Octavia MK1 VRS 1.8
17" (I think 6.5x17) would be normal on a UK vRS.
Headlight washers
Similarly on the old Octavia 1 (A4), on which they were very useful in mucky conditions.
Adaptive Lane Assist - Do I have it?
The nearest motorway to Norwich is the M11, and that's 60 miles as the crow flies.
Agreed, as long as you mean "real wood" (see under Aston Martin, van den Plas et al), and not "plastic wood" (see under Ford, Mercedes...).
Car failed MOT brakes - question
Er, they're not supposed to dismantle the car to carry out an MoT!
Antifreeze G40 — Specification advice
I'm not aware of any such thing as a VAG coolant specification. As per @brettikivi about actual coolant specifications. And absolutely do not use tap water in a hard water area like St Albans; you'd probably be OK in a soft water area like this.
early oil change notification
10_500+4_500 = 15_000. If you did the 10_500km in 2 months, 4_500km is an expected distance for you to cover in the next month. The warning will happen at 1 month or 1_600km before the service is due, whichever is sooner. So if you typically did, say 1_000km per month, the warning would still have appeared at this time.
Cambelt covered in oil after leak
Absolutely you need to change it, or start saving for a new engine. DO NOT drive the car in the interim.
Octavia 2 VRS TDI CEGA Blue Smoke
"Wather"? Do you mean "water"? If so, this is pretty normal until the engine heats enough that the exhaust gases stay above 100C to beyond the exhaust exit.
barn find felicia pickup.
Indeed, when God made time, he was sure and made plenty of it.
Ignition Key vs Fob
That is an "emergency door key" and not an ignition key. You owe them nothing since you have not damaged the key.
Ignition Key vs Fob
Ok, given what @Winston_Woof has said, I have a suspicion here. Would you describe, as completely as you can remember, the design of this key?
Seat belt locking
This usually means that you're jerking on the belt too suddenly, so that the inertia reel locks. It's unusual to be able to reproduce the issue with 3 different people though.
Car Park Fires, Transporters / Ships, any fires, any EV,s involved or not thread, were they the cause just there and so made fighting the fire harder.
Well, where there's fire there's smoke.
1995 Skoda Felicia LX 1.3 54 HP - Where can I purchase carburetor from?
That's definitely a carburettor, not a fuel injection throttle body.
Kamiq SOS Warning- Fault code- Take to workshops-
Yes, as long as there are independent VAG specialists in East Anglia.
Mot advisory Mcpherson pin/bush
Point to inspect; is there any sign of excess wear on one side of the NSF tyre? I've seen one car where the inside of the tyre was worn through to the banding, so it cost the owner for a new tyre as well as the parts and labour.
Adblue fun
@Iansuperb @PetrolDave This sub-section of the MoT Manual (copied from Web 29 Aug 2024) seems relevant. Have a read for yourselves and see if AddBlue is mentioned.
Head Gasket failure?
Not "need to be done", but it would be silly not to since the parts are less than the labour for a replacement and they're out.
Rear brake advice
@Geoff_Linton - Ok modified version of my post above. You certainly need to change that wheel cylinder, and use brake cleaner on that drum and back plate. You may well need to change the other wheel cylinder too if it's leaking and clean the drum and wheel cylinder on that side. If there is any suggestion of fluid contamination on any of the brake linings, best practice is to change all 4 shoes.
Rear brake advice
@Geoff_Linton More or less as @aubrey says above, with the note that I would go to another garage because the tester was talking male bovine faeces. The components you need to change are the rear wheel cylinders. You may also need to use brake cleaner on the drums and backplates and may also need to change the brake shoes, but I can't comment further because I can't open HEIC files.
Software failure not so Superb
Why am I not surprised?
Škoda Scala as a high mileage car
Taxi and private hire drivers around here are much more likely to buy Octavias or even Superbs than Scalas. This "poll" represents hundreds of drivers across 4 local authorities, including Greater Glasgow.
abs light has come on
@Joanc As @aubrey says, with the note that I never top up brake fluid until I have fitted any new brake friction components I'm about to fit.
