Everything posted by Danoid
Car won't start, lots of error messages
https://www.tayna.co.uk/car-batteries/?gclid=EAIaIQobChMIjt2Cw_H4-gIVh7btCh1ang2SEAAYASAAEgKtZPD_BwE I believe that’s where I bought a battery for my old Passat from, or it was battery mega store. Tanya whack in your reg and it should already know if your battery is EFB if not make sure you click the EFB tab Once you got the model number you can do more searching if anyone has it cheaper. I’ll be honest I’m not sure if it’s only stop start that needs coding, hopefully someone else can clarify
Very likely to be your battery, it’s around the right time for batteries to start dying with colder evenings. Have a look at your battery and see if it’s still the OE one as that could be the same battery it’s had all its life. What year is your car? If it is the original make a note of what battery you have, they’ll be a sticker saying AGM or something else B?? Then buy a direct Varta replacement. If it’s not obvious to you post a picture on here You’ll need it coded to your car
Will my car die if I replace the battery??
I believe I read it on here that when you change the battery you need to start the car and do full steering lock left and right a few times, and yes get it coded in, as long as the battery size is the same you’re good the other code can literally be any value, just something different to the previous value as I believe not all batteries have the correct stickers https://youtu.be/IJAScg6JrYI
Skoda superb 2018 xenon bulb upgrade
If you know German give this guys channel a watch, some of its English aswell I’ve linked the very bulbs I’m decided whether to get but watch his others as he does light output and on a Skoda albeit a octavia https://youtu.be/EKVgD2TYMUI
Looking to buy a 2020 Superb SE L
I played hardish to catch when I bought my car from a main dealer. In the end I got £2k off, four free services and free MOT for life, which is what I asked for straight away I went in saying I don’t want to play the fake ping pong of salesmen going to the manager then back and forth, I said I want to deal with the manager only, they accepted my request straight away so they probably still made plenty off me, but I did PCP so probably thought I’d get a new car when my deal ends but I paid the balloon payment
Comfort control module
Nightmare, mine was like a pond too but only issue I ever had was the alarm going off on all hours which turned out to be corroded grey connector in the passenger kick panel. Why VW decided to use a foam gasket by the pollen filter I’ll never know Glad to know the same issue isn’t present in the Superb 👍
I was once a Passat b5.5 man, the ccm placement still gives me nightmares. If you are asking because of anxiety, the scuttle area should still be cleaned on the Superb apprantly, but it’s even harder to get to because you need to remove the wipers 😬
Auto start / stop inversion!
My habit is starting the car and literally saying “turn that @“£&@“ off” So OP if you can get into a habit of turning it off it’s much cheaper and easier
Low speed manoeuvering
What do your rear discs look like? Upload a picture if you can as it’s always a laugh This was mine before I replaced, ignore the red line. This was at around 37k miles the outer section was never used 😂
Haha I had exactly the same with stalling, I was like how on earth can I stall an automatic. I went with Brembo coated discs as I got annoyed with the rusting, and skoda OE pads fitted by my local Skoda dealer, stops, it was still like £180 but the time I’d bought a battery maintainer and VCDS it just worked out cheaper to let them do it
The DSG gearbox can be a little jerky and it’ll be something you get use to. Its worth mentioning the gearbox oil and filter should be changed every 40k miles, but check if it’s ever been serviced as dealers don’t seem to mention it, at least not mine and some others on here 😞 Also check the condition of your rear discs and pads, OEM is a bit of an Achilles heal. My car is smoother and quicker at releasing the handbrake since changing them
Tyres annoyance....
They do indeed, I just like the peace of mind knowing mine still over reads by design incase there’s a speed camera van fishing, as the more the tyre wears with 245’s your going even more faster. That shouldn’t matter much unless you live on the 10%+2mph edge all the time
Tyres annoyance....
I only do about 3k a year so don’t listen to me for a long term review 😬 My friends probably covered about 5k since May and recently went to Wales on what he called rough roads, when he got back is when he said how much of a difference the 5 and 6 is
Tyres annoyance....
That’s possible, I doubt I’ve put more than 1k on them since sometime in May so time will tell but so far so good These are EV rated so I’d like to think they’ll stay quiet
Tyres annoyance....
Get the Asymmetric 6, much quieter than the 5. Although I’ve never used the 5’s my father in law has them on his A4 and quiet loud. One of my friends recently needed 4 tyres on his beemer and got 5’s on the front and 6’s on the rear due to needing them urgently but 6 wasn’t available in his size for the fronts (staggered sizes) as it’s a new tyres, he said the difference in sound is massive and much more quieter on the 6’s
Tyres annoyance....
Just get the eagle F1 asymmetric 6’s in default size, so much quieter than the P7’s, don’t need to tell insurance nor worry about it over-over reading, win win
Like I said earlier never had a chip before, today at 1540 I thought I’d go online to get the chip fixed, 1640 auto glass turned up, very impressed. Its still somewhat visible but have to really really look
What bulbs are fitted to the S3 & upgraded bulb recommendations
Is this just for the boot door lights only? Also what’s the deal with the wiring harness supplied, is it car loom plugs into that then the supplied wiring into the lights?
I remember reading that on here, but it’s thankfully only 1.3cm from end to end and on the passenger side outside of the wiper, so should just be a normal chip repair and more than 3cm from the edge
Software update
Is there a way to legitimately get the firmware? I’m getting some funky things going on with Bluetooth mostly and wondering if updating it would help. I don’t want to appear rude but if there’s a legit way of updating like satnav I’d love to know
Tyres annoyance....
Changing size will require to tell insurance to be 100% honest and covered. I went with these and absolutely love them, so much more quieter than the P7’s and had recently went through loads of massive puddles at 70mph and steering wheel hardly moved compared to the P7’s which was more scary https://www.asdatyres.co.uk/goodyear/eagle-f1-asymmetric-6?width=235&profile=40&diameter=19 https://www.camskill.co.uk/m55b8935s3932p0/Car_Tyres_-_MPV_Tyres_-_People_Carrier_Tyres_-_19_inch_Goodyear_Tyres_Car_Goodyear_Eagle_F1_Asymmetric_6_-_R19_inch_-_235_40_19_235_40R19 I got them from Camskill when they first come out at £150 per tyre but that’s just the tyre delivered, whereas Asda is full price so just chose your garage and done, just like blackcircles but that’s £196 fitted which is bonkers
Managed to get a stone hit my windscreen and cause a small crack. Almost 20 years of driving and first time ever, annoying but I guess it had to happen eventually
At wit's end with a coolant issue
Personally I’d get something like this https://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=230723938073&category=43998&pm=1&ds=0&t=1640273183000&ver=0&cspheader=1 Then one evening go out and have a look, cheap enough and easily DIY
Middle Seat Width
I’ve always found this to be a strange law personally. Is it possible to have your eldest sit in the front seat with the booster and the other adult sit in the middle? Ample room for the adult in the middle and no more distracting looking back all the time
Pencil behind dashboard!
How did you remove the scuttle btw? I’m sure when I checked mine I had to take the wiper blades off, is that the only way?
