Diff shaft
Reckon if its still there its either worn splines or worn cv joint. Get someone to hold shaft and try turning wheel by hand if its still there it would I think rule out Gbox and inner cv. Alasdair
Changing Tyre Sizes on Fabia Estate 1.4 petrol VRS 2013
I use https://tiresize.com/comparison/ if you go for 205/45 at 60mph its actually 62mph and 205/50 its actually 64mph according to their site. As previously said as long as all tyres are the same size ABS etc wont be affected. Had 225/40/18 on a people carrier but the weight rating was too low so went for 225/45/18 and didnt really notice. On it the larger size just cleared the bottom of front strut. Make sure you have enough room. Alasdair
Noisy car ...
Might be worth getting bearings checked if its related to speed. Does it change if turning left and right. Sons fabia was really loud droning but seemed to get better/worse when turning. No obvious play in bearing but was pretty rough and tight when turning wheel. Also if fitted on the scala check the front exhaust flexi hasnt failed. Alasdair
Disable alarm siren?
I had a troublesome alarm on my old Seat. I removed siren fuse and eventually alarm battery went flat. Indicators still flashed but at least it didnt wake anybody up in the middle of night. Alasdair
Urgent advice fault code P2149
Not sure which injectors you need but found this on ebay. He may have more than one £36-75 plus three month warranty. https://www.ebay.co.uk/itm/188720875711?_skw=skoda+2.0+tdi+cr+injectors&itmmeta=01M0PSBKSSNXXA9B374HHDY7NZ&hash=item2bf0a408bf%3Ag%3A7WkAAeSw6QhqbF2E&itmprp=enc%3AAQALAAAA4GfYFPkwiKCW4ZNSs2u11xCYcGQCs9l3X8kE%2ByJzIRgr4wELj29GxGovqjdh44G5e2iEJVYBWS%2BrwFHDXQpA4dEpBP5qDDzvbXpEj8vxo9aoQgaUWNDgcDprRIHg3vm1t56kfobVCBuuxM4A6JzqSu3tIggTt8QBY3ZsAqtTitbYUcgFRoOzIyMd0hwognhxBp0rNKvMYwtT1R%2BIyMXjyj11ZwnQ1XWl8LaBX19EF4eGWckkUBCGJoFVG0LUg6lTBns1vR9WvXU%2BOS4i58w7CjXcgeZyRWzOyC5WGTY6kSAm%7Ctkp%3ABk9SR7C9rtmFaA&LH_ItemCondition=4 Might be a cheaper fix if your thinking of getting rid of car or at least rule out electrics? Alasdair
If the autospark is 100% sure wiring is good then you may as well fit two recon injectors. If you dont then I reckon you will have problems selling it or get a lot less than its worth. Hopefully it will cure it and if your still worried about reliability it will be easier to get rid of. Not sure where the best place to get recon injectors from but someone on here may know. Alasdair
P0113 fault - Intake Air Temperature High Input
Wonder if theres a break further back in wiring loom? Alasdair
P2149 is as far as I know is a failing injector or wiring fault. The injectors would probably have been tested when cold and could be failing when very hot or there is a wiring issue the autospark missed. What engine is in your mk2? Alasdair
HELP! Hot brake AFTER changing caliper and flexi-hoses
Could be a defective new caliper (not common but not impossible) although might be pads that are tight in the carrier. Have had some that were slightly too large and were very stiff. Slight file of the edges and sorted it. Make sure area the pads sit in on carrier is clean and free from rust etc and check pads arent too tight. Also check the rear wheel bearing for roughness and play as well and make sure the discs are running true and not binding at some point. If the bearing or disc isnt running true it can cause disc to bind and heat up/wear pads Alasdair
- OEM electric windows + mirrors retrofit on a 2001 Fabia Mk1 Classic – wiring / Comfort module questions
- Error code advice please
- Rear drum brakes.
2012 Octavia 1.6 high revs and fan on after switch off
Mine does the same. The high idle followed by fans on after stopping are a failed regen. When I notice high revs I try to continue driving and give it for a good blast down the road at revs above 2500 for about 20 mins and it should complete the regen till next time. Mine is due to shorter runs than I used to do. Alasdair
Rear drum brakes.
On the MK1 fabia which I am sure will be the same or similar on yours there are slider wedges that automatically adjust in rear drums. They can seize or wear out. They have a gripped surface on one side and are held in place with a small spring. It could also be a failing brake cylinder or leaking cylinder and contaminated shoes or a sticking handbrake cable on the poor side. If the handbrake is high it would point to the adjuster not working. Either way they will need to be taken apart to check. Alasdair
Could also be due to overfilling with petrol and some is in carbon caniste but i think it would happen more often. If the fuel cap is good a new N80 valve is around £20 and easy to change. Got a bosch one for my sons mk1 for £15 off amazon. Check that any pipes are secure and not split. Alasdair
Octavia IV Combi 2.0 TDI — 129 Hz droning above 125 km/h, temperature-dependent
check undertray/arch liners etc. Have had one that was slightly loose and made a weird howling sound at specific speeds. Must have caught it on something and ripped a couple of screw fixings. As it plastic it may be slightly softer when weather hot so might change speed it resonates at. Alasdair
P25AB00 Piston Cooling Oil Control Circuit High - Superb
Hope it stays gone. If it returns I think there should be a multipin cable from ecu in the engine bay fuse box. Not sure exactly where. On my octavia it seems to connect through base of box. Check it for loose pins/corosion. Hopefully it was a fuse/relay that needed reseated. Alasdair
Meant base of actual engine bay fuse box as in picture above. Think there are connectors underneath to ecu etc. Not unknown for a pin to be coroded or socket opened up enough to make bad connection especially if moisture is present. Alasdair
A random thought and could be wrong but wonder if its corrosion or bad connector pin/socket in bottom of engine bay fuse box? Might be making good contact when warm but poor when cold thats not enough to trigger other fault codes but the N522 valve system may be more sensitive. Alasdair
Check your sills! Paint advice
Problem with the stone chip guard it gets brittle and cracks with age then moisture gets trapped underneath. If the rest is solid I would leave it alone. Alasdair
How to find OEM part numbers of front wheel bearings for my Fabia 2
Used febi ones as well and no problems. Put a slight smear of copper grease on bit that fits in hole not the tip for future removal. According to youtube the new bearings should click in place when fully home. I didnt hear anything but they went in as far as the old ones. Took a photo of the old ones in place before removal for reference. Sons were really loud but no play and we only noticed once I finally fixed his blowing flexi exaust. Just got to do front swing arms and bushes now, Alasdair
Diff shaft
If the shaft seals are leaking it may be low on oil hence the clunk. I would get gearbox oil level checked and also the condition of it first. Could also be worn cv joints. Alasdair
Are you getting 12v at N522 valve with ignition on. Just wondering if its a bad fuse or relay problem. Read the valve is supplied with 12v at ignition and ecu connects earth to operate it. Alasdair
Had to spend a bit of time cleaning up bearing socket on my sons. Especially the grooves it clicks into due to corosion. Fairly easy to do with the correct puller. Couldnt get ABS sensor out without destroying it. Give it a good soak with penetrating oil for a day or two and you will hopefully be lucky. Alasdair
Maybe check engine bay fuse box for loose contacts/corosion/relays and all earth points you can find. as the wiring is new and so is valve. Alasdair
