Everything posted by rum4mo
Noise from camshaft drive system
I did understand that, but still added that comment to suggest why they had not returned.
That member last visited this website/forum a few days after that final posting, have their "lips been sealed"? Ie set conditions for resolving this issue, just idle speculation on my part, but could be true.
Check oil level!
I’m guessing that while the bonnet switch lead was unplugged that the car would think that the bonnet was open, applying a short should, I’m guessing look like the bonnet was closed.
Check oil level!
But, now that you have hopefully simulated the micro switch working, as far as the car knows, and if the oil was high enough, and of course if the bonnet switch is faulty, you should now have cleared that oil level warning. If it is still there, the root cause lies elsewhere like the wiring, maybe a fuse, or the oil level sensor.
Warning lights: ABS, TPM and traction control together
Any fully VW Group compliant scan tool will point to what it thinks is causing the fault, so yes, if a ABS wheel sensor, it will identify which one. You could check the "VCDS locator map" to see if anyone close to you is reg'd and ask to make contact. Where, roughly, in Scotland are you located?
Check oil level!
One thing that I can't enlighten @Jackhodge998 on is, the exact location of the plug/socket for that bonnet switch, I never ever noticed it on my wife's previous 2002 Polo, but on her 2015 Polo, it sticks out like a sore thumb very high up just at the washer fluid tank, which seems a very obvious or important position for something that hopefully never needs anyone to gain access to, strange.
Check oil level!
Yup, that would have been an easy fix, but you could always try unplugging the lead to the bonnet micro switch and stuff a paper clip across it, I'm guessing that if its open circuit that equates to "bonnet open" and if it is short circuit that equates to "bonnet closed" - but that is purely a guess as doing that would make it fail safe for cars that show an open bonnet - like most/all later cars. If that worked, then the "Low oil level"| light would get reset until you let it run low again. My logic was, the previous owner kept an eye on the oil level as maybe he knew it "liked" a bit of oil added frequently, and so even if the bonnet micro switch was faulty, it would never have caused any issues, you then bought this car and basically didn't quite keep on top of checking the essential fluids and the "Low oil level" warning appeared - and if the bonnet switch was faulty that warning would never get cleared just by adding in oil. Edit:- even leaving out stuffing a paper clip into the removed lead as I'd think that open circuit for a few minutes would be enough to reset the low oil level warning - if that bonnet switch was in deed faulty.
Check oil level!
For goodness sake, has the OP not said that the dash display does not register the bonnet being open, while it does so for all other doors and hatches, I'd be sorting that out before buying a new low level sensor, much cheaper.
Check oil level!
I'm reading/interpreting what you wrote as " on the dash each door and hatch opened show on up - but when the bonnet is opened it does not show up", if that is the case, then sort out the micro switch and/or lead before looking elsewhere would be my plan. Edit:- in other words, the car's systems need to know that the bonnet has been opened before it will revisit and clear the low oil level warning, logically, if the bonnet has not been opened then the oil level can not have changed, if that makes sense.
Check oil level!
Could this not now just be the bonnet lock micro switch sticking in the "bonnet closed" state - so until that is sorted you could put a lot more oil in and still have that warning showing.
Karoq Brake pads and discs
Yup, as it turns out. Edit:- they seem to able to supply Lesjofors road springs, which could be handy in future.
I had that noisy rear pads experience from buying from ECP way back in maybe 2008, bought new Pagid or Textar pads for my 2000 VW Passat 4Motion - I contacted the UK sales arm of TMD Friction and they sent out the correct kit FOC, that sorted that out! Electric handbrakes, yes, maybe not ideal, but they do have their advantages - after a while.
I always thought that Dingbro will only deal with trade customers, the one reason why I've never, as a DIYer, checked them out for parts. As they had a branch almost next to where I used to work (South Gyle Embra), I went in to buy a trolley jack many many years ago as I had an urgent need for one to use at work, paid with my own cash and they muttered about not wanting to deal with non trade customers, which I suspected would be the case, so never went back for personal car parts.
Another tailgate problem
If you look on the SEATCUPRA forum, there has been a few people finding that there is cable connection, ie plug pin>socket pin, within the rear hatch, that can get wet and so end up with a "bad" connection, I'd think that Fabia and Polo will be roughly the same in this area. Failing that, there is always the possibility that a cable has ended up shearing on the cable run between the car body and the hatch - ie in the area that is covered by a flexible rubber sleeve.
