Inner tyre wear Dangerous Anyone Else?
I'm pretty certain that a gouge like that indicates either something sticking out from the spring just above the wheel, or the wrong size wheels fitted. What is the wheel size supplied? This will be either cast (alloy) or stamped (steel) into the wheel, probably on the inside. An example measurement (figures from my old Octavia for illustration only) would be "6.5x16 ET42 5x100 56.1".
Skoda Superb MKII Battery drain
This might seem like a strange question, but does the battery light come on when you first switch the ignition on, and before you start the engine?
Outside temperature dash display
My -20 was in Invergarry, and cold enough that 50/50 screenwash froze.
DSG AutoHold at Traffic Lights without brake pedal held down
OK, so why don't brake lights stay on when you use the handbrake? By the logic you seem to be applying this should happen.
Can't find factory OEM tires?
At the risk of repeating the thunderingly obvious, YOU DON'T KNOW, AND NEITHER DOES ANYONE ELSE, EXACTLY WHAT MAKE AND MODEL TYRES WERE ON THE CAR NEW! The likelihood is that they were "whatever the manufacturer could get, say 10_000 of, cheapest that month".
No pics but I've seen them go to -20C.
Kamiq reverse lights
You have H7 reversing light bulbs!?
the truth about electric cars
Doesn't that make these vehicles at least possibly LGVs under European laws?
Long Life oil question? 2014 Octavia vRS petrol
So timed service; with the stated mileage, "ordinary" oil is adequate.
How do you argue that brake lights that go out when you take your foot off the pedal are "defective"?
Fabia MK 2 power steering top-up.
@Dr. Lovebucket - @Jocko has a point; the only time I ever had to top up PAS fluid there was a leak...
skoda fabia diesel scout 1400
This "won't rev past 3_000" thing; would this be in neutral?
About to buy my first car ever—a second hand Skoda Superb...
@profcalculus Unless you want to be a fashion victim with a bad back, look for one with "small" (17") wheels, because it rides better.
Suspension upgrade
Report the thread to the moderators with "reason for report" being "wrong forum".
Flashing coil light 😱
With the aid of an assistant, check whether or not the brake lights work. If none of them do, replace the brake light switch.
Phoenix orange
Isn't it more of a marmalade colour?
Car Park Fires, Transporters / Ships, any fires, any EV,s involved or not thread, were they the cause just there and so made fighting the fire harder.
Cite needed.
Has your Octavia ever jumped into manual on its own?
I think this is called "normal design operation", or "kickdown".
Citigo mileage display
Dead elements on the LCD panel. It also won't display 0, 2, 3, 4, 5, 6 or 9 correctly. I'm afraid that repairing the display will mean getting a new panel, so I'd suggest just living with it.
Car failed its MOT.
Well, mine visibly broke a rear spring whilst parked!
Car starts, can’t put into gear
As a test, try starting in neutral rather than park.
Well, FWIW the last car fire I saw was a V@*xh@11 Firelighter Z@f1r@, and the one before that was a turbo Renault which had a bird build its nest on the turbocharger.
- Cooling down turbo engine, by idling engine..
120L engine swap
Forget the Porsche motor; it's a complete boat anchor beside a Skoda 120 (or even 130) unit. Look for an Alfasud flat 4 if you want more power and to keep a bit of handling.
iV Charging
There's this stuff called "insulating tape"... We used to regularly use it to partially blank main beam lights, particularly on Fords.
