Battery replacement
Hello, welcome to the forum. Is your present battery AGM - or EFB? You should replace with at least an EFB battery - which will be less expensive than AGM (if that is what's currently fitted) - a standard lead-acid battery would probably not survive for long. Adaptation of the BEM (coding) for the new battery should still be done,
EPC and MIL light on
Update 2. Garage could find no obvious cause of fault after diagnostic check, car remained fault free for 3 weeks since the check - until yesterday - EPC lit up again while wife was returning home. I plugged OBD11 reader in - no DTCs recorded, EPC extinguished when engine started. I took it out for test, EPC and MIL lit up and engine appeared to go into limp mode as soon as I accelerated onto A3. DTC P003A again! Question, wife needs to use car before the garage can take another look - should I leave DTC logged so mechanic can see that the fault was definitely recorded - or should I clear the fault before she drives it again?
skoda wont start after back wiper motor burned
...or at least get battery charged and tested.
Drivetrain issues
Yes, the CV joints, you mentioning that at least one of the gaiters is split and leaking rings an alarm - this could very easily allow wear and damage to the joint. The 'shimmy' you mention could be from dynamic imbalance of the drive shaft if the coupling is badly worn.
Drivetrain issues
Get the driveshafts, couplings and wheel bearings checked.
Right side wiper not working
Hello, welcome to the forum. You've not given much information here - and do not recognise model 'luna' but if the wipers are working on one side only, the fault will be a mechanical one in the wiper drive-train, between the two wiper spindles.
Skoda Octavia Faill Start
Late reply to OP - but displayed 'one fault found 10763' P1734 would be an obvious start point to check. Also recall that failing crankshaft position sensor can often be cause of difficult, or failed start - the TDI can also be very sensitive to slow cranking speed.
Radio head unit not working in Superb Mk2
Hello, welcome to the forum. Interesting, was the battery tested before being replaced? - If so, do you remember what the test showed?
All those faults strongly suggest a failing battery or faulty ABS sensor.
If that voltage was read in correct manner, at 11.94 volts the battery is less than 40% charged! Strongly suggest getting battery tested and check alternator operation.
Gear changes
...or try it in Eco mode for a while and see what that does.
Gear changes
That rather sounds like it's stuck in Sport mode - even though the mode is not selected. Try selecting Sport mode, then switching back to Normal or Eco after a while.
Gear changes
How much later (I.e. higher revs) is the DSG shifting up gears? Stop/Start consistently being inhibited could explain approx. 2 to 3% higher fuel use, depending on length of stops.
Alignment
Hello, welcome to the forum. Unlikely to require ADAS calibration if only having a wheel alignment done. SWMBOs Fabia recently had both front lower suspension arms replaced (MOT - failing bushes) and subsequent wheel alignment - with no affect on ADAS.
Gear changes
Hello, welcome to the forum. 'Power Consumption is High' message refers to battery state of charge (SOC) and is one of the parameters that inhibits Automatic Idle Stop (Stop/Start) This message can mean either there is presently a high electrical load (A/C, etc.) or the battery is possibly starting to fail. Unlikely to be cause of early DSG changes, but failing battery can cause quite a few false warnings on the dash. Have you accidently switched engine mode to sport?
Braking Questions - pad wear.
Suggest checking the rear hubs for excessive heating after a run.
The ESC programme will almost certainly use braking effort, but I wouldn't think it would be on the rear brakes only.
The 60/40 braking bias will actually be to the FRONT - NOT the rear!
Large oil consumption. 1,5L 1000km. 10W-40 ?
Redex was once a product recommended to free gummed-up piston rings - not sure that this is the issue here though, at least one of the issues with EA888 engines was unsuitable oil control rings - but I thought that particular issue had been addressed with the Gen. 3.
Misfire cylinder 4
How bad is this misfire? Not sure how advisable it will be to continue driving for too long if mis is noticeable.
Misfire cylinder 4
Guard against possibly voiding any warranty by having work carried out by anyone else.
Misfire cylinder 4
Is this an 'approved Skoda' warranty? How long have you owned it? How many times has it been back to their workshop for the misfire?
Misfire cylinder 4
To confirm condition of suspect coil pack, it could be moved to a different cylinder - if misfire moves to that cylinder, that's the problem! NB. it is strongly recommended to use a coil pack extractor. Edit - ^^^^ what Gaz said.
Misfire cylinder 4
Very much doubt that using V power will make any difference - in any case, poor fuel would affect all cylinders. Did they actually have the coil packs tested off the engine?
Misfire cylinder 4
Suggest checking cylinder 4 coil pack, if that checks out OK, possibly a faulty injector.