Wheel part number
Yes, sorry, "first impressions" and all that, not a good look/experience. I would not be too sure that some of the grumpy ones are not women, though they might not know it.
Melted Mess !
I've contacted DVSA about an issue - and not one that had happened to me - yet, they will claim to note any contacts from drivers/owners and reply to emails, I'd think that after that it will be up to many many others to contact them before they take any action, like communicating with the car manufacturer's UK representative, any follow up action with depend on how that comms with the car manufacturer's UK representative went. All the communications that they receive will get it's own reference number.
Tail Lights Gone.?
Well, if you had or borrowed or bought a multi meter, you could find out more.
Gear stick intermittently stuck in 1st and 2nd position
Best to ask the next workshop to hand you back the old clutch parts, just in case the plate is getting contaminated.
Door check bolts replacements
Better to get your local Skoda dealership parts department to order 4 in for you if you feel the need to change them.
Correct Tyre Pressure?
Maybe I've put myself in a fortunate position, but, as I swop wheels/tyres every 6 months (Summer<>Winter), I measure the tyre tread depth at 3 points across the width of each tyre when removing the wheels, doing that lets me check if the tyres are being used at too high a pressure or too low a pressure - typically, with fuel economy in mine, I tend to be running with pressures set on both our cars, that errs towards "too high".
Abs sensor
Just a passing comment now that you have mentioned that you have a 36mm 12 point (BiHex) socket, that you have probably used in the past on the front hub nuts, if the rear hub nut is the same for rear drum brakes as for rear disc brakes, then it is a 30mm 12 point (BiHex) socket that you will need if you plan on ever removing the rear hub(s).
Abs sensor
What you have described sounds more like being a physical "thing" with that wheel's brake shoes, like not be allowed or forced to centre or something else concerning the springs, pivots hold downs or wedge adjustment/condition. The ABS system just modulates the fluid flow to the 4 wheels in response to one or more locking up.
TSI 1.2 Engine CBZB auxiliary belt/ Serpentine belt change interval
I consider that it makes sense to examine these exposed belts and make your own judgement on when to replace them, personally, I'd rather replace a good enough looking belt at 10 years than worry about it actually failing when far away from home. Tensioner assembly, maybe just check it out while the belt is off and if it feels/sounds a bit worn, then replace it. This was not usually an issue when cam belts and water pumps that were driven by the cam belt, were getting replaced every 4 or 5 years, as the workshop, if you gave that job to a workshop, would normally make that decision for you! (annoyingly for me, once only 3 months after I had replaced that belt - oh well.) Edit:- really as you have considered this task, just do it and then you can forget about worrying about it, for some reason I probably still buy belts from VW Group - maybe I didn't trust any application list I had checked for favoured aftermarket suppliers, just my money my choice.
New Scala - any strange anomalies and warning lights
I've found that once you have got your first TPMS warning "under your belt" - and found no credible reason for it, then the next time you should still pay attention to it and check the tyre pressure, but understand that any/all these systems can throw out a "ghost" warning, better safe than sorry, I still trust that these indirect systems will give me warning of a tyre losing pressure though - so a lot better than no TPMS.
Wheel adjustment
I think that most tyre/steering chains now have "alignment benchs/tables" - that sort of thing should be able to check camber, though a few years ago, my local one did not seem to have worked out what was needed to check the castor! These rear bonded bushes do end up distorted in some cases and the material torn in others, I got the LHS one replaced under the 3 year warranty on my wife's August 2015 VW Polo 1.2TSI, when changing the tyres to "winter" at the start of last winter, I spotted that the RHS rear mounting bush looked a bit distorted - as in the centre alloy bush had separated from the rubber material - so I replaced these bushes on both sides a few days ago, the hole in the rubber on the RHS is now oval with an "air gap" at each end, so that bush would be allowing quite a bit of "extra" movement - but no sign of uneven wear on the removed winter tyres - and I do measure them at 3 points after swopping tyres/wheels. Next idea might be to check the track rods as the inner swivel joints can end up wearing and having a bit of free movement, I had that on a 2002 VW Polo 1.4 16V at around 90K miles, it had been reported as an advisory at the MOT, so I just replaced both track rods and maybe even both TREs. Why I'm suggesting this is, if there is some slack in these track rods, the steering geometry will be free to move about.
