Can you identify this leak?
Used to make a slight blow off noise. Hardly noticeable then limp mode with sometimes EM light on other times not. My actuator was sticking. I sprayed with oil and manually operated it until it became free again. The lights would go off and limp mode cancelled if I pulled over and stopped then started engine again. If your lights coming on randomly and going off when car is restarted I assume its not a consistant fault. Alasdair
Mine uses to do the same due to sticking turbo. EM light on but when I stopped and started it it went off. I did a quick scan for codes and it was randomly overboosting. I would get it scanned to see if its stored anything. Alasdair
fabia 1.2htp brakes still feel spongey after being bled
Check the servo hoses again. My sons brakes were poor and the hoses were split at every join. If there is a new master cylinder to be fitted it could also be the seals have failed and fluid is pushing past them? I used a pressure bleeding kit. (gunsons from memory) and I discovered some air in the front brake line after replacing flexi,s I did bleed it manually but the pressure kit cleared the air and sorted the problem out. If its got drums on the rear it could also be a leaking brake cylinder. Alasdair
One Touch Window Glitch
I had similar problems on my old 08 octavia. Over time the switches wear out plus they tend to get wet if the window is left open. Tried dismantling switch to clean contacts but found the retaining screws were loose and wouldn't tighten properly. I bought a cheap copy off amazon for about £15 and it cured it. In my case it randomly worked but most of the time the window went either all the way down or all the way up when trying to open it slightly. Alasdair
Octavia mk2 FL repaint
Years ago my friend painted his old Bedford van with a small roller and used Dulux exterior gloss paint. Damn thing was shiny for years and never needed polished and paint lasted as well. It wasn;t perfect but looked tidy. Alasdair
Engine help , cracked mount.
£50 off is no where near it either. I reckon its worth £50 for scrap. Try https://www.trents.co.uk/ Might be worth an email as they seem to have a fair range of skoda/vw engines. Meant to add why a new engine? Is yours not repairable? Alasdair
Its either been removed badly or been in a fair crash. I doubt thats repairable and I personally wouldn't risk it. There may well be hairline cracks that you can't see. Alasdair
- Fuel filter housing screws completely stuck
Or do as I do. Run it till body too bad for MOT and then keep it for spares. Problem is my place is turning into a bit of a scrap yard but it saves me a fortune on spare parts.
Might as said be worth trying some of the smaller body shops or car restoration guys that don't do insurance claims. Know someone with a cleaning business and it recently cost nearly £8000 to replace and repaint the rear doors on his VW transporter after the handbrake failed and it rolled away and hit a wall. The only damage was the rear doors and the bumper. It was done through his insurance but how it cost that much ??? Alasdair
Looked into getting my old volvo resprayed but the cost was huge. Most of the decent car body shops in my area are doing insurance jobs so charge a lot. There are a few that do smaller touch up like wings etc but won't do a full car. I think from memory it was about £2500 plus vat and that was a few years ago. It wasn't too bad upper body and laquer was peeling on roof but the sills and wings were poor so decided not to bother. They all said its the preperation work etc that puts the price up plus they said they never know what they will find when rubbing it down like previous repairs and cover ups. You might get a smaller independant shop to tidy it up? Alasdair
Lower than expected MPG
I was also told by a mechanic friend to fill up once a month with premium diesel. He reckons it helps clean things up and improves MPG/performance. Being doing it for the last couple of months and have noticed a slight improvement. The 1.6tdi is supposedly the same horsepower as the 1.9tdi but I found the 1.9tdi had a lot more torque/low rev power and you didn't need to change down as nearly as much. Hopefully a good service will help. My 1.6tdi is a 12 plate so not the greenline as far as I know. Alasdair
Skoda Octavia A5 II Restyling radio code (safe mode swing)
There are a few online services but I got mine from the dealership although it was a few years ago. I gave them the reg and vin and they managed to find the code. At that time it was a small independant dealership and as the car had come from them they didn't charge me anything Alasdair
I have a 1.6tdi octavia and was only getting 50-52 mpg on long steady runs. Was also getting just less than 45mpg around town. It seems to have improved since I serviced it and reset the service interval message. It now does aprox 70mpg on long runs and 50mpg around town. I was wondering if the car was in some sort of limp/limited mode due to the service light being on? I also put a couple of bottles of wynns injector cleaner through a couple of tanks which also seemed to make a difference. Just wondering if the turbo/actuator is working properly on yours. The 1.6tdi is a bit gutless compared to the 1.9tdi I had previously and does seem to need more revs to get up to speed. The 1.9tdi used to accelerate fine in 4th and fifth but I find the 1.6tdi needs to change down to get the power for overtaking etc. Could also be a clogged air filter etc. Alasdair
Error code 000258
Holy crap thats well blocked. I thought mine was bad. I hate EGR. I blanked mine on my old toyota lucida as it was the same and very prone to blocking. Who ever thought of recirculating exhaust gases was a good idea was obviously not a mechanic . Glad you got to the bottom of it. Aladdair
Fault code help needed!
I am no expert but I think you will have to check the different sections. As far as I know 0010 is telling you that there is a fault and there will be fault codes stored under Auto trans section. Alasdair
Central Locking
I have an old seat that does the same. Its I think got an auto door lock feature when you go above a certain speed doors lock. On mine i am pretty certain its a fault in the drivers door lock/switch. Never did get round to fixing it. Just lived with the click clunk while driving at lower speeds. Alasdair
1.4 TSI Coolant leak ! Common places too look
Personally I always use Gates timing belts and kits. Not sure who makes this one. Never had any problems with them but there are a few out there that are not worth the risk. Does it have a belt or chain? I thought the 1.4 was a timing chain. Someone on here will confirm. Alasdair
Error code 000258
If the air flow sensor looks new it may have been replaced just before you got the car. Its a long shot but wondering if its the correct one thats fitted or why it was replaced. Might be worth checking wiring continuity as well. Alasdair
Fabia Mk1, 1,4 petrol BKY, P1196 fault code
Sorry missed bit re neew lamda. Good luck with checking wiring etc. Alasdair
Check the bottom of the rad for wetness. My daughters vw had a slight leak where the temp sensor goes into rad plus on further inspection the bottom of the rad had started to disintegrate on the inside. Alasdair
It could be a dirty lamda sensor. If the car had a misfire it could have contaminated it due to unburnt fuel etc. I assume the resistance would be the same if it was dirty or not. Might be worth trying a new one or a known good one.
MK2 Octavia VRS CR170 CEGA
I would haave thought if the high pressure pump had failed it would have thrown up a code. Hopefully its just a fuse/relay or low pressure pump. Alasdair
Not sure either but maybe fuel pump failure or fuse/relay Alasdair
59 plate fabia EPC
Might be worth ordering another one in case its on its way out. Dont think they are that expensive. Alasdair
