverse
For RHD vehicle, I believe that the window switch has to be set to left (L) for the mirror to dip while reversing - you also require electrically operated seats for mirror to dip to correct position, otherwise mirror position while reversing can be a little random.
Coolant, cause for concern?
Good afternoon CM. Most likely the original coolant has simply become diluted over time - has it ever been just topped up with plain water? Probably due for a coolant change anyway.
Can anyone explain this please?
Pete was referring to the alternator charge management levels while driving.
Hello, welcome to the forum. At 2017, your Yeti would have smart alternator and automatic idle stop (Stop/Start) - does that operate correctly - do you normally use it? At 12.6 volts, your battery is approx. 85% charged - which is a little above the level that the smart alternator limits its output to allow for energy recuperation. Try leaving the headlights on for about 10 minutes with the engine off, then check the battery terminal voltage with the engine idling. It is possible that the voltage sensor wire to the alternator has a bad connection - this appears to be relatively common problem reported on the forum.
Skoda Warranty
Good morning John, is this Fabia a TSI? DSG or manual?
EPC and Engine Warning Light
Despite the modern ICE being much more complicated than the old carb and points system, consideration should be given to the fact that the modern engine is cleaner, more economical and more powerful than in the past. Not a lot of consolation, but many of the problems with the modern ICE will be from the myriad of sensors required for it to run correctly. P.S. My wife's Fabia (1.0TSI 110PS) currently has a very similar problem - apart from the rough running - DTC code thrown is P003A. A reliable OBD11 code reader is very affordable and perhaps should be considered to be an essential accessory nowadays.
Dash warning lights after battery charged
All transient fault lights triggered by battery removal and replacement should clear themselves after a short drive and turning steering wheel lock to lock.
